N type connector ID
OK rookie question.   I have this adapter on the back of my Vertex vxr-7000 repeater.   I plan to get new coax,  likely M&P ultraflex 10.  Is it better to remove the adapter and have N connections on both ends of the coax to minimize loss or at 30 - 50 foot coax length will it matter?
14 answers to this question
Yup.  I’d go N male on both ends of the coax.   Will it matter probably not but less connections is always better.
It’s always better to have fewer adapters, especially since N male connectors are easily available already mounted on coax.
Just now, VETCOMMS said:
Thanks.   I was looking at Gigaparts M&P but all I saw were PL-259 connections.  Much appreciated!
M&P certainly makes their excellent cables with N connectors, but Gigaparts is terribly under stocked right now. But you can order it direct from M&P and they’ll ship it directly to you.
I have good luck using DX Engineering 400MAX cables. And ABR Industries also makes good coax cables. I use ABR coax for my portable setups.
And don't overlook the Jet brand from R&L Electronics. I am using a few for jumper cables in the shack.
