WRYZ926 Posted June 13 Report Posted June 13 3 hours ago, WRTC928 said: I'm puzzled about why I get different power readings with different antennas, though. If someone can explain it, please do. I'm still learning. You are seeing loss from the coax and/or the antenna. Using quality coax and a good antenna with some gain will help overcome any loss. A dummy load will show a perfect match of 50 ohms, there won't be any loss with the dummy load. @OffRoaderX was that a simple response? I know I have a ways to go to catch up to @SteveShannon OffRoaderX, WRHS218 and SteveShannon 2 1 Quote
OffRoaderX Posted June 13 Report Posted June 13 1 minute ago, WRYZ926 said: @OffRoaderX was that a simple response less than 10 paragraphs and no big technical-sounding words, so you did good! WRHS218, WRYZ926 and SteveShannon 2 1 Quote
WRYZ926 Posted June 13 Report Posted June 13 I still have a ways to go before I reach @SteveShannon status WRDJ205 and SteveShannon 1 1 Quote
SteveShannon Posted June 13 Report Posted June 13 1 minute ago, WRYZ926 said: I still have a ways to go before I reach @SteveShannon status I have no idea why anyone would want to. WRYZ926 1 Quote
LeoG Posted June 13 Report Posted June 13 1 hour ago, OffRoaderX said: less than 10 paragraphs and no big technical-sounding words, so you did good! Radio Dork? Quote
WRTC928 Posted June 13 Author Report Posted June 13 9 hours ago, WRYZ926 said: You are seeing loss from the coax and/or the antenna. Using quality coax and a good antenna with some gain will help overcome any loss. A dummy load will show a perfect match of 50 ohms, there won't be any loss with the dummy load. @OffRoaderX was that a simple response? I know I have a ways to go to catch up to @SteveShannon I hadn't thought about loss in the cable causing an artificially high power reading, but now that you mention it...I guess it could. Thanks. None of the antennas I tested are likely to be the one I ultimately end up using, and I have 50' of LMR400 Ultraflex to feed it. There's always going to be some loss. All we can do is keep it to a minimum. As far as I know, anything you can easily coil up and carry is going to have quite a bit of loss at 462 MHz. Quote
WRYZ926 Posted June 13 Report Posted June 13 1 hour ago, WRTC928 said: I hadn't thought about loss in the cable causing an artificially high power reading, but now that you mention it...I guess it could. Seeing higher return power would be due to the antenna having a high SWR as it is reflecting power back down the coax. That's why a dummy load should be used to test power output as the dummy load is a perfect 50 ohm match and should show a 1:1 SWR. That takes out coax loss and reflected power returning down the cable. SteveShannon 1 Quote
SteveShannon Posted June 13 Report Posted June 13 1 hour ago, WRTC928 said: I hadn't thought about loss in the cable causing an artificially high power reading, but now that you mention it...I guess it could. Thanks. None of the antennas I tested are likely to be the one I ultimately end up using, and I have 50' of LMR400 Ultraflex to feed it. There's always going to be some loss. All we can do is keep it to a minimum. As far as I know, anything you can easily coil up and carry is going to have quite a bit of loss at 462 MHz. It seems I have a reputation to either change or uphold. Here are the ten paragraphs and big technical sounding words. Sorry. Lossy cable will always make your SWR appear artificially low when measured at the radio. If lossy cable is attenuating your forward power there will be less power that reaches the antenna and then whatever power is reflected by an imperfect impedance match is attenuated before if gets back to the radio. So an RF power meter/SWR meter placed at the radio will see erroneously low reflected power, resulting in an erroneous calculation of forward power and an erroneously low calculation of SWR. If your radio has an ALC circuit, it limits output power as SWR increases and allows greater power if the SWR appears low. Where are you measuring the power? At the radio or at the antenna? If you want an accurate reading of the SWR of the antenna, you must read at the antenna feed point. If you want to see how much power is reaching the antenna, measure it at the antenna feed point. If you want to see how much power your radio is emitting, measure at the radio. Sometimes it’s very helpful to measure power at both places at the same time to see the difference. How are you measuring it? Some RF power meters are simply better than others. Expensive ones are calibrated to a standard for a specific frequency and power range. Inexpensive ones may lose accuracy at different frequencies and power levels which can make things appear better or worse than they really are. Are all measurements at the same transmit frequency? Our radios often (always?) have a range of power output levels that change at different frequencies. Quote
