Guest Timber_Canyon Posted July 7, 2024 Report Posted July 7, 2024 Where in the world are the squelch settings for the 5RM in CHIRP? Is it still supported? Quote
WRWE456 Posted July 7, 2024 Report Posted July 7, 2024 Squelch is not something you program with software. You have to be able to adjust it on the fly as needed, like volume. Quote
SteveShannon Posted July 7, 2024 Report Posted July 7, 2024 2 hours ago, WRWE456 said: Squelch is not something you program with software. You have to be able to adjust it on the fly as needed, like volume. Some radios have deeper squelch settings that can only be configured with the CPS which allow you to control how the squelch works when you adjust it on the fly. WRXB215 1 Quote
WRWE456 Posted July 7, 2024 Report Posted July 7, 2024 Thanks Steve I did not know that. Doesn't seem to be very useful according to Randy. Maybe under certain conditions. SteveShannon 1 Quote
WRXR255 Posted July 7, 2024 Report Posted July 7, 2024 The 5RM "driver" in CHIRP is still experimental. I am sure if the squelch levels can be changed in the 5RM, like they could in the UV-5R family, at some point they might be adjustable but it may not be possible with the firmware or how the radio is made. Its why its important to keep CHIRP updated. And why its important to keep the older versions around too. Sometimes the update takes something that worked before and messes with it. WRXB215 1 Quote
WRXR255 Posted July 7, 2024 Report Posted July 7, 2024 8 hours ago, WRWE456 said: Squelch is not something you program with software. You have to be able to adjust it on the fly as needed, like volume. On the VU-5R Radios you could adjust the squelch setting breaks. It did not have a potentiometer squelch, you set a level of squelch from 0 to 9 in the menu. With that by default, the settings where the break level was in a new radio was kinda bizarre, so any level you had from 1 to 9 was not much different. For instance: You could adjust the levels for each setting from 0 to 120, but in the top pic, I adjusted mine to a max of 60, as above that you were pretty much fully "deaf". WRXB215, WRWE456 and SteveShannon 2 1 Quote
Guest Timber_Canyon Posted July 7, 2024 Report Posted July 7, 2024 Thanks for the replies. I think WRXR255 might have gotten it. I should have been more specific, but what I was looking forvwas this. https://www.miklor.com/COM/UV_Squelch.php Quote
Guest Any Updates on 5RM Squelch Posted January 18 Report Posted January 18 I see this topic was last commented on in June of 2024. I find the factory squelch settings on the Baofeng 5RM are lacking insofar as there does not seem to be a reasonable breakthrough setting anywhere on the default range. Does anyone know if the CHIRP-adjustable fine tuning functionality mentioned above in this thread is forthcoming for the 5RM? Quote
