WRYG716 Posted August 10 Author Report Posted August 10 57 minutes ago, BoxCar said: It sounds like shop time. Yeah that’s the problem no local shops lol Quote
BoxCar Posted August 10 Report Posted August 10 Looks like Morganton or Wheeling are the closest Moto dealers. Quote
WRYG716 Posted August 11 Author Report Posted August 11 So this is strange repeater is programmed to 462.675 I have a handheld that can scan for frequencies when I key up repeater it’s showing 440.002 I type that into radio with 77 pl and I hit the repeater and get a clear tone. What could be causing that? Quote
OffRoaderX Posted August 11 Report Posted August 11 2 hours ago, WRYG716 said: So this is strange repeater is programmed to 462.675 I have a handheld that can scan for frequencies when I key up repeater it’s showing 440.002 I type that into radio with 77 pl and I hit the repeater and get a clear tone. What could be causing that? Its not programmed the way you think it is. Quote
WRYG716 Posted August 11 Author Report Posted August 11 1 hour ago, OffRoaderX said: Its not programmed the way you think it is. Well when I write it then read it back to the pc it’s giving me my frequencies. Any idea what I’m doing wrong? Quote
OffRoaderX Posted August 11 Report Posted August 11 12 minutes ago, WRYG716 said: Any idea what I’m doing wrong? are you sure its set to the correct channel, and in Repeater-mode? Quote
WRYG716 Posted August 11 Author Report Posted August 11 5 minutes ago, OffRoaderX said: are you sure its set to the correct channel, and in Repeater-mode? Positive like I said when I write to the computer from radio it’s showing 462.675 467.675. Repeater light is on. Quote
WRYG716 Posted August 11 Author Report Posted August 11 3 minutes ago, WRYG716 said: Positive like I said when I write to the computer from radio it’s showing 462.675 467.675. Repeater light is on. Quote
WRYG716 Posted August 11 Author Report Posted August 11 10 minutes ago, WRXB215 said: Your TX and RX frequencies are reversed. Rx is 467.6750 TX is 462.6750 SteveShannon 1 Quote
WRYG716 Posted August 11 Author Report Posted August 11 This is my radio picking up the tone from my repeater on 440 how is this possible? IMG_2438.mov Quote
OffRoaderX Posted August 11 Report Posted August 11 19 minutes ago, WRYG716 said: This is my radio picking up the tone from my repeater on 440 how is this possible? Is it ALSO transmitting on the correct frequency or ONLY on the wrong frequency? Quote
WRYG716 Posted August 11 Author Report Posted August 11 8 minutes ago, OffRoaderX said: Is it ALSO transmitting on the correct frequency or ONLY on the wrong frequency? Only wrong. Can’t hit it on the right frequency. No rx or tx only on that 440 Quote
OffRoaderX Posted August 11 Report Posted August 11 attach a pic of the front panel showing the display and all the buttons/lights. Quote
WRYG716 Posted August 11 Author Report Posted August 11 1 minute ago, OffRoaderX said: attach a pic of the front panel showing the display and all the buttons/lights. Quote
OffRoaderX Posted August 11 Report Posted August 11 ok, something is seriously wrong.. That's the best I can do so, I'm out. Quote
MarkInTampa Posted August 11 Report Posted August 11 If I had to guess, you have the wrong version of the repeater for GMRS or the frequency limits are set incorrectly. Try binging up the software in manufacture mode with the "-m" option instead of "-d" and read the radio configuration. The Windows shortcut target should be something like "C:\Vertex Standard\CE27 for Windows\CE27Win.exe" -m". The -m option will require the manufacture password, it is "ansho-bango". Once you read the config of the radio, go to "Common" on the top of the screen and then "TX Adjustment". Be VERY careful here and don't adjust anything, check to see what the highest Tx Frequency is set at. If it's below GMRS frequencies it's probably the wrong version of the repeater. OffRoaderX 1 Quote
WRYG716 Posted August 11 Author Report Posted August 11 14 minutes ago, MarkInTampa said: If I had to guess, you have the wrong version of the repeater for GMRS or the frequency limits are set incorrectly. Try binging up the software in manufacture mode with the "-m" option instead of "-d" and read the radio configuration. The Windows shortcut target should be something like "C:\Vertex Standard\CE27 for Windows\CE27Win.exe" -m". The -m option will require the manufacture password, it is "ansho-bango". Once you read the config of the radio, go to "Common" on the top of the screen and then "TX Adjustment". Be VERY careful here and don't adjust anything, check to see what the highest Tx Frequency is set at. If it's below GMRS frequencies it's probably the wrong version of the repeater. All looks the same to me. Quote
MarkInTampa Posted August 11 Report Posted August 11 Since you can receive the repeater at 440.000 but the CPS shows 462.675, what happens if you add a channel on 439.xxx and another on 441.xxx just for testing? Does the repeater transmit on the programmed frequency then (440 being a upper limit maybe)? Weird problem, can't think of anything else. Quote
WRYG716 Posted August 11 Author Report Posted August 11 2 minutes ago, MarkInTampa said: Since you can receive the repeater at 440.000 but the CPS shows 462.675, what happens if you add a channel on 439.xxx and another on 441.xxx just for testing? Does the repeater transmit on the programmed frequency then? Weird problem, can't think of anything else. Hang on I’ll try that! I actually thought of doing that was just to chicken lol Quote
WRYG716 Posted August 11 Author Report Posted August 11 6 minutes ago, MarkInTampa said: Since you can receive the repeater at 440.000 but the CPS shows 462.675, what happens if you add a channel on 439.xxx and another on 441.xxx just for testing? Does the repeater transmit on the programmed frequency then? Weird problem, can't think of anything else. Nope got nothing. This is wild Quote
OffRoaderX Posted August 11 Report Posted August 11 Maybe you should take it back to the guy you got it from and tell him you want one that works? Quote
