WSEH456 Posted September 4, 2024 Report Posted September 4, 2024 I downloaded the latest and greatest version of programming software from Baofeng for the UV-5G Plus. Opened the software, plugged in the USB cable to the computer and handheld radio, turned on the radio and went to Settings -> Port. The Port drop down is blank. Is there a sequence to making the connection, outside of common sense, or do I have a bad programming cable? Thanks, Brent - WSEH456 Quote
OffRoaderX Posted September 4, 2024 Report Posted September 4, 2024 You *might* have a bad programming cable, but it could just be a "driver issue" with Windows. If that is the case, may Xenu have mercy on your soul.. What version of the Windows are you running? AdmiralCochrane 1 Quote
OffRoaderX Posted September 5, 2024 Report Posted September 5, 2024 31 minutes ago, WSEH456 said: Windows 11 Home Good luck with that.. You're going to need it. Quote
WSEH456 Posted September 5, 2024 Author Report Posted September 5, 2024 I don't get it but, I plugged the cable in to the computer and handheld, went into the Device Manager and I found the connection under the USB connection. I was then able to turn on the handheld, read and write to the handheld. Crisis averted!! WRXB215 and SteveShannon 2 Quote
LeoG Posted September 5, 2024 Report Posted September 5, 2024 Praise Oh Xenu, for thou have thwarted thy torture of driver hell.... Amen. OffRoaderX 1 Quote
WRYS709 Posted September 5, 2024 Report Posted September 5, 2024 Someone once suggested this driver Quote
Raybestos Posted September 5, 2024 Report Posted September 5, 2024 FWIW, this thing has made my life so much better. https://www.buytwowayradios.com/xlt-rpc-k1-uf.html I am not a computer geek of any sort. I despise them and yes, I know they make us being here, possible. These cables make programming any radio that I don't have RT Systems software for, so much more do-able. Quote
WRYS709 Posted September 6, 2024 Report Posted September 6, 2024 2 hours ago, Raybestos said: FWIW, this thing has made my life so much better. https://www.buytwowayradios.com/xlt-rpc-k1-uf.html I am not a computer geek of any sort. I despise them and yes, I know they make us being here, possible. These cables make programming any radio that I don't have RT Systems software for, so much more do-able. Yes, I purchased a FTDI chip USB to K1 cable from Amazon back in 2016 when I first started working with Baofengs and the FTDI chip is easily supported by updated driver software for all operating systems! I even build a DIY adapter that I found on Miklor that allows it to work with the Radioddity DB20-G and Anytone AT-779UV mini-mobile RJ-45 style radios! WRQI663 and Raybestos 2 Quote
WRQI663 Posted September 6, 2024 Report Posted September 6, 2024 Miklor had info on how to make your own - I did it for 2 radios, the COTRE CO04d DMR toy radio and one for the UV5G that work great. Get some UART's and cut an old usb cable, it's easy...... Quote
WRYS709 Posted September 6, 2024 Report Posted September 6, 2024 7 hours ago, WRQI663 said: Miklor had info on how to make your own - I did it for 2 radios, the COTRE CO04d DMR toy radio and one for the UV5G that work great. Get some UART's and cut an old usb cable, it's easy...... Is that the Cotre model with the LED screen? I got the low end version for $14 before they disappeared from the face of the Earth, and I would love to find the LED version. And yes, my FTDI cable works with the Cotre too. Quote
WRQI663 Posted September 7, 2024 Report Posted September 7, 2024 No it is the toy, you see a display behind the case lit up but nothing visible after a few seconds It's pretty small, next to my bug here, which one do you have? Quote
WRQI663 Posted September 8, 2024 Report Posted September 8, 2024 Does that also display behind the case too? Quote
