rfjunkie reacted to a post in a topic: What are some good frequencies to program.
WSJU837 joined the community
What if everything is programmed correctly, I key up, and hear nothing??
WSJV482 reacted to a post in a topic: How to access a repeater?
WSJV482 started following SteveShannon
WRUU653 reacted to a post in a topic: How to access a repeater?
TNFrank replied to TNFrank's topic in Amateur Radio (Ham)
I've added a bunch more 70cm Repeaters since I picked up a 9db Yagi for that band. The antenna also has an SWR of 1.01:1 for 70cm and 1.03:1 for GMRS so it should be fun to play with. -
rfjunkie replied to TNFrank's topic in Amateur Radio (Ham)
Recent Technician here. From my travels on the net so far, it seems you may want to also add the following for simplex communication in 70cm: Discovered via https://www.azfreqcoord.org/bp/bp.htm (PDFs of the bands are on the left menu). 446.0000 Simplex (National Calling, already included in the list) 440.9250 Narrow Band Simplex 441.0250 Simplex 446.0250 Simplex 446.0500 Simplex 446.5000 Simplex Finding these band plans is really helping me program up my HTs. How goofy will I look hanging out on top of a mountain, surrounded by 6 HTs (*one decent one for Tx and 5 or so more cheap ones for dual watch coverage of multiple channels?) Idk but I kind of want to find out.. . There are 2m and 1.25m VHF band plans with similar designated simplex frequencies that can be used, plus repeater listings linked to in the upper left of the menu that's worth a look. My guess is that repeaterbook status info is more up-to-date than static PDFs, but they also sort by location and have maps pinned for some bands in the lists. -
I don’t know, but if you click on Repeaters on the menu bar you should be able to look them up either in the database or on the map. Many repeaters give a squelch tail, a short burst of static right after you activate them, but the most reliable way is to monitor the repeater and see if anyone is using it then ask for a radio check. Also, if you leave your R-CTCSS empty you’ll hear everything.
WRUE951 reacted to a post in a topic: How to access a repeater?
Exactly!
so my T-CTCSS on my radio is the INPUT tone for the repeater?
@SteveShannon, are there any repeaters near Cherokee, NC that I can access? How do I know if I'm accessing them when I transmit? WSJV 482
WSJU965 joined the community
Input and Output are relative to the repeater. So your transmission is the input to the repeater and you receive the repeater’s output. The settings on your radio are relative to your radio. So T-CTCSS (or T-DCS) is what you transmit, which is the input to the repeater.
WSAQ296 replied to NWHov's topic in FCC Rules Discussion
It is amazing and frustrating how so many will fall back on 4-8 year old posts about line A, and not read the current rules. We've had this battle locally, and still the mumbles. It's just not there, as you know. Like building codes, when they remove one, they don't let you know, it's just gone. -
WSJV 482 here, i just recently, as of 08/29/25, received my callsign. I am still confused about connecting to repeaters... On my radio, I have C-CTCSS, C-DCS, R-CTCSS, and R-DCS... What is the difference between these settings and the INPUT and OUTPUT tones listed on the repeaters' information pages and which do I use for INPUT tone (R-CTCSS or T-CTCSS) and which do I use for OUTPUT tone (T-CTCSS or R-CTCSS)? And, what is the INPUT frequency and what is the OUTPUT frequency? And how do I program them into my radio? Thank you, any advice is appreciated! In Christ's Love, WSJV 482
WSJV482 joined the community
At one point I had mine on a mag munt on the roof of my truck, but I have the factory roof rack that was surrounding it. Now it's on a basic bracket and it is possible that performance was lost since the ground plane is no longer there. Regardless we shall see soon how much improvement I can get with the Highland antenna at roof height for mounting. Best case scenario it improves quite a bit. Worst case it's no change at all.
Question of radio rules between US and Canada
Lscott replied to WRTK502's topic in FCC Rules Discussion
See attached files. Canada Annex E - GMRS and FRS.pdf Canada GMRS-FRS Rules.pdf -
I was running it on a mag mount in the middle of the hood and it sounded better, but I got tired of looking at the coax running back down the hood and was worried about paint damage, so I got the lip mount. The clarity suffers a little bit and there's more snow in the RX but it looks cleaner and my left eye doesn't twitch anymore.
You're probably right, and I don't get in a panic if I forget, but it's a good habit to have.
Doesn't hurt to be on the safe side but my radio has a feature to turn on when that surge happens. I have that feature off because I don't want it coming on every time I start the truck. Point is, I don't think that starting the vehicle is dangerous to the radio unless it is wired wrong.
That's the one. I don't have it installed at the moment, but I do have it. I have a different guy for my ghost antenna
Welcome, Pedro! That radio is my go-to favorite when talking with new users. Good choice.
Working the repeater on distance and locations that can reach the repeater.
We had a great test and tune session on August 29, 2025 to find out more about test and tune dates attend a net on Thursdays at 7:30 pm. We logged locations where you can reach the repeater. We started around 9 am and it lasted till late afternoon. Thank you to WRMA779 and WRCY622 for your attendance in helping out. We where able to get some great information on the repeaters strengths. We reached downtown ST Charles from the top of the parking garage at St Josephs Hospital. Busch wildlife at lake 2, all along Hwy 94 and a lot of Hwy k. We used multiple radios from HT's to mobile setup and base units, antenna types as well. We had a good time doing it and look forward to the next. Until next time 73's WSHD977 clear.
Originally my Btech RPT50 didn't have a squelch function other than tones. It was added in when they did the 2nd update V1.008R
This one? https://www.frontrunneroutfitters.com/en/us/antenna-rack-mount.html
Thankfully I won't have to worry about a spring loaded part for the fold over. I have looked into my options and will be using a antenna mount by FrontRunner on my roof rack to simply fold the antenna over. How does it work? It has its own locking pin with multiple holes to lock I to for having the antenna stand strait up and folded over for clearance and not being in use. This will not affect the spring on the antenna
Try Chirp. I always had weird issues with some of the radio settings not being transferred properly from the Radioddity software. Like, it works, but sometimes I'd have to push the settings to the radio a couple times for them to stick. I haven't seen that same behavior w/ Chirp.
Lol, Try doing that where I live. You "might" catch a local depending on where you are, but more often than not, you will hear crickets. I know there is a lot you can do with Ham, thats why I like it, but some things take a lot of time to learn and many areas of this country do not have anyone on the receiving end. Band conditions aren't always good. This is much of the reason I rarely use the radio. Believe me, it pains me but I can't force people to like what I like, or to actually get on the radio and do something useful and I especially cannot control the sun. If you happen to be in an area where you get activity, then kudo's to you. I am glad it works. All I am saying is that radio is not uniform in all areas of this country. There are many dead zones in Ham Radio and GMRS where radio works, the operators don't.
WRUW294 joined the community
I wasn't talking about the spring on the antenna. You said you were considering a fold-over mount to lay the antenna down when no in use. I was discussing that, because most of them are spring loaded to control the hinge function. I should have been more clear about what part I was talking about. This whole comment tells me that you don't understand antenna design, what a the wavelength of the frequency is, proper antenna size base on the wavelength and antenna design..... and you shouldn't have to, to buy a radio and antenna to use the radio.... my fault for mentioning it. I should probably just wait for people to ask for an explanation instead of mudding the response.
