WRHS218 reacted to a post in a topic: Hilarious ad on facebook
I can’t speak for the Admiral, but to me choosing “Scan for Tones” from the menu seems automatic. I don’t know how much more automatic it could be.
Unitforty started following rdunajewski
SteveShannon reacted to an answer to a question: WRYI628
RoadApple reacted to a post in a topic: Long, Long Ago
Can't argue with an Admiral!
WRDU469 changed their profile photo
For GMRS... 100% agree.
What would generate a Morse code ident on channel 6?
TrikeRadio replied to WSCB609's question in Technical Discussion
CW - "Continuous Wave" - Basically... Morse code -
I get those all the time, I usually just "X" them out.
I was joking with the digital mode thing since they said "off-grid communications" (although Rapid Consulting's "nationwide radio" uses LTE which does feel like cheating), but on the topic - I've talked to a couple of local hams on a club repeater and they were all about it. It's not their main thing, but they had lots of recommendations if I ever wanted to get into it. Seems like there's quite a few Fusion repeaters around here but they also told me I could just set up a Pi Star hotspot and run whatever I wanted.
Bogieboy01 reacted to an answer to a question: What would generate a Morse code ident on channel 6?
WRUE951 replied to WSCB609's question in Technical Discussion
WRUE951 reacted to an answer to a question: What would generate a Morse code ident on channel 6?
I agree, but I don't see another way to remain within GMRS, unless you use two antennas and mount them like a dipole and only use 1/2W. I have a trunked P25 P1 "site" in my living room where the CC is 0.05MHz below the VC, RX antennas are pointed up, and TX antennas are left and right away from each other. Works well, but it's only putting out 0.1W. In theory, its a $7+M idea that would likely just become space junk before it is used.
Finding something that is going to be more than 5-6m/18-20 feet tall at a decent price is gong to be a challenge. Giga Parts has a tripod with 18 ft telescoping pole for $199. https://www.gigaparts.com/intellitron-am-2509ex-18-ft-telescopic-fiberglass-mast-with-tripod-stand.html
I'm a member there as well, and I sometimes get a little salty when people do that. I tell them to be Elmer, not Mr. Magoo. I do get good information sometimes, but I often have to sift through some trash. With regard to the Linux forums, the Ubuntu forum is usually helpful. I mostly avoid the others.
WRTC928 reacted to a post in a topic: What did I do wrong?
Cue the "that's not real radio" SadHam comments!
An oldie but a goodie. That one's been hammered to death by the Hams, both Happy and Sad over the last couple of years. Yeah, with EchoLink or DMR/C4FM, etc., et al, I can talk thousands of miles on my handheld. But I prefer the old school nothing between me and the other guy than the ether...
MarkInTampa replied to WSCB609's question in Technical Discussion
You are around 4 miles from one of the strongest repeaters in the area on 462.675Mhz with a 50 mile radius. I used to be able to hit it from Pensacola on occasion. Channel 6 is only 12.5kHz away (462.6875Mhz). If the repeater is running wide band, running slightly off frequency, your receive is off or sensitivity/selectivity sucks, etc.. it could sneak through. Is the id the same as the repeater on 462.675? -
why would I want to get any of these? more relevantly, what's it to you? you work for BTWR or just a fan of that store? speaking of the KG-935G - BTWR did a botched job on its NOAA channel, so they later release the KG-935Plus, but not as an exchange, but an full price upgrade. I know, I have both of these radios clearly, BTWR, and you, apparently, think that they are a monopoly. They ain't! But if a lot of their customer base does indeed believe that they are, yet another solid reason for me to go elsewhere.
TrikeRadio reacted to a post in a topic: zello app linking
Will have to look at that when I can get on a PC. It may be the version that only works with a paid account, or they may have put the free one back since I last looked (been some months). not that it matters much with them killing the pc version off later this month.
No, but I will go to vendors who try to help even with a radio is out of guarantee. I have had good experiences so far with BetterSafeRadio and their latest KG-UV9GX+ looks rather sexy (see here: https://bettersaferadio.com/wouxun-kg-uv9gx-plus-gmrs-radio-shtf-scanner). And there are other vendors and distributors out there. There are always options even if BTWR think that they are irreplaceable
Davichko5650 replied to WSCB609's question in Technical Discussion
Or.... Both kinds of Music, Country and Western. -
When my old club put a repeater up, it cost over $7M. I doubt we would pull that kind of money together on crowd-fund... but it's fun to joke about. I wouldn't put a mobile duplexer in orbit. That would be a disaster waiting to happen.
OffRoaderX replied to WSCB609's question in Technical Discussion
Radio-Dork term for Morse-Code. -
WSCB609 replied to WSCB609's question in Technical Discussion
Yep, same thing, that could be it. (What is CW?) -
Can't, it's arbitrary, never at a set time and lasts about 3 seconds . -
If I recall correctly, you have to do it in the software.
