9 answers to this question
Another option if you want a custom length cable is ABR Industries. Yes they will cost a little more but they are excellent cables. You won't go wrong with cables from ABR Ind., Messi and Paoloni, Times Microwave, or DX Engineering. Another good source that I have only used for short jumpers is the Jet brand from R&L Electronics.
You will be fine as long as you stick with LMR400 or a quality equivalent.  Avoid the cheap stuff from Amazon and eBay.
The Comet CA-712EFC is a very popular antenna that works well. It is long at around 10 ft. The Comet CA-GMRS is another good antenna if you need something shorter. There are other brands that will be suggested.
The DX Engineering Max400 is an LMR equivalent and good coax for less cost. Search around for LMR400 equivalent coax. I would just stay away from the cheap stuff on Amazon.
Lm400 is best bang for the buck unless you have a whole bunch of money.  I run 50w radio 40’ of lm400 and a comet 9nc that was upgraded from a 712efc.   Crystal clear  60miles from the high desert of California to Huntington beach and  170miles to Las Vegas the next state over.
Wow!!! Thats Cool!!! Thanks for the respond.
I'll look into it> Thanks for responding.
4 hours ago, WSHE531 said:
I’m new at this and was wanting some of your thought on choosing cable and a antenna for base unit.
You can shop around for deals and many of the YT people have codes you can use for discounts. I ended up with the Comet CA-712EFC 460-470MHz 9 dBi Gain base antenna, and I used the premade Messi & Paoloni hyperflex 13 premium .500" coax w/PL259 connectors. I also had to get an N male to UHF female adapter and silicone seal shrink tube too. With all the discount codes I found, and sales they had going on I was able to get everything for less then $250 including shipping.
Nice, I'll check it out thanks for responding.
