WSDS892 Posted July 15, 2024 Report Posted July 15, 2024 If there is repeater local to me would I be able to hear someone transmitting if I was tuned to that frequency without having programmed in dpl/ctss or any of the other stuff I haven't wrapped my head around yet? GP62 1 Quote
Guest Posted July 15, 2024 Report Posted July 15, 2024 Yes. The tone only keep LS others from transmitting into the repeater. Tones or not you will here it all on simplex. Nothing is private Quote
GreggInFL Posted July 15, 2024 Report Posted July 15, 2024 24 minutes ago, WSDS892 said: If there is repeater local to me would I be able to hear someone transmitting if I was tuned to that frequency without having programmed in dpl/ctss or any of the other stuff I haven't wrapped my head around yet? Yes. Tones are filters that filter out everything not on that tone, so if you want to receive everything coming from a repeater just don't set any receive tone and you will filter out nothing. SteveShannon, GP62 and kirk5056 3 Quote
WSDS892 Posted July 15, 2024 Author Report Posted July 15, 2024 Thanks for the replies. TrikeRadio and GreggInFL 2 Quote
WSCE577 Posted July 17, 2024 Report Posted July 17, 2024 On 7/15/2024 at 2:25 PM, WRXP381 said: Yes. The tone only keep LS others from transmitting into the repeater. Tones or not you will here it all on simplex. Nothing is private Do all GMRS repeaters have a +5.0 MHz offset for transmit? (ie: 462.625 Rx is 467.625 Tx)? I think I understand tone codes to transmit to open the repeater. Quote
OffRoaderX Posted July 17, 2024 Report Posted July 17, 2024 2 minutes ago, WSCE577 said: Do all GMRS repeaters have a +5.0 MHz offset for transmit? Yes. marcspaz 1 Quote
WSCE577 Posted July 17, 2024 Report Posted July 17, 2024 2 minutes ago, OffRoaderX said: Yes. OffRoaderX Thank you. It has been a long time since my early days of GMRS. I just renewed my license after about a 20 year hiatus! GP62, marcspaz and GreggInFL 3 Quote
BoxCar Posted July 17, 2024 Report Posted July 17, 2024 7 hours ago, WSCE577 said: Do all GMRS repeaters have a +5.0 MHz offset for transmit? (ie: 462.625 Rx is 467.625 Tx)? I think I understand tone codes to transmit to open the repeater. Yes, the frequencies (channels) are set by regulation. Quote
