  2. If he is a licensed GMRS users he does not need to lower his power down to 2 watts to legally communicate on FRS channels 1-7 and 15-22. He is allowed to use 5 watts on channels 1-7 and 50 watts on channels 15-22 even if he is communicating with a FRS user on those channrels.
  3. His request doesn’t make sense. Any GMRS mobile radio will talk to FRS radios except for channels 8-14 which may only be handheld portable units by regulation. GMRS handheld radios can talk on 8-14.
  4. Trying to assist someone... He is looking for a mobile radio recomendation. He wants a Mobile rig to use with FRS at 2 Watts and GMRS 5Watts for Comms with his rock climbing friends. They all have Rocky Talkies and he wants a Mobile that will work with Rocky Talkies-- both the FRS and GMRS versions. He threw out around a Mobile in the 10-15 watts unit-ballpark. Any ideas on a GMRS Mobile rig that has that 2 watt pwr. option for TX on FRS and is not locked out on FRS? Thank you!! Best Regards!
  5. Today
  6. Keep talking guys. I am learning a lot.
  7. The simple explanation is one is used to isolate the transmitter from the receiver. Since the repeater is a full duplex operation, transmit and receives at the same time, any RF energy from the transmitter will get into the receiver. When this happens the receiver will trigger the transmitter. Now you have a feedback loop where the system will stay locked up on transmit until the power is yanked, destruction of the receiver's input at worse, or simply kills the sensitivity of the receiver then it becomes deaf to weak signals. The typical notch/bandpass duplexer filter is setup such that the receive half of the filter is tuned to notch out the transmitter's frequency as much as possible. The bandpass filter on the transmitter side is tuned to eliminate as much of a spurious signals that are not on the exact transmitter's frequency, thus preventing them from entering the receiver's circuits. For the above to work a certain frequency minimum difference between the transmit and receive frequencies are required. This minimum depends on the quality (design) of the duplexer. https://horwin.info/en/pro-dupleksery/ https://www.repeater-builder.com/antenna/pdf/w6nbc-duplexer-book.pdf
  8. If you look at the table, it's performance narrows and insertion loss increases as you approach 5MHz spacing. There is no way in hell that will have acceptable performance at 3MHz spacing.
  9. Since it's in my repeater and my repeater has 5MHz spacing I would say that it can be tuned for that spacing.
  10. Conflicting info 50W RF Power Handling 6 Cavity Design Minimum Tx and Rx frequency difference: UHF 3MHz Maximum Tx and Rx frequency difference: UHF 12MHz Fequency Range: UHF 400-470MHz(the full band) Bandwidth:±500kHz Standard Termination: N Connector Frequency Spacing: 8-10MHz Insertion Loss:≤1.0dB Nominal Impedance: 50Ω V.S.W.R:≤1.5 Suppression:>75 Isolation:>75dB Free Frequency Tuning Easy to build your repeater Weight:1.8Kg
  11. Be careful, that specification indicates a minimum spacing of 8-10MHz between RX and TX, but the US standard for UHF is 5MHz.
  12. That's the one.
  13. Google is sending me to the same link as i found earlier ... Repeater Duplexer 50W UHF 6 Cavity Duplexer SGQ-450D -
  14. If you broaden your search to “SQG duplexer” you’ll find several hits.
  15. No reference to my-450-sqg-50 on the interwebby And the other number had no reference either.
  16. That would be awesome to mess with for an afternoon. It's small, so it should be cheap to ship, too. If you want me to take a look at it, PM me and I'll send you my info.
  17. I had an Uncle who was an Admiral in the Navy out of Groton. Passed away and only my Aunt is survived. No one in Rhode Island that I know of LOL
  18. It's totally possible. The new one came nicely pack in a bubble bag surrounded by foam in a thin cardboard box. I just pulled it out and the old one that I'm storing in that box I checked the tuning screws and they are as tight as can be. And here's the original one that I replace with the one sent by Btech. Looks like a different brand, probably the cheapest they could find until they found out you need to buy them twice which isn't making it cheaper.
  19. Glad I could help you spend money The black screen is definitely easier on the eyes in bright sunlight and at night. It's worth the extra $50 for me. I can't answer your question about swapping the remote heads between the radios since I have not tried it. I have not noticed any differences in the two radios except for the screen colors. Both work equally well on 2m and 70cm. I didn't bother doing the mod on my 2730B since I am not impressed with how my 2730A performs on GMRS. I've tested the 2730A against my TYT TH-7800 and my Wouxun KG-1000G. I've tried all three with my Comet CA-712EFC and Comet GP-9 antennas. The modded 2730 does not receive GMRS as well as the TH-7800 or KG-1000G no matter which antenna I use. And everyone says my transmissions are louder and clearer with the TH-7800 and KG-1000G
  20. My son in-law just retired from the Navy (damn I'm old). He spent his last few years in Gronton, and lived in Preston. I still have family in Rhode Island and Florida too... funny coincidence. LOL
  21. Ya, thanks for the offer. Up in CT so kinda far to travel. But maybe I'll get sick of working up and take a couple days off and go visiting. Got people as far down as Florida and Texas I'd like to meet up with some day to make the imaginary internet friend real friends.
  22. It's been about a year since we got these and they are by far the most used radios in our household. We use them for simplex in the neighborhood when we're out walking or biking. They have had multiple slips, trips, and falls from bikes and scooters. We get coverage from inside the house to a point about 0.5 mi away in an urban neighborhood with lots of mature live oak trees. If both radios are outside, it's closer to 3/4 mi. I can hit a local repeater from inside Walmart at about the same distance without any problems. Actually, reaching the repeater can be done from inside my house at almost 2 mi away (elevation matters). For a <2W radio that's as small as the bubble pack radios and costs ~$13 ea, we've been very pleased. They're going back to the beach this year where it all started. There's more repeater coverage now so I'll have to reprogram them. I guess that's the biggest complaint is that there are not many DIY programmable channels. Otherwise, we've been happy with the purchase.
  23. I'd love to get my hands on it to see if it's just out of tune. You may have 2 good duplexers now.
  24. I think some companies will pre-tune them for you, but I would be concerned about filters with a more narrow filtering being shaken/vibrated out of adjustment during the shipping process. that may be why the first one you had didn't work so well. I may have asked this before, but if you are anywhere near DC, I'd be willing to meet up with you to tune one, or at least verify one you order stays in tune after you get it.
  25. Damn it, I was content with the 2730A and able to tell myself I didn’t need the 2730B and then you post pictures. I can’t resist pictures! You’re costing me money. In all seriousness though thanks for the comparison. I really like my 2730A. It does pretty good paired with a Comet SBB-5 NMO. I have been thinking about getting the 2730B and moving my 2730A to the house. Looks like it would be an improvement from the bright screen of the 2730A at night especially. Have you noticed any other differences between the two or is it just the screen? I was wondering if you can swap heads between the two? Reason for this would be to keep one with mod in vehicle with the black screen and have a non mod one in the home.
