WRUE951 reacted to an answer to a question: Bursts of noise on channel 15
WSFH440 reacted to an answer to a question: Radioddity db20-g conection to repeaters
Utilizing GMRS vs Ham repeaters for a newbie!
UncleYoda replied to WSJF256's topic in General Discussion
That still doesn't follow the rules unless it is a GMRS approved radio, which should have the repeater channels already there. His given model number doesn't match any that I know of. -
SteveShannon reacted to an answer to a question: Radioddity db20-g conection to repeaters
Ability to add text notes to our profile (in the repeater section not the forum).
amaff replied to WSFH440's question in Technical Discussion
#4 on this post covers manually entering a repeater channel from the face of the radio: The one thing it doesn't say is that once you go to put in your tones you'll have to hit the MON button to cycle between OFF / CTS / DTS options -
amaff started following Radioddity db20-g conection to repeaters
Are you running it unlocked, or in GMRS mode? If in GMRS mode, are you using 1 of the pre-programmed repeater channels? Also, Menu 6 is Step size, not repeater offset. Step size is, when you're in VFO mode, the smallest increment of frequency change when tuning or scanning. I will say that programming the DB20-G on the face is...pretty annoying. It's still a bit clunky but a heck of a lot easier with the programming software (EDIT: I forgot this radio's in Chirp now, which helps a lot) -
I'm having an issue with radioddity db20-g. I have other radios I program the repeater in and don't have a problem. When I use the radioddity I don't connect to the repeater. Only talking simplex. I have the tone plugged in correctly. The repeater owner said he could hear me simplex but I was not programmed correctly for duplex. He said my tone is correct otherwise he wouldn't hear me. I have entered several "names" of repeaters in my radio. #6 program on my radio is for offset step and is only available in frequency mode. #12 program on my radio Channel name is only available in channel mode. What am I missing?
@UncleYoda thanks for pointing this out. Some people have issues with the ARRL but I appreciate their diligence on matters like this. As they pointed out, AST is trying to grab something they have no legitimate right to. Amazing how some people think that just because they want something, they automatically have a right to it
WRXB215 reacted to a post in a topic: ARRL files comments opposing corporate takeover of 430MHz section of 70cm band
Good reason not to spend money in such countries.
They want to ensure if you wind up shipwrecked or overboard, you have zero chance of getting through it unless they provide. Exactly why I will never go on a cruise.
Raybestos reacted to a post in a topic: Do you talk to the --- unlicensed?
SteveShannon reacted to a post in a topic: Utilizing GMRS vs Ham repeaters for a newbie!
SteveShannon reacted to a post in a topic: GMRS for Motorsport
Cruise line publish lists of what is permitted or prohibited. For example Royal Caribbean has these rules regarding ham radio and two way radios: HAM Radios or other transmitting devices are strictly prohibited due to potential interference with the ship's onboard communication systems. This does not include baby monitors, which are permitted. Guests are allowed to have two-way radios, more commonly know as walkie-talkies, for onboard personal communications. Basic specifications are as follows: Up to 10-mile coverage range, Up to 5 watts power, Internal Voice, Operated Transmission, No external mounting antenna. https://www.royalcaribbean.com/faq/questions/prohibited-items-onboard-policy
Interesting read however this article is from over twenty years ago and I can’t help wonder what changes may or may not exist now to the laws there. It’s noteworthy that they now use encryption for police communications and such which has been implemented after this was written.
Yep, same. For $125, I figured it was worth the experiment
In this sort of application, there is something to be said for commercial radios. It was mentioned 'did I just bump the channel knob' and that's a thing if you have one. Personally I would be looking at a CDM750 for this specific application and dealing with the 4 total channels that can be programmed in it. I realize that as you travel track to track and races to race that others might be on the same channel and you might need to move. But 4 channels should actually be enough to have something usable for the event. Of course the high dollar race teams all have a licensed frequency, so they don't tend to have issues with others interfering with their comms. The other thing with a CDM750 or similar radio is the quality of construction. Race cars are not luxury sports sedans with leather and adjustable 'comfort systems'. They beat you and vibrate and generally are a rough ride. I remember the difference in my Camaro just building in the cage and tying the subframes (unibody 2nd gen). Even with the mostly stock suspension system the car suddenly rode more like a log wagon and less like a pony car. And the solid motor mounts didn't help much either. CDM750's are dirt cheap since they are only 4 channels. No one wants them, they all want the CDM1250s and 1550s. I would be interested to hear how that radio holds up in a purpose built race car over time.
