My enabling Busy Channel Lock (BUSYLOCK) on my radios seemed like a simple courtesy to reduce the chance of accidentally stepping on others.
Before enabling it I did receive good advice that BUSYLOCK can disable a radio's ability to transmit in noisy or congested environments. I thought this risk acceptable risk since BUSYLOCK is easily disabled.
What I didn't anticipate was the effect of BUSYLOCK had on my participation in repeater based events.
The owner of my favorite repeater hosts a weekly event were participants start by checking-in. With a list of participates complete, he calls upon each to respond to the week's topic. It provides lighthearted discussion and opportunity to check out equipment.
After enabling BUSYLOCK I found my attempts to check-in resulted in the BUSYLOCK error tone, even when I was sure the previous participant was done and no one else was attempting to talk in that moment.
In my ignorance I did not consider the repeater's use of carrier delay (hang-in timer) on BUSYLOCK.
With the repeater's carrier delay longer than it takes for participants, including the host, to realize the current speaker is done and there is an opportunity to talk I was effectively blocked.
Now slightly less ignorant, I have disabled BUSYLOCK on my radios unless I find some future special case use.
WRNU354
Does anyone have use for BUSYLOCK?
17 answers to this question
