Guest ROD WSCF455 Posted February 7 Report Posted February 7 Good evening to all , I am really confused I am from Bound Brook area in New Jersey so i am very confused so in all reality I need a guide and directions because the towers around me are either not working private or dont have listings so yeah im so confused Quote
OffRoaderX Posted February 7 Report Posted February 7 What, exactly, are you confused about? What is it you are not able to do? FIND repeater? USE repeaters? Something else? RayDiddio, TrikeRadio and Hoppyjr 3 Quote
BoxCar Posted February 7 Report Posted February 7 13 hours ago, OffRoaderX said: What, exactly, are you confused about? Asking for help? Quote
Guest Info = Help Posted February 10 Report Posted February 10 As said by others, More info = more help. If you indeed are trying to connect to a repeater, and I interpret the map correctly, and I could be wrong, there should be a few large repeaters in your area. I see some are members only, so there won't be any input or out put tones provided until you become a member. That's just the way it is sometimes. As offroader X outlined please be really specific on what you want to do and the problems you are having doing it. In the mean time watch his youtube videos for some good tutorials. Perhaps someone from your area will chime in regarding repeaters. Best of Luck! Quote
TerriKennedy Posted February 12 Report Posted February 12 On 2/6/2025 at 7:15 PM, Guest ROD WSCF455 said: Good evening to all , I am really confused I am from Bound Brook area in New Jersey so i am very confused so in all reality I need a guide and directions because the towers around me are either not working private or dont have listings so yeah im so confused I'm only about 30 miles away from you, so if you're having trouble setting up a radio and it's one of the models I know, I could walk you through it. OTOH, if your question is about repeater access, they're likely too far away from me. If you can explain more clearly what you're having trouble with, I'll try to help. WRUU653 and SteveShannon 2 Quote
WRYS709 Posted February 13 Report Posted February 13 You might want to delay help until they are licensed and become a registered member of this forum. According to the FCC WSCF455 was licensed in April, 2024; why a guest? Quote
SteveShannon Posted February 13 Report Posted February 13 16 minutes ago, WRYS709 said: You might want to delay help until they are licensed and become a registered member of this forum. According to the FCC WSCF455 was licensed in April, 2024; why a guest? Why not? These aren’t nuclear secrets. WRUU653, AdmiralCochrane, WSHB846 and 3 others 5 1 Quote
Wscf455 Posted February 21 Report Posted February 21 On 2/10/2025 at 5:33 PM, Guest Info = Help said: As said by others, More info = more help. If you indeed are trying to connect to a repeater, and I interpret the map correctly, and I could be wrong, there should be a few large repeaters in your area. I see some are members only, so there won't be any input or out put tones provided until you become a member. That's just the way it is sometimes. As offroader X outlined please be really specific on what you want to do and the problems you are having doing it. In the mean time watch his youtube videos for some good tutorials. Perhaps someone from your area will chime in regarding repeaters. Best of Luck! On 2/7/2025 at 8:28 AM, BoxCar said: Asking for help? i got it thank you how you join a club Quote
Wscf455 Posted February 21 Report Posted February 21 So I finally understood what randy was saying on you tube until i got sick of him with confroculation so i figured the tones what i dont understand is i only hear the 2 regular guys Quote
OffRoaderX Posted February 22 Report Posted February 22 2 hours ago, Wscf455 said: So I finally understood what randy was saying on you tube until i got sick of him with confroculation It's kONPHUKULATION .. Get it right. Quote
SteveShannon Posted February 22 Report Posted February 22 3 hours ago, Wscf455 said: so i figured the tones what i dont understand is i only hear the 2 regular guys I don’t understand your question. Are you looking for irregular guys? WRUU653, Hoppyjr and TerriKennedy 1 2 Quote
Hoppyjr Posted February 22 Report Posted February 22 I don’t understand your question. Are you looking for irregular guys?Pro Tip: always check for the Adam’s Apple. Quote
SteveShannon Posted February 22 Report Posted February 22 1 hour ago, Hoppyjr said: Pro Tip: always check for the Adam’s Apple. I was thinking of the kind of regularity that bran flakes help, but okay. FishinGary and WRUU653 2 Quote
TDM827 Posted February 25 Report Posted February 25 On 2/21/2025 at 3:46 PM, Wscf455 said: i got it thank you how you join a club Google search for clubs in your area, you can also check facebook. If I remember correctly I found and joined Midwest GMRS via facebook. Quote
