I apologize if this question has been asked/answered -- I did some searching and wasn't able to find anything specific to this, yet I don't believe I'm the first person to encounter this.
TLDR; I can't transmit on a second similar frequency channel with or without a "privacy code"
I know "privacy code" usage isn't private. I'm using it as a general term for using DCS/CTCSS codes to reduce hearing unwanted signals.
Equipment: I have a TIDRADIO TD-H3 (HAM version) running in GMRS mode
The firmware version is GMRS_240817
I can and have programmed it on Odmaster or CHIRP
I can do some limited work on the HT itself
I just got it this week, so I'm still a little new (Jan. 15 2025)
Intent: My younger children have some FRS radios where I used FRS/GMRS Channel 1 plus a "privacy code" to (a) reduce some of the distraction from area GMRS/FRS users (b) potentially reduce the possibility that their ears might hear something inappropriate. I'd still like to be able to switch to a regular "privacy code"-free channel when I'm away.
I want to talk to communicate with them from my TD-H3.
Situation: I can't transmit out on higher of the TD-HD3's two channels if I have a mixture of privacy code and non-privacy code for the same frequency. The radio prevents transmitting on the higher channel of the same simplex frequency. Example: If I use GMRS freq. 1 and put the "privacy code" on HT radio channel 1. I then use a "privacy code" free GMRS freq. 1 on the HT radio's channel/slot 100. I can transmit out and be heard on the FRS radio when I use HT slot 1, but can't actually transmit (and hear a rejection tone) when I use the HT radios slot 100 on the same frequency. If I make HT slot 1 clear of codes and make HT slot 100 the same frequency as channel 1, but use a "privacy code", the radio blocked me from transmitting on slot 100.
I discovered this after several hours of troubleshooting and hand-wringing. It didn't matter whether I used DCS or CTCSS. I then tried using "privacy code" on the lower radio channel and put the privacy free* on the greater channel and saw I could use a privacy code successfully. What's a little weird is that I have a repeater setup with a CT tone and the radio will transmit fine.
I don't know if this is by design or a limitation of the TD-H3 and similar firmware. For all I know, it might be a general phenomenon of TIDRADIO products.
Comparison: I have a brand new pair of Baofeng 5RMs that I would like to see if they exhibit the same phenomenon, but there are issues with the programming over the cable preventing me from quickly programming them. Maybe I'll figure out how to program them on the keypad. Observation: I get the feeling that Baofeng and TIDRADIO are basically the same manufacturer but simply different brands.
Kind regards,
Jim
Woodleaf, NC USA
WSGP797
Edited by Imply4907 clarification of the "intent" section. Edit 2: improved title. Edit 3: Corrected typo in firmware version. Edit 4: standardized language from radio channel to radio slot and used slot 100 rather than 31
Imply4907
Good day!
Kind regards,
Jim
Edited by Imply4907Woodleaf, NC USA
WSGP797
42 answers to this question
