WRUM460 Posted November 20, 2024 Report Posted November 20, 2024 My search for repeaters in the search box wont show me anything ? Quote
OffRoaderX Posted November 20, 2024 Report Posted November 20, 2024 (edited) EDIT: UPON REFLECTION I DECIDED IT WAS BEST TO JUST REMAIN QUIET. Edited November 20, 2024 by OffRoaderX I changed my mind. RayDiddio 1 Quote
WRUU653 Posted November 20, 2024 Report Posted November 20, 2024 3 minutes ago, WRUM460 said: My search for repeaters in the search box wont show me anything ? Are you typing in a location or using location near me? If the latter, it’s possible your browser isn’t set with permission to use your location. That’s just a guess. SteveShannon, RayDiddio and AdmiralCochrane 2 1 Quote
Guest Posted November 20, 2024 Report Posted November 20, 2024 Might want to try using the map. It’s much asker and give a clearer total picture of your surroundings. Quote
Billz Posted November 21, 2024 Report Posted November 21, 2024 I used the map to look at where repeaters are located near me. Quote
WRKC935 Posted November 21, 2024 Report Posted November 21, 2024 While there has been a significant increase in GMRS license holders and repeaters in recent years. Not every corner of the US has a GMRS repeater. There is always a possibility that you are having issues with what you are doing with the search, it might be that there are simply no repeaters in your area. If you are willing to give a basic location of where you are, one of use can take a look and see if there are any repeaters that you just aren't seeing or if you don't have any coverage in that area. RayDiddio and SteveShannon 1 1 Quote
808Beachbum Posted November 21, 2024 Report Posted November 21, 2024 19 hours ago, WRUM460 said: My search for repeaters in the search box wont show me anything ? Really? Based on your location of Bristol, Pennsylvania, there are two that show up. "Tullytown 675", and "Burlington1". Both indicate coverage over the Bristol area. Quote
SteveShannon Posted November 21, 2024 Report Posted November 21, 2024 20 hours ago, WRUM460 said: My search for repeaters in the search box wont show me anything ? When that happens to me I click on the Advanced Search Settings and I always discover that there’s something there from a previous search, such as a state filter, which results in an empty result. WRUU653 1 Quote
WRXB215 Posted November 21, 2024 Report Posted November 21, 2024 30 minutes ago, SteveShannon said: When that happens to me I click on the Advanced Search Settings and I always discover that there’s something there from a previous search, such as a state filter, which results in an empty result. Also, don't forget to try turning on "stale" repeaters. Just because the info hasn't been updated in a year or more doesn't mean the repeater is down or no longer exists. WRUU653 and SteveShannon 2 Quote
SteveShannon Posted November 21, 2024 Report Posted November 21, 2024 4 minutes ago, WRXB215 said: Also, don't forget to try turning on "stale" repeaters. Just because the info hasn't been updated in a year or more doesn't mean the repeater is down or no longer exists. Great reminder!! Thanks! WRUU653 1 Quote
808Beachbum Posted November 21, 2024 Report Posted November 21, 2024 Well, apparently the Search function under the "Repeaters" tab uses different data than the Search function on the actual Map, under the "Map" tab. I've never used the Search under the Repeaters tab until someone mentioned something about "advanced search". Quote
