Having trouble with KPG-46 USB Programming Cable
Any ideas how I can solve my programming cable issue? Brand new win11 computer to a Kenwood TK-880. The computer says the cable is good, however when i try to load or receive data to or from the radio I get an alarm stating to check cable connection and/or com port settings. I'm at a loss.
open device manager, see what port the cable is. I can't remember if KPG-49 limited which com port you can use, you may have to reassign the cable to  a port 1 thru 4. You also have to set the com port in the software.
Thank you. I do have the port settings the same. I even tried changing the port number. Still no success.
Good heavens. Latest OS and we're assigning ports like it's the 80's. Next someone will bring up serial ports and IRQ's
Unfortunately, most of the computer software creates virtual serial ports and require the user to determine which ports are being used.
I guess my biggest surprise is that they are USB.  You know "UNIVERSAL" Serial Bus".  That crazy idea that port and IRQ selection would be a thing of the past.
Not when the radios themselves are 20+ years old, and were first programmed with a true serial port.
I can't remember if the TK-880 needed booted up in a programming mode or not. I guess check the manual to see? That may only be for firmware updates though.
Oh, I understand. But out of all the radios I have only one doesn’t create a virtual serial port.
But I never have to do anything with IRQ. Sometimes I have to set baud rate. Usually, I have to set the port so the software knows, but not always.
The FTDI or Prolific chips that are in programming cables emulate serial connections. So yes when you plug in a USB programming cable it does create a virtual serial port. Windows likes to default to a baud rate of 9600 and some radios will use a different baud rate.
I haven't had to mess with the IRQ settings but I did have to change the baud rates for a few different radios. Changing the baud rate is mostly for connecting HF radios to a computer though some mobile VHF/UHF radios do use a baud rate that is different from the default 9600. I have not had to mess with the baud rate when connecting any of my hand held radios to a computer.
I also am having issues with the cable . I have a programming cable from a TM-481A and from what I understand is the same cable for the 880. But I’m also told that I need a cable driver for it to work ? I am running a mini computer can’t seem to get the software to read my 880 . Any and all help would be greatly appreciated
Do you have the FTDI chip programming cable or the Prolific cable. You need to make sure that you have the appropriate driver for the type of cable you using. And you do need to select the correct port in the CPS. Usually, the correct port will have a white background and the others are grayed out. Select the port that is white
I did figure out the port part but as far as the cable goes I don’t know which one I have
5 hours ago, WRYZ926 said:
Open up Device Manager and then click on Ports. FTDI chips will say Silicon Labs since that is who created the drivers for the FTDI chips
Thanks for the help , when I get home from work tonight I’ll give that a try , greatly appreciated!!!
12 hours ago, nokones said:
And make sure that you have Com Port 6 selected in the CPS.
Ugh ……… can’t get it to work . It says PL2303TA doesn’t support windows 11 or later
4 minutes ago, Nfranks97 said:
I have a cable from a Kenwood TM-481a iM gonna try to order one like you have
If your cable is for the TM-481a and is good working order, it should work on the TK-880. Depending on how the cable built, it will require the appropriate driver. Just make sure that the driver is compatible with Windows 11. If you're not sure if you need the Prolific or the FTDI driver, load both drivers on your computer and set the port selection according to the Device Manager. With the radio connected to the cable, pull the cable connector in and out of the computer while viewing the Device Manager and that may indicate the port the computer wants to use and set the port selection in the CPS accordingly.
If the cable is a genuine Kenwood cable or built by Blue Max 49ers, you should be good to go. If it is built by some unknown provider that sells cheap Pandaland stuff from a business that is not dedicated to or does not specialized in only radio electronics, I would round-file the cable and get a quality built cable before you brick the radio permanently.
I don't believe that the old TK-880 software is capable of using anything other than Comm port 1 through 4.  In your Kenwood software, what Comm port are you assigning the software to use?
What does your Device Manager say is the port assigned to your USB programming cable?
When your programming cable is connected to the computer, your computer pick which comm port it wants to use. In the CPS, you have to tell the CPS which comm port the computer wants to use by going to the Set Up Page and click on Communications Port. You will notice that one of the 20 comm ports in the CPS is the only one that you can select so you need to select that port and click OK.
Now, you can either read that codeplug or write to that codeplug. If any alerts come up just push pass it to write to the radio.
On 4/5/2025 at 9:23 AM, Nfranks97 said:
I think I figured out the port stuff but it’s not reading the radio , it keeps saying check communications port settings
This is why I started this thread. Exact problem I am having...
