Widowsson Posted August 13, 2024 Report Posted August 13, 2024 I bought everything I need to build a node for gmrs. Or so I thought. Here’s the one I got: AURSINC MMDVM Hotspot Board (V1.5.2) + Antenna Support UHF VHF Support P25 DMR YSF DSTAR NXDN POCSAG for Raspberry Pi-Zero W, Pi 3 Doea anyone know if this will work or do I need a RF only? Quote
SteveShannon Posted August 13, 2024 Report Posted August 13, 2024 7 hours ago, Widowsson said: I bought everything I need to build a node for gmrs. Or so I thought. Here’s the one I got: AURSINC MMDVM Hotspot Board (V1.5.2) + Antenna Support UHF VHF Support P25 DMR YSF DSTAR NXDN POCSAG for Raspberry Pi-Zero W, Pi 3 Doea anyone know if this will work or do I need a RF only? That hotspot was designed for digital modes, ham radio. I don’t know if or how it can be used for GMRS. Widowsson 1 Quote
BoxCar Posted August 13, 2024 Report Posted August 13, 2024 1 hour ago, SteveShannon said: That hotspot was designed for digital modes, ham radio. I don’t know if or how it can be used for GMRS. True. Hotspots are used to convert between analog (FM) and the different digital modes. If you are just building a scanner type device to see if there is anything on the air then just an SDR radio would work. Widowsson 1 Quote
WRQC527 Posted August 13, 2024 Report Posted August 13, 2024 10 hours ago, Widowsson said: I bought everything I need to build a node for gmrs. Or so I thought. Here’s the one I got: AURSINC MMDVM Hotspot Board (V1.5.2) + Antenna Support UHF VHF Support P25 DMR YSF DSTAR NXDN POCSAG for Raspberry Pi-Zero W, Pi 3 Doea anyone know if this will work or do I need a RF only? I'm going to be a little harsh here, so bear with me. Send this thing back where you got it and get your money back. It was not intended for GMRS, and it won't work. Before you spend another penny on equipment, ask here first. A simple question like "Will an MMDVM hotspot work with GMRS?" would have been met with a resounding "no", and would have saved you time, aggravation and quite possibly money if you end up stuck with this thing. AdmiralCochrane, gortex2, Widowsson and 1 other 3 1 Quote