LeoG Posted June 13 Report Posted June 13 That's only 4 paragraphs... WRYZ926 and SteveShannon 2 Quote
SteveShannon Posted June 13 Report Posted June 13 1 hour ago, LeoG said: That's only 4 paragraphs... I’m bad at counting also. But at least I use an occasional period and paragraph breaks. Every so often I see a post that is one long run-on free association. Those make my head hurt. Quote
WSHH887 Posted June 13 Report Posted June 13 2 hours ago, SteveShannon said: I’m bad at counting also. But at least I use an occasional period and paragraph breaks. Every so often I see a post that is one long run-on free association. Those make my head hurt. Welcome to the new world of written communication brought to you by young people with limited education. GrouserPad 1 Quote
WSIK532 Posted June 21 Report Posted June 21 On 4/20/2025 at 10:10 PM, OffRoaderX said: There is a setting for the kerchunk.. "STE" i think? I would double check for you but both of mine are boxed back up and ready to be given away to lucky viewers. Wait what? you doing a giveaway... Cool! Quote
WRTC928 Posted June 21 Author Report Posted June 21 13 hours ago, WSIK532 said: Wait what? you doing a giveaway... Cool! 12 hours ago, LeoG said: Ya, 2 months ago. Too bad you missed it. It's a pretty good little repeater. WSIK532 1 Quote
OffRoaderX Posted June 21 Report Posted June 21 13 hours ago, WSIK532 said: Wait what? you doing a giveaway... Cool! As a very wise-man says in my videos all the time: You snooze, you miss out. WSIK532 1 Quote
WSIK532 Posted June 22 Report Posted June 22 6 hours ago, WRTC928 said: Too bad you missed it. It's a pretty good little repeater. lol... its ok, congrats to the winner. Quote
GreggInFL Posted June 23 Report Posted June 23 I guess this means I didn't win it. Well, poop. SteveShannon 1 Quote
WRTC928 Posted June 23 Author Report Posted June 23 5 hours ago, GreggInFL said: I guess this means I didn't win it. Well, poop. The only thing I've ever won in my life is a coffee mug from the 11th Ohio Volunteer Cavalry YouTube channel. I was the first to correctly answer a cavalry history question during a livestream. It ain't much, but I won it. I'd rather win a GMRS repeater, though. Quote
WRUW493 Posted June 25 Report Posted June 25 I wonder how good the RX sensitivity is on the 97L. I read somewhere that it's spec'd at 0.35uV, compared to 0.20uV for the 97S. Any one know if this is correct? ps: I hope not as 0.35uV is not very good for a repeater. It would have a hard time hearing the HT's when far out but the 20+W TX would get to them well. thanks for any info. Quote
LeoG Posted June 25 Report Posted June 25 Not going to be the receiver sensitivity that'll be the issue. The wideband duplexer is what is really going to limit the sensitivity. SteveShannon 1 Quote
WRUW493 Posted June 25 Report Posted June 25 True. Well OK, but the RX sensitivity at the antenna connector is what matters. Do we know anything about how good or not that is? ps: yes IM, Adjacent Channel etc matter in some installations too Quote
LeoG Posted June 25 Report Posted June 25 Well I am actually going to find that out tonight. I have a Btech 50w repeater and it has a wideband duplexer in it and soon I will be changing that out for a single channel tuned duplexer. The receive should be more sensitive. The receiver will be the same, but the desense should be much less with the >-85db vs the >-45db of the wideband duplexer SteveShannon 1 Quote
WRUW493 Posted June 26 Report Posted June 26 Sounds good LeoG. I fear that Retevis made a mistake when they upped the TX power. They either didn't have enough isolation in the duplexer, or choose to allow more insertion loss to get a high isolation. Either way is makes for poorer RX sens. I hope I'd dead wrong though and it's good. According to the spec sheet, the 97S is 0.20uV, which comes out to -121dBm. Many years ago when I worked on a project that had a full duplex radio I modified it (in a kludgy way) with a 1dB NF preamp and custom bandpass filter to protect the low NF preamp. The resultant RX sensitivity was about -123dBm, which is as low as you can go in the real world on a 25KHz channel BW. So the -121 of the RT97S is pretty darn good for a "mere" consumer grade repeater. SteveShannon 1 Quote
LeoG Posted June 26 Report Posted June 26 Ya, I have one of those 97S repeaters. More of a bug out repeater. SteveShannon 1 Quote
