WSEH456 Posted September 24, 2024 Report Posted September 24, 2024 I installed what I think is the correct software (Baofeng_UV-5RM_CPS_20231124), selected the Port 3 and hit the Read button and get a Failure. I can see the computer connecting to the HT. Any thoughts or is there a newer version than that what is on the Baofeng website? Thanks, Brent Quote
OffRoaderX Posted September 24, 2024 Report Posted September 24, 2024 What kind of cable are you using/do you know the cable works with your computer? Quote
WRYZ926 Posted September 25, 2024 Report Posted September 25, 2024 Also makes sure that the cable is plugged into the radio all of the way. My Baofeng GT-5R gave me fits until I realized I didn't have the cable plugged in all of the way. I couldn't tell just by looking at it. Also make sure your cable has the preferred FTDI chip instead of the older Prolific chip. Quote
WSEH456 Posted September 25, 2024 Author Report Posted September 25, 2024 It's the programming cable that came in the box. I find Port 3 in Device Manager which shows up in Settings in the program. When I hit the Read button, I see the screen change on the HT like it is communicating with with the computer, then get the Failure message. Using the UV-5RM program download from: Download - Baofeng (baofengradio.com) Quote
OffRoaderX Posted September 25, 2024 Report Posted September 25, 2024 23 minutes ago, WSEH456 said: It's the programming cable that came in the box. It is likely this is a Windows/Driver issue with the cable and has nothing to do with the software or the radio.. What version of Windows are you using? WRYZ926 1 Quote
WSEH456 Posted September 25, 2024 Author Report Posted September 25, 2024 Standard Windows go to...... Restart the computer! LOL I originally downloaded the UV-5RM Plus software by accident and got the Failure. I removed it from the computer and downloaded the actual UV-5RM software, installed and tried it then and got the Failure. I restarted the computer which cleaned the cache and tried it again and it Read the HT successfully. Thanks again gang! Brent WRXB215 1 Quote
WSAA635 Posted September 27, 2024 Report Posted September 27, 2024 Same "no read" issue with the UV-5RM Plus that I have with the AR-5RM in CHIRP. Baofeng software reads the radio but you can't program Airband and the UV won't accept the saved AR radio program so I'll have to enter everything I'm the program by hand. Quote
ma5carena5 Posted October 5, 2024 Report Posted October 5, 2024 I have two Baofengs that I program with CHIRP. On one of the radios, the cable plug does not fully insert. It looks like it is fully inserted, but it is not and hence get that error message. To program it, I have apply pressure to the connector to make it go in further and hold it down while the programming is downloading. Quote
WRYZ926 Posted October 6, 2024 Report Posted October 6, 2024 Are you guys using the latest version of CHIRP Next? Are you making sure that the programming cable is pushed all the way in? I have used CHIRP to program the UV-5R GMRS and GT-5R radios I own without issues as long as I make sure the cable is pushed into the radio all the way. I also have programmed a couple of UV-5RM radios and UV-9R radios again without issues. I used the latest version of CHIPR Next and the OEM Baofeng programming cables for all of them. I programmed the two UV-5RM radios a couple of weeks ago and programmed the UV-9R radios yesterday. Note: the UV-9R uses a Motorola type connector and not the usual Kenwood type connector. SteveShannon 1 Quote
