WRWU395 Posted January 19 Report Posted January 19 I have a pair of GM-15pro radios. one of them now has only very low volume,as if all the volume was turned down and will not increase. Any ides how to fix, or throw away? Quote
SteveShannon Posted January 19 Report Posted January 19 19 minutes ago, WRWU395 said: I have a pair of GM-15pro radios. one of them now has only very low volume,as if all the volume was turned down and will not increase. Any ides how to fix, or throw away? Do you hear full volume through an earphone or external speaker/microphone? Have you tried doing a factory reset? Quote
WRWU395 Posted January 19 Author Report Posted January 19 Neither headphones,nor , reset all cured the problem. Quote
WRWU395 Posted January 19 Author Report Posted January 19 The volume is also low on FM stations. Quote
SteveShannon Posted January 19 Report Posted January 19 Then I would recommend sending it in or replacing it unless you’re good at replacing surface mount components. AdmiralCochrane and WRXB215 2 Quote
