Programming
Guest bear63
I have an Anytone 5888uv, when I program one side it automatically transfers same info to other screen,also I programmed gmrs simplex to memory and some 440 repeaters,when I try to transmit on gmrs,it offsets
Is there a question in that ^ ?
Have you read all the manuals?
Asking for a friend.
  • 2 months later...
It may be programmed with an offset if you are on a repeater channel. When you hit the  P.T.T. button do the first three numbers of your frequency increase by 5Mz?  for example:
462.700 MHz to 467.700MHz ? Some radios will show this on the display. Not all. If that's the case you will have to go into your radio's settings and check. Read the manual.
When you are keying a repeater in this case, you're actually transmitting on 467.700 MHz which is the input of the repeater that then re-transmits your message on 462.700 MHz. With no offset, you would probably be transmitting simplex, Meaning radio to radio with no repeater involved. Hope this helps.
"Read the manual"
Is it not a man's right to not read the manual, figure it out for himself, if not, then by failing to read any part of it, get on a forum and complain about the
crappy radio???
surely I jest!
