Guest old baldy Posted October 28, 2024 Report Posted October 28, 2024 I'm interested in the Radtel RTT 493 handheld radio. It is advertised as a GMRS radio with repeater capability. I tried to find a user manual so I could review it and verify that it does what I need but cant find one. Does anyone have this radio and can share their experience using it? thanks Old Baldy Quote
BoxCar Posted October 28, 2024 Report Posted October 28, 2024 Reports on other models of Radtel state they're not great but adequate. Quote
Guest Posted October 28, 2024 Report Posted October 28, 2024 Yea it is repeater capable when programmed in a computer. I have no idea if it comes with cable or kit or what software it needs to program. Chirp? Rt systems? but I’d buy one of many other better radios. Quote
Guest Programing a radtel 483 on Posted December 15, 2024 Report Posted December 15, 2024 Chirp is a no go..how do I program thus thing..nothing on youtube. Quote
Guest Jammin & Programmin Posted January 22 Report Posted January 22 Hey folks! Looks like Radtel have a software available on their site here (https://www.radtels.com/pages/software-download) There's a cable they sell as well for under 10 bucks that does the job. You can find their cable on amazon, and I just ordered mine. Look a little more than halfway down the page on their site to find the 493, you'll need WinRAR to extract and install the software and then you should be set up to program! Quote
Guest speedbump Posted January 27 Report Posted January 27 I have the software, the cable and the radio hooked up. The software doesn't seem to recognize the radio at all. Quote
SteveShannon Posted January 27 Report Posted January 27 2 hours ago, Guest speedbump said: I have the software, the cable and the radio hooked up. The software doesn't seem to recognize the radio at all. With all CPS software: Make sure you load the driver first, before ever plugging in the cable. Most require you to select the correct com port. WRXB215 1 Quote
1speedbump Posted January 28 Report Posted January 28 Driver??? I have a selection of 2 ports, neither seem to matter. Quote
SteveShannon Posted January 28 Report Posted January 28 19 minutes ago, 1speedbump said: Driver??? I have a selection of 2 ports, neither seem to matter. You must load the driver software. It is specific to the cable and creates a virtual serial port that the programming software can use. Look on the software download page for the right cable driver. You can see some listed in the center of the screenshot below: WRXB215 1 Quote
1speedbump Posted January 28 Report Posted January 28 I read somewhere that a driver isn't necessary, that it is in the cable. However my cable is old and is for a UV5R. I guess they are going to make me spend more money. Quote
SteveShannon Posted January 28 Report Posted January 28 Just now, 1speedbump said: Iread somewhere that a driver isn't necessary, that it is in the cable. However my cable is old and is for a UV5R. I guess they are going to make me spend more money. I have no idea if the UV5R cable might work, but it would still need a driver. Quote
1speedbump Posted January 28 Report Posted January 28 Apparently it won't work. I tried it on the old UV5R and it won't even work there on Chirp. I guess I'll head on over to Amazon and get the new one. It's been close to ten years since I used the UV5R and that cable, so who knows what goes on. Maybe the difference between Windows 7 or maybe even earlie and Win 11. Plus 32bit as opposssed to 64bit. Quote
SteveShannon Posted January 28 Report Posted January 28 13 minutes ago, 1speedbump said: Apparently it won't work. I tried it on the old UV5R and it won't even work there on Chirp. I guess I'll head on over to Amazon and get the new one. It's been close to ten years since I used the UV5R and that cable, so who knows what goes on. Maybe the difference between Windows 7 or maybe even earlie and Win 11. Plus 32bit as opposssed to 64bit. Windows 11 killed the ability to use some cables that were made using counterfeit chips. Maybe that’s what happened. WRXB215 1 Quote
1speedbump Posted January 28 Report Posted January 28 Very possible. I just ordered the one they recommend. I'll know more Friday when it arrives. Thanks for the help! SteveShannon 1 Quote
1speedbump Posted February 1 Report Posted February 1 Well it arrived and it is plug and play. Downloaded all the stock freq's and changed all the output power to low so I wouldn't flatten my battery in short order. Not bad for just over $ 6.00 on Amazon with free shipping. Funny part; when I saved the file then went to look at it with Windows, it was all Chinese Jibberish. The only way to view it is to open the software and do it there. Quote
wbmccarty Posted April 6 Report Posted April 6 The manual is available on the Support section of the Radtel website. It is very brief. The radio does not appear to be FCC Part 95E compliant or Part 95E certified. Its stated output power (10W) exceeds the maximum allowable for portable GMRS devices (5W). The higher power seems unlikely to provide greater range but would certainly drain the battery more quickly than the legal power. The RT-493 also supports frequencies that are not part of the FCC-allocated GMRS spectrum, though Radtel asserts they are GMRS frequencies. Specifically, it supports 44 of the 30 Simplex channels [sic] authorized by the FCC. I checked Part 95E as of the date of this posting, April 6, 2025. Personally, I would avoid the RT-493, especially if communicating with devices other than the RT-493 itself, since you may inadvertently choose a non-GMRS channel. Moreover, I strive to operate in full compliance with FCC rules and regulations. Jaay and Chicagojon2016 2 Quote
