(UPDATE) Favorite Magmount Antenna?
Picked up a BTech Nagoya UT-72G for my SUV. Very poor RX/TX, even though plenty of steel roof ground plane.
My stock-stubby HT outperforms it from inside the vehicle.
I plan to buy another antenna to compare against before returning it.
So, what are your favorite magmount options?
  • Primary use is Simplex.
  • Urban hills (no buildings over 10 stories, but plenty of hills. 3db?).
  • Need to stick with removable for now. No drilled holes.
  • Would consider bracket mount for top of rear hatch (but worse ground plane?)
I haven't done SWR sweep; don't wanna focus on numbers just yet - would rather stick with analogue comparison initially.
It'll be easy to compare. The UT-72G is performing noticeably worse than any HT in the vehicle.
Thank you.
[UPDATE] I purchased a TRAM 1192 to test through-glass before I spend more on sexier magmount options.
Will update.
On 7/12/2025 at 12:53 PM, WRTC928 said:
Actually, my favorite is a magnetic base with an NMO mount. Then I put a Comet 2x4 or some other quality antenna on it.
the ability to swap out as needed is very helpful, and i have probably 3 or 4 mag mounts around for whatever i feel like messing with
