Connecting radio to headset for listen only
TNWEB replied to HamsterDancer's question in Technical Discussion
2.5mm or 3.5mm audio cables or adapters are readily available at many online retailers. -
WSBA407 joined the community
WSHL963 joined the community
WSJQ333 joined the community
I have a couple of Motorola DMR radios with several DMR repeated and simplex channels programmed and not one of the have any HAM channels programmed in them. One main reason why I don't is because I am not a licensed HAM and I don't care to be a HAM.
GreggInFL reacted to a post in a topic: Thinking about getting into DMR.
You can start by looking through the attached file. Amateur Radio Guide to DMR.pdf
What's the best way to learn DMR? This question from some holding a GMRS license only. Randy, you have a channel?
amaff reacted to a post in a topic: GMRS license covers my family? And etiquette for family chat?
WSJP316 joined the community
Sorry I missed this, but UncleYoda gave you the right answer. Every person should ID every 15 minutes and at the end of the conversation. Because you are all using the same ID a unit number or name is frequently also used. But to be honest most people just use their names and most people don’t care too much.
SteveShannon reacted to an answer to a question: Need help contacting a repeater with a Midland 115 mobile radio
CONGRATS on getting your Tech license.
WSJG968 reacted to a post in a topic: Passed my technician exam
GreggInFL reacted to a post in a topic: GMRS license covers my family? And etiquette for family chat?
You can give them GMRS approved (certified) radios. (Not HAM radios.) yes (any of the pre-programmed channels) They will need to identify with your call sign (at the end of each conversation, and every 15 mins if longer than that). You can give each one an optional unit number or nickname to tell them apart but the official ID is still required.
tstewart10 joined the community
WRUQ683 replied to WRUQ683's question in Technical Discussion
I know about the normal and inverted codes. But there is no option for that on the Midland radio. I opened a help ticket with Midland but of course it will be nexr week before anyone will get back to me. -
I took a drive around the block. No luck. I can easily Tx from the HT to the mobile on the repeater channel but not the other way round. I haven't touched the squelch but I'll look at that next. -
I took a drive around the block. No luck. I can easily Tx from the HT to the mobile on the repeater channel but not the other way round. -
OffRoaderX reacted to a post in a topic: GMRS license covers my family? And etiquette for family chat?
WRXB215 reacted to a post in a topic: GMRS license covers my family? And etiquette for family chat?
hxpx replied to HamsterDancer's topic in FCC Rules Discussion
If God the FCC gave us 50 watt channels, I'm gonna use all 50 watts. Edit: Theoretically. All I have are a bunch of 5W handhelds. But I would if I could! -
WRXB215 reacted to an answer to a question: Need help contacting a repeater with a Midland 115 mobile radio
What are some good frequencies to program.
TNFrank replied to TNFrank's topic in Amateur Radio (Ham)
I still need to get out and give it a try on some of the further repeaters. I really want to give it a try on simplex to see if I can TX/RX further. -
SteveShannon replied to WRUQ683's question in Technical Discussion
Make sure you do as @OffRoaderX suggests to prevent desense. Also, with DCS there’s both a normal and inverted codes. Make sure you use the right one. If it doesn’t have an I after the code it’s assumed N. Finally, I recommend leaving the receive squelch tone or code unprogrammed at first. That way you hear everything. -
OffRoaderX replied to WRUQ683's question in Technical Discussion
Get back 100 feet and try again.. -
Yes, I am. The Midland does see it as a repeater channel because it has an 'rp' next the channel number. -
Very close. I also moved back about 20 feet and still nothing.
