GMRSJohn Posted 14 hours ago Report Share Posted 14 hours ago This is what I get every time I try to hook up on chirp. What do I do? WSEZ 1 Quote Link to comment Share on other sites More sharing options...
0 OffRoaderX Posted 13 hours ago Report Share Posted 13 hours ago I see this message when I have selected the wrong type of radio from the drop-down list. Is your radio a UV-5RH? WRUU653 1 Quote Link to comment Share on other sites More sharing options...
0 GMRSJohn Posted 13 hours ago Author Report Share Posted 13 hours ago And what is a radio image? Quote Link to comment Share on other sites More sharing options...
0 TrikeRadio Posted 13 hours ago Report Share Posted 13 hours ago radio image means a download of the data from the radio that matches your radio. I don't even see a UV-5RH on the read from radio list in my CHIRP.. maybe i need to update.. but is that you exact radio or did you choose the wrong one? possibly UV-5RH is a new radio for CHIRP and it is not working right yet? GMRSJohn 1 Quote Link to comment Share on other sites More sharing options...
0 GMRSJohn Posted 13 hours ago Author Report Share Posted 13 hours ago 2 minutes ago, OffRoaderX said: I see this message when I have selected the wrong type of radio from the drop-down list. Is your radio a UV-5RH? No it’s a uv-5g plus. Which is supposed to be chirp compatible. But isn’t on the list. But people have told me that the uv5rh is basically the same. Quote Link to comment Share on other sites More sharing options...
0 OffRoaderX Posted 13 hours ago Report Share Posted 13 hours ago 2 minutes ago, GMRSJohn said: people have told me that the uv5rh is basically the same They lied to you... Are you using "CHIRP" or "CHIRP NEXT"? In CHIRP NEXT, select GM-5RH TrikeRadio and WRUU653 1 1 Quote Link to comment Share on other sites More sharing options...
0 GMRSJohn Posted 13 hours ago Author Report Share Posted 13 hours ago 1 minute ago, OffRoaderX said: They lied to you... Are you using "CHIRP" or "CHIRP NEXT"? It’s the 2024 version. what do I need to do? Quote Link to comment Share on other sites More sharing options...
0 OffRoaderX Posted 13 hours ago Report Share Posted 13 hours ago 3 minutes ago, GMRSJohn said: what do I need to do? 1) Install CHIRP NEXT 2) Select GM-5RH D) Program Radio 5) Thank me WRKW566, SteveShannon, WSEZ and 2 others 4 1 Quote Link to comment Share on other sites More sharing options...
0 GMRSJohn Posted 13 hours ago Author Report Share Posted 13 hours ago 3 minutes ago, OffRoaderX said: 1) Install CHIRP NEXT 2) Select GM-5RH 3) Program Radio 4) Thank me Just to confirm, this, right? Quote Link to comment Share on other sites More sharing options...
0 GMRSJohn Posted 13 hours ago Author Report Share Posted 13 hours ago Ok so I put in the information. Uploaded it. Still don’t think I’m getting any repeaters unless I’m not doing something right. Which is highly likely. Quote Link to comment Share on other sites More sharing options...
0 Socalgmrs Posted 12 hours ago Report Share Posted 12 hours ago Are you close enough with the little uv5 to hit the repeaters? Do you hear any one in the repeater’s? Do you have line of sight? What antena are you running? How far from the repeaters are you? Quote Link to comment Share on other sites More sharing options...
0 GMRSJohn Posted 12 hours ago Author Report Share Posted 12 hours ago I hear a lot of people. The radio has no problem with picking up signals and range. They just can’t hear me. Quote Link to comment Share on other sites More sharing options...
0 Socalgmrs Posted 12 hours ago Report Share Posted 12 hours ago Again all the other questions. Remember the repeater is most likely up on a hill with 50w and a big antenna. How far away are you? Do you have line of sight? Just because you can hear the repeater well does not me you can reach it with any radio let alone a hand held. Quote Link to comment Share on other sites More sharing options...
0 OffRoaderX Posted 11 hours ago Report Share Posted 11 hours ago 58 minutes ago, GMRSJohn said: They just can’t hear me. Are THEY on a repeater? Do you have that specific repeater programmed into the radio with the correct tones? Are you on the correct channel for that specific repeater? AdmiralCochrane and SteveShannon 1 1 Quote Link to comment Share on other sites More sharing options...
GMRSJohn
Link to comment
13 answers to this question
