WSDB540 Posted June 11, 2024 Report Posted June 11, 2024 I have a CB base antenna up. I want to put up a GMRS base antenna on a separate pole. How far apart does it need to be away from the CB antenna? Thanks Quote
1 MSnow Posted June 11, 2024 Report Posted June 11, 2024 I had on my truck dual firesticks on each bed rail and then had my mxta26 on the roof about 2.5ft away from each firestick with no issues. SteveShannon and WSDB540 2 Quote
1 BoxCar Posted June 11, 2024 Report Posted June 11, 2024 Antenna spacing is critical when the frequencies are within the same band or one (or both) are using high power. CB is essentially HF (below 30 MHz) while GMRS is UHF (462 - 467 MHz) or 20 times higher in frequency. Your spacing should be at least a quarter-wave length of the UHF channels or 15 CM. WSDB540 and SteveShannon 1 1 Quote
0 WRYZ926 Posted June 11, 2024 Report Posted June 11, 2024 General rule of thumb is to space antennas apart by 1/2 to 1 full wave length. A full wave length for CB is 11 meters/36 feet. A half wave length is 5.5 meters/18 feet. So you would want your GMRS antenna at least 18 feet away from your CB antenna horizontally. You can put antennas closer together vertically if you have the space to go up and down. WSDB540, WRXR255 and SteveShannon 3 Quote
0 WSDB540 Posted June 11, 2024 Author Report Posted June 11, 2024 18 hours ago, WRYZ926 said: General rule of thumb is to space antennas apart by 1/2 to 1 full wave length. A full wave length for CB is 11 meters/36 feet. A half wave length is 5.5 meters/18 feet. So you would want your GMRS antenna at least 18 feet away from your CB antenna horizontally. You can put antennas closer together vertically if you have the space to go up and down. I can go higher for the GMRS antenna thanks for the help. WRYZ926 1 Quote
WSDB540
Thanks
4 answers to this question
