  2. I’m not certain that surplus ground plane in one direction more than another affects directionality, much if any. I absolutely agree that some antennas require a minimum radius ground plane and I suspect that having that at least the minimum radius ground plane in all directions contributes to more even 360° coverage, but for GMRS that radius is relatively small. I’m old enough to remember how CB signals were pictured as very off center when an antenna was mounted at one edge of a vehicle, but the ground plane minimum radius is much larger for CB than for GMRS.
  3. @Alec Do you mainly use your radio to talk on repeaters or simplex? If you're in an area where there's good repeater coverage, and that's what you mainly use, whatever compromise you make with antenna location should be negligible. Let us know what you end up doing and share some pictures.
  4. Yeah, with the shape of the ground plane of the trunk (dependent on vehicle and frequency), I'd expect some directionality, given most will have more ground plane to the sides than front to back. id also expect the greenhouse to be blocking/shading the signal in some directions too. It just struck me as a little odd that permanent mounting in that location would mean more loss than a mag mount in the same place, where on the roof it's the other way around.
  5. Today
  6. In the description it says it can be used as a base station. Some people take that literally and think it'll do 1-23 plus the 8 repeater channels. It will not. It can't because it has the duplexer built in which would kill the incoming simplex channels. It's designed so you can respond with the repeater on the repeater stations with the microphone instead of needing a separate radio to transmit to the repeater to talk. Some people.... don't understand this. Even Randy was hoping the description of the "base station" was that of a full range GMRS radio as described. But he to, found out it can only transmit on the repeater pairs while only receiving on the 467MHz side.
  7. Piqued my interest after having seen the review. But I'm also allocating funds for a new handgun, so may have to watch for the giveaway video!!!
  8. As Steve Shannon mentioned, yes, but at an additional $35. In what way is your call sign ridiculous to where you'd want a change? I can't see that with the sequential assignment system. Maybe in the Amateur world where you get a tongue twister or very bad on cw maybe...
  9. Isn't this a repeater ? If so there is no need for 800 frequencies. 99% of the time a repeater is on one channel and one channel only.
  10. I just ordered a swr meter and should be here soon. The two radios are identical in the tones and settings. Tidradio is sending a new radio also, no questions.
  11. Steve you just answered a question I had regarding call sign assignment. That was were the issued alpha numerically. It seemed that way but with any government agency appearances can be deceiving.
  12. @mickeydav did you double check the tones?
  13. Sure, you can give up your current license and buy another, but it’ll cost you another $35. We had a member here that regularly irritated people then got a new license with different call sign. But there’s no selection of call signs. You might get something you dislike more. They’re assigned in order.
  14. I would check/confirm but mine is all boxed up and ready to give away to someone on Youtube. You should email the BTech Support with your questions - they are very good and very fast/responsive.
  15. Not on mine. That's the problem. The software I downloaded from BTech seems extremely rudimentary. For example, there are only 16 channels. Period. Supposedly, you can store up to 800 frequencies and scan them. There's no way to do any of that with this software.
  16. The payment should be associated with a FRN and show up as unused funds. If you apply for a new license using that FRN, instead of paying through the payment portal you should see your $35 there and a balance due of $0.
  17. I just randomly came across this review of the RT97L that was published on Youtube about 3 minutes after you made this post:
  18. One should keep in mind with that pic on whether or not the vehicle would be moving in any random direction as we all do when traveling. What frequency? Too many variable to take it with even a half grain of salt. You could have -2.8db and a split second later you would have +2.8db to the receiving station.. Now if the car was stationary in an anechoic chamber there's a better chance of those numbers be acceptable. But when we get back to the real world you wouldn't be able to tell where the antenna is placed on the car.
  19. We have limited stock of the new Retevis RT97L repeater available and ready to ship before the tariffs are in place. Like most things we sell, these will undoubtedly be bumped in price, so hurry up and get them before May! Purchase the Retevis RT97L Like the RT97S, these are waterproof (IP66 for this model), have an all-metal chassis, a built-in pre-tuned duplexer, and a DB9 accessory port. 16 channels are supported, in wideband or narrowband mode. CTCSS and DCS codes can be programmed with the included USB cable, but default to 136.5 Hz with the built-in channels. The antenna connector is a UHF (SO-239) connector. There is also a built-in heater to allow cold-weather operation, and it will reduce output power if it's starting to overheat, so it can stay running for longer. The transmitter duty cycle is 100%. RepeaterID will also support these with a model specifically for this repeater. The pinout is slightly different than the RT97S series, so the original RepeaterID is not fully compatible.
  20. Yesterday
  21. So--and I'm, um, asking for a friend--one can get a new license/call sign if their current one is ridiculous?
  22. After 90 days you can’t renew an GMRS license but you can get a new one. According to google’s AI refunds can be given, but it’s probably easier to apply the credit towards a new license. Call their support number. I’ve gotten excellent and friendly service the one time I called.
  23. We just need to keep reminding them.
  24. I also think there an option in the updated menu about being a non toned channel.
  25. IIRC, there is a "none" option in the CTCSS/DTS drop down list.
  26. When i had my JK Jeep, my Midland SMRS antenna was mounted on the left cowl back side of the hood. It worked fantastic in any direction. Now with my 10 meter mounted there, not so good. In fact i couldn't find a single place to mount my 10 Meter that worked as will as it does on my truck.
  27. Okay, one more thing. How do I tell it I don't want a CTCSS or DTS code enabled? "No SQ" doesn't seem to be one of the options.
  28. You are 100% correct that they are not only our representatives, but they are also there to serve us.. But It's cute that you think this would actually accomplish anything because they all seem to have forgotten about that part of the job.
