VERTEX STANDARD EVX-R70 PROGRAMMING PROBLEM
3 answers to this question
With what you provided in our request, no. If you stated what kind of help you neede, such as locating cables, software or something specific, then yes, someone can and will provide help.
Now, what help do you need?"
42 minutes ago, WRVX811 said:
I have recently come into the possession of a VERTEX STANDARD EVX-R70 repater and am having issues programming it.
Can anyone help.
Thanks
What are the issues you're having? Someone may recognize the problem.
I have the same repeater. Please describe the help you need and I'll try to help you. Depending on what is preventing you from proceeding, if necessary, you can send me your codeplug file and I can set it up and send it back to you for uploading to the repeater. If you need the programming cable, contact Blue Max 49ers. I'm not sure if he has the software.
If you have the software, depending on the codeplug firmware and the software versions, you most likely need the Windows 7 or 8 64 bit Operating System and most cases, you have to run the application as the administrator.