WRTC928 replied to WSJF256's topic in General Discussion
Yes, if both radios are programmed correctly, that's how it should it work. The repeater picks up the signal from one HT and retransmits ("repeats") it with more power from a more advantageous position. Typically, a repeater is situated in an elevated position, meaning it can receive and transmit more effectively than a radio at ground level. If there are GMRS repeaters open to public use within range, that would give you the communication capability you want. That's the primary reason I put up a repeater. I have a couple of buddies living to the east of me where I can reach their HTs with a base unit and tall antenna, but not with an HT. The repeater gives us HT-to-HT capability over a wide area. GMRS repeaters are privately owned, and some owners allow public use while others don't. As a general rule, if the repeater is listed in public databases with the CTCSS/DTCS code, it's available for public use. You're not permitted to use a repeater (or simplex, for that matter) on any service for which you do not have the appropriate license. Some repeater owners are pretty casual about the license requirement, while others are strict, but FCC regulations do require that you be licensed for the frequencies you use. -
SteveShannon reacted to an answer to a question: Bursts of noise on channel 15
The nearest hospital is a couple of miles away, and it doesn't have an MRI machine. Small town Oklahoma. Would I pick that up despite having a DCS code set? Obviously, there's something that can cause noise on that frequency regardless of the code, but I'm puzzled about what it could be.
I might do that if it goes on for a long time or becomes more frequent. TBH, my primary concern was that my repeater might be causing it. Now that I know it isn't my fault, it's primarily a matter of intellectual curiosity.
That was my first thought. However, in order to be heard on my repeater channel, wouldn't it have to open the squelch? I have a DCS receive code on my HT, but I hear it anyway. Could there be some sort of electronic signal that can be heard despite the DCS code?
Actually, the receive code I'm using is DCS. I typically have one side of my base or mobile radio scanning, and so far, I've only picked it up on 15. Because of how random it is, it's possible I've just missed it, but that seems unlikely. Nevertheless, I'll set a radio to GMRS 1 and see if I pick it up there too. I don't remember if I've heard it when I'm away from the house. I'll try to find out.
GreggInFL replied to WSJF256's topic in General Discussion
Sure, just use the GMRS repeater frequency. And welcome to GMRS! -
jwilkers started following Utilizing GMRS vs Ham repeaters for a newbie!
jwilkers replied to WSJF256's topic in General Discussion
You cannot use ham repeaters without a ham license, period. You must reprogram the radio to frequencies you are legally licensed to use. Sent from my SM-S911U1 using Tapatalk -
I heard that but have been skeptical. Thanks for the documentation. Wow.
Hi everyone, New to world of gmrs. Have a Uv5r+. it came programmed with ~50 nearest ham repeaters. I understand simplex comms, but my question is if a buddy has the exact same radio/programmed the same way, wouldn’t we be able to communicate via one of the local repeaters we are both in range of that’s programmed in our radios? So if he goes 1 mile away and we lose connectivity with one another, shouldn’t we be able to tune into the same local repeater and now communicate? We do not have Ham licenses but do have GMRS. Should we be finding the nearest GMRS repeater and communicating through it? trying to understand the difference. Thank you!
WSJF256 joined the community
Schmidty570 joined the community
Instead of a receive tone engaged, try setting a receive DCS code in your radio to see if it still receives it. Noise can include several CTCSS RX tones but might not so easily mimic a DCS code. Have you tried listening to other channels that are adjacent to channel 15? Channel 1 is the closest of the GMRS frequencies at 462.5625 MHz. Channel 16 is at 462.575 MHz and then channel 2 is 462.5875 MHz. This might help you see how broad the bandwidth of the noise is. If it’s truly random noise it might be pretty broad, but if it’s a digital signal it should be fairly narrow. A spectrum analyzer like @WRUE951 suggested would be helpful also. Does it still happen away from your house or if your main breaker is open? Try recording the audio for a few seconds and post it to this thread.
Live near a hospital? I got an MRI a couple of years ago, and as I approached the facility and drove away from it, channel 17 was picking up the exact sound I was hearing while inside the MRI tunnel. Otherwise I'd guess DMR or some other digital signal. My SDR is particularly good at letting DMR on nearby frequencies intrude into what it picks up in the GMRS band.
This is what i was going to say, but it does not explain why/how its opening his squelch/getting past the RX tone he has set.
Sounds like you are picking up digital transmissions from nearby source. I.e.: DMR Activity: You might be hearing Digital Mobile Radio (DMR) signals, which sound like a buzz or "machine gun" noise on an analog radio. Other Digital Signals: There are various other digital radio signals that can bleed over or interfere with GMRS frequencies and could be generated from nearby public safety digital radios. I.e police dept. Utility Use: Some digital signals are telemetry data or other utility uses that might be operating on or near GMRS frequencie you might want to invest in a Tiny Spectrum Analyzer which will help you with frequency and pinpoint the source. Lots of you tube videos out there for Tiny Spectrum Analyzer
