BTech V2 GMRS +- Repeater Offset
I can not transmit on GMRS 1.  The only thing I see different from other GMRS channels is the +- repeater offset image is on the display.  How do I turn it off?  I can not find it in the manual.
6 answers to this question
1 hour ago, amaff said:
Sounds like you somehow managed to set an offset onto GMRS 1. So you're transmitting to a frequency that isn't GMRS1.
Disable the offset and try it again?
As long as the offset is positive, the OP is still on a GMRS channel. Channel 8 is channel 1 + 5.000 MHz. It’s also an interstitial channel which is limited to 0.5 watts.
If the offset is negative the OP is down in some other service.
I didn't say it wasn't GMRS. I said it wasn't GMRS 1.  If they're trying to talk on GMRS 1, and have another radio listening on GMRS 1, transmitting on GMRS 8 isn't helping them any
