  2. WRUU653
    guest
    No worries, I was sure you were only trying to help. I purposely didn’t quote your post so it wouldn’t be saved in mine.
  3. I've done pretty good flipping certain Hytera Radio Equip.. Mostly Hytera Repeaters. I do weekly search's on the stuff and have noticed a huge decline in Hytera equip adds over the last month. Then yesterday i got an email from an ebay seller i've worked with telling me Ebay is restricting Hytera related adds. Not only do i see a decline in Hytera stuff but other manufactures i.e. Motorola, Kenwood etc.. Apparently Hytera is on the Homeland Security radar over networking issues..
  4. Not sure what CCS7 is. I understand DMR and P25. Also, another question, will I be able to RX P25 channels?
  5. You can go on eBay right now and find serialized firearm receivers, suppressors, and any number of highly illegal things... They do not care at all. Call me cynical but somehow I can't see them cracking down on radios in any meaningful way. If the ATF can't get them to enforce the law what chance does the FCC have.
  6. Today
  7. I live in Califailure.. Ebay does have capability to censor adds based on states and their laws.
  8. I agree. I don’t understand.
  9. That's sort of interesting. You have two different ID's that both show as working for DMR/P25. Not sure why the first one shows for DMR/P25/CCS7 since your DMR ID should work for that already unless they are maintaining two separate databases for DMR and CCS7.
  10. You have to use the OpenGD77 CPS. You want to. That’s the whole point of going to OpenGD77 is to be able to use the much simpler CPS.
  11. Interesting. I guess it’s possible that because you live somewhere else that your eBay results are censored. Is that your state government or eBay’s doing?
  12. If my radio comes with GD77 installed do I still use the factory CPS or is there one made just for GD77 that I'll need to use? Also, would it be possible to add a DMR section to the Forum?
  13. The simple answer is no, don’t invite the lightning into your house. Which is the most direct way for a lightning induced surge to get to the service ground? The box where your surge suppressors are is also connected to your service ground, but if running from the mast ground to the service ground is straighter, then that’s what you should do. Motorola R56 is the bible of station grounding, but most questions related to home amateur radio equipment bonding and grounding can be answered with this document: https://reeve.com/Documents/Articles Papers/Reeve_AntennaSystemGroundingRequirements.pdf On page 3 is a diagram that shows a bonding conductor running from the mast to the antenna discharge unit and then to the service ground. On page 10 it shows a bonding electrode running from a tower to a grounding electrode and then to the service ground electrode with a separate ground conductor running from the antenna discharge unit and the service ground, so it can be done either way.
  14. Randy, Looks like you are 100% correct. The seller sent me the same page Ebay sent him notifying him of their denialing of allowiing him to sell Hytera stuff. Kirk, The link below is what eBay sends. Evidently eBay searches for key words RD-982, or Repeater. The word Hytera itself does not trigger the response below. Notice this dates back some time. https://www.fcc.gov/supplychain/coveredlist
  15. Try looking at the MyGMRS listings instead of RepeaterBook. AZ shows 59 without stale or offline option enabled in the state and 125 with stale and offline enabled.
  16. Here's a pic of what I have. One I.D. will do 3 modes and the other will do 2.
  17. Do a web search for "Motorola R56" and you will find a PDF of a guide used for professional radio sites. This has an entire section on grounding, something that is often neglected until a lightening strike or power issue takes out most of the equipment. As to your questions, I would not recommend running through your floor joists....better as short and direct a run as possible. Don't go near your gas line either. As direct and short as possible with heavy gauge grounding wire, from your radio to a copper ground rod. Rod to bonding box and on to service ground should be fine though, unless you have hundreds of feet around your house for that too. Look at the amateur radio book/website you must have studies at some point for your license.....it will have some guidance for grounding as well. Keep it short and simple. Good luck.
  18. I know this has been discussed and just read a 3 page discussion but it did not answer my question. I am setting up my shack with GMRS and Ham. I understand the grounding and bonding but have a bonding wire routing question. My home was built in 1972 and the service ground from the breaker box connects to the copper water pipe inside the house where it goes through the concrete in the basement. That line runs 5’ under the ground. My grounding rods are about 40’ away on the end of the house. Can the wire for bonding the service ground and mast ground rods be run through my floor joists? It will also pass close the duct for my heat registers. Is that an issue? I read a post somewhere that said not to but have only seen that once. I can’t go in front of my house or I would have to tear up a lot of asphalt and concrete. Going all the way around the back to the front would be about 150’ and pass close to my gas line and gas meter unless I go further out in the lawn. A second question. Should that bonding wire run directly from rod to service ground or can I run it from rod to bonding box where my lightning arrestors are then from the box to the service ground? Been doing a lot of reading and get more confused as I read more. Can’t find anything that really covers my situation.
  19. big difference between HYT and Hytera. Yes HYT is manufactured by Hytera but as a different enity. HYT radios and software are down low in quality and options. HYT is basically another Baoefeng.. Hytera produces commercial stuff competing with Motoroloa and are actually good radios.. And yes, Hytera, like most Chinese companies, have stolen technologies, most notably from Motorola to win some dominance in the U.S. Lots of school districts and low budget cities and counties used Hytera Radios until Motorola sued them for stealing their technologies. However, that doesn't stop me from latching onto their repeeaters, which are pretty damn nice.
  20. Sweet, I'll have to give it a try.
  21. That would do it. It doesn't say anything about recreational use, but they probably don't sell enough for that purpose to be worth shipping them.
  22. Yeah, a couple months back
  23. The search terms you use can make difference. I've been looking at Dell and HP workstations with dual CPUs and I get different listing depending on what I type into the search bar. Same thing with GMRS Repeaters.
  24. They can give you two but you must really must need the second one. They are getting very pis*y-as*ed about people getting multiple DMR ID's, and don't need them. DMR can only handle a max of about 16 million ID's. If they don't clamp down on people getting a bunch sooner or later those will run out. I don't see that happening any time soon but you do have to watch out. I believe you can use your DMR ID for P25 as the CCS7 ID. I haven't looked at this in a long while so I could be wrong on this part. While you're there you can also apply for an NXDN ID too. I have both so I'm covered for all three modes. DMR: 3122951 NXDN: 765
  25. Northcutt114
    guest
    I had no idea. Thanks for the heads up. I edited my post.
  26. There are still lots of Hytera radio's on eBay, search for HYT instead. Ebay search results for "Hytera radio" showed 304 results but for "HYT radio" shows 4,700+.
