I have been in preparations for a computer swap, so i bought an encrypted thumb drive to put everything important on to it. Well, that has taken a few days and I've gotten a little Clicky with the mouse. As you can see by the image i changed Whatever (program, or whatever) I've tried to Re-install the Original Software that didn't change it, I tried to Install the New Software that didn't change it and finally i tried to Restore my PC back a day, but even the Restore failed. Can someone tell me what this is to be running in before i change over later today? Thanks, Ron
16 answers to this question
then what about saving to the channels to the file. What if its not a file anymore, i changed something maybe not even in the software itself maybe its in windows, could that be where my issue is?
Expand
What about it?  I guess I don’t understand what you’re having trouble with…
What is it that you think has changed?
Posted (edited)
THE MORE I THINK ABOUT IT NOW IT HAS TO BE A WINDOWS ISSUE, IF THAT HELPS ANYONE!!
i have to step ot for about 25 minutes maybe less, but ill be back, thanks for the input so far. Now if there are some windows 10 experts on or come through that would be amazing. Thanks, Ron
Edited by WRTJ860
need to update why i won't be able to respond immediately
  On 6/21/2024 at 5:35 PM, WRTJ860 said:
the icons used to look like file folders, now notebook is what i hit by mistake to open the files in error
Expand
The default program to open .KG files was somehow set to Notebook. That’s an easy thing to fix but it doesn’t mean that your radio will be damaged.
Right click on a kg file, click on open with, choose the name of the Wouxun CPS, and click on “Always use this program “.
