  2. i think everyone should start using Waveguide
  3. I like the stealth approach, perfect for Jeeps ets.. For the price, hard to beat.. I like the Bluetooth programing, wish more radio manufacturers would do this.
  4. Actually, the most used 'tool' i use.. Wished it worked on allegories. Hot Damn-it
  5. If your coax is good I would cut both connectors off and install quality new ones, preferably N connectors. Professionally installed connectors are the worst for quality and reliability. Only premade cables I would use that had "Professionally installed" connectors would be Heliax or RFS hardline.
  6. Works fine with the Firefox browser.
  7. Today
  8. You really don't want to get bit by the high voltage from a tube amplifier, it will wake you up. You youngsters missed the good old days of flyback transformers connected to CRT, they hold their voltage for a long time after being de energized.
  9. @WRXB215 yes, I tried swapping the "tx" and "rx" even, all combinations. I returned them and am looking for a higher wattage HT.
  10. lots of reading and coordinating so your repeater doesn't bleed onto another frequency or step on someone else's toes. I think it would be cool to get a few repeaters up and down the 24 corridor. obviously not linked but just to be able to turn a dial and hop onto the next repeater.
  11. Are you that guy that’s always hollering out “Breaker Breaker, Can You Give me a radio check” all the time? You need to lighten up and say something different, You sound like a broken record.
  12. Ill leave that version to the guy/gal who calls himself a queen.
  13. I need my radios to actually work.
  14. Does this model last longer than the 50V2 before crapping out?
  15. 1/2" Heliax if you can afford it. Otherwise LMR400 will work even though it is not optimal for repeater use. Here are the losses for LMR400 and 1/2" Heliax for a 50 foot run on 462.600 using 50 watts out and antenna with 6 dBd of gain: Power loss per 100 feet LMR400 - 48% 1/2" Heliax - 30% ERP -effective radiating power LMR400 - 143 watts 1/2" Heliax - 166 watts You will not see 50 watts out of the repeater due to the duplexer. Most will output 25 to 35 watts. Here is the numbers for 35 watts out. EPR LMR400 - 86 watts 1/2" Heliax - 99 watts Those numbers are from using the kv5r.com coax loss calculator. @WSFF627 is correct when he talks about receive signal strength. You have to keep that in mind too. You will be okay with either LMR400 or 1/2" Heliax. Go with what fits your budget. Don't skimp on any of the components such as coax fittings, etc.
  16. I was able to log to both. It's always in and out. You can login on minute and the next page times out , refresh and it comes up. Click something else and it times out.
  17. He will only get a Midland if they make a pink Barbie or purple Barney version. Otherwise he will give use 1009+ reasons why one should just throw any Midland or Wouxun radio into the trash.
  18. LMR600 is more expensive ($2.69/ft) than 1/2" Heliax ($1.99/ft) and has greater loss. It has the advantage of being more flexible. (antenna farm prices) https://theantennafarm.com/images/specs/34/lmr-600-coax-cables-datasheet.pdf https://theantennafarm.com/images/specs/36/ldf4-50a-product-specifications.pdf The fittings for both run about the same although the LMR has a wider variation.
  19. I never messed with voltage above 480 three phase and I did not want to mess with higher voltages. KV is nothing to mess with. I won't get near a high power AM/FM radio station tower either. I also would refuse to use any type of welder outside in the rain for the same reasons. I had a 1st Lieutenant that wanted one my soldiers to stand inside a M113 engine bay and well the engine mount in the rain. The 1st Lt tried pulling rank but he forgot that the lead maintenance soldier was always in charge while working on vehicles. I politely and tactfully told hime that he was an ID10T and my soldiers would not weld in the rain.
  20. My KGXS20 will set off my neighbors motion detector light on a certain repeater channel. My H3 can activate my headlamp, my Fein Vacuum with the tool activation. It has turned on my stove when I am very close to it, but you need to push the 2nd button to make it turn on. RF energy can do strange things to unshielded equipment. I've never had my set off a GFCI though.
  21. LMR 400-600 will work just fine for distance less than 150', of course if you have some decent height on your antenna. We used Helix on super long runs for our UHF radios at work on antennas at the upper portion of a 300' tower. From 150' down we used 600 and so did everyone else leasing space on the tower from mid point down.
  22. As lots have mentioned here Heliax is the ideal choice. However you need to decide how much you want to spend. LMR400 is cheapest, LMR600 is more expensive but loss wise more comparable to 1/2 Heliax. For your length the dB loss doesn't justify the cost of 7/8 Heliax in my opinion. Yes the LRM types risk noise in full duplex operation, however that's more prevalent in wattages much higher than 50 watts and when there is a bunch of cable flex. I ran a test on a 100 watt 70cm HAM repeater for a while on 65 feet of LMR600 and didn't see a noise issue. Yes 400 will work but is not the best choice due to higher loss. Everyone thinks about TX and power out loss, but not many talk about RX loss, and a pre-amp cant do something for what never makes it to it. In high RF environments or with poor filtering, or a combination of both, they can do more harm than good. If your going to try one, get if from AdvancedReceiver.com I have several of them, they work great, and if you have a service monitor and the knowledge, can adjust them. Large Heliax is the best performing choice, and the most expensive, the connectors alone are $35 each. LMR600 is a good economical and good performing choice. Its actually in service in a lot of commercial setups on short runs, so is LMR400. But you wont find either going up a commercial tower due to loss and the noise issue at high wattage. Andrews and Times Microwave also offer grounding kits for LMR600. I recommend grounding the cable shield as well as a good quality (not a cheap amazon) lightning arrestor. A good one will run you $100 or so. Check repeaterbuilder.com It has lots of good info and a copy of the Motorola site standards, which you may find very helpful. I own and operate a GMRS repeater with a 60 mile radius as well as a 70cm DMR HAM repeater that can go farther (both have site elevation to their advantage, they are high). I've also put together other large footprint repeaters at commercial sites.
  23. Do they, Are they?? going to do a HAM ver of this radio?
  24. A Midland will fit your bill just fine.. No Bells and whistles, ho hype, just radio. They just work. You better get you a Midland
  25. Yesterday
  26. I used the WX_PLAYER and put it into a BF-888 via a headphone jack and it worked fairly well.
  27. Ive got one in Sarepta on a 20ft tower. You'd have to be in Sarepta to hit it and receive it tho. only 5w output. The Springhill Louisiana Amatuer Radio Club is putting one up soon.
  28. No info needed really. Just use your name. I created this for those that cannot join our Friday night net.
