  2. I’ll see if I can find something like that I think it would help a lot. I did screw a 12 inch diameter pizza pan to the combine fiberglass roof and ran a grounding cable to the frame of the combine to try to limit noise. Farm equipment has so much interference it’s insane. If counterpoise truly means anything to these radios it would be a nightmare to bond anything on the machine
  3. Do you remember where you got those mounts at? They look clean and I’d only need one. Any issues with water infiltration in the cab after install?
  4. @TNFrank I haven’t tried it yet but qdmr seems promising and supports the RT3S, assuming the issue you’re running into is something with Wine/virtualization: https://dm3mat.darc.de/qdmr/
  5. Today
  6. My solution was a NMO mounts thru the roof. Had 6 on my 2018.
  7. I have no interest in how you run Linux. Just thinking about it, gives me heart palpitations!! Please give me more details about this statement: I would like to recreate your workflow to see why you were not successful with Windows 10 in VirtualBox. Also, please link me to your download of VirtualBox, and let me know which version of OS X is on your Mac.
  8. I'm running MX-Linux, 23.3 which is a Debian based Distro with the KDE Desktop environment. I've been on it for a few years now and it's the longest I've stuck with a Distro because it's been rock solid stable, the desktop environment is light weight and looks and works well and I can update my entire system with a couple simple commands in the Terminal. I'm sure it all had something to do with the way Linux handles devices vs the way an actual Windows install handles things.
  9. So has anyone been able to unlock the BTECH GMRS PRO?
  10. Welcome! Sounds like a nice collection of gear to start with, for sure. Its always fun to scan the channels and see what i hear when im traveling. Its always good to have some kind of radio on a common/popular radio service when you are someplace where cell service is spotty or non-existent, too.
  11. I did a little coding when I was young, but I can’t imagine what aspect of a DMR CPS, which is fundamentally a relational database, is causing you such fits. But to be honest, I have no interest in Linux just to solve a puzzle when so many alternative solutions exist on my Mac that just work! Although I am a happy camper with Parallels, I am intrigued to solve your Virtualbox problem and attempt to install Win10 and then program my non-OpenGD77 DB-25D on it, so… Which flavor of OS X are you using and please link me the VirtualBox you downloaded to run in it, so I can emulate yiur setup and then attempt to get Win10 and DMR COS running in it! I will acknowledge that COM ports in Windows is a “dark science!!”
  12. As far as the CPS for the MD UV380, I have used both it and the OpenUV380 CPS on a Mac, in Parallels, remotely accessed using RIM without any issues. I have also used RT Systems native Mac CPSes with various radios. All have worked. I don’t think your problem is the CPS software. I think it’s the translation between the hardware USB port in Unix and the port, whether USB or comport, in the Windows virtual machine.
  13. I hear people talking on it but I have not been able to key it up in a few weeks now. Shaw 525 went down also about the same time. (HAM)
  14. I downloaded a copy of Win10 and tried to install it in VirtualBox but VB couldn't read the activation code so it wouldn't install. It has been exhausting, I get excited about DMR only to be let down by CPS's that won't play nice with WINE. I've not had that problem with any of the CPS programs for the analog radios I have.
  15. Thanks…will do. Stopping by Devil’s River and Seminole Canyon on the way. Looking forward to it.
  16. Yep, just look at it wrong and it dents.
  17. Whew: it’s been exhausting! I have no experience with Linux, but it sounds like you are beating your head against a wall for no good reason. You know, Windows 10 and 11 do not require activation and hence are free?!?
  18. Analog really wasn't that hard to program WHEN the radio would connect to the radio. The DMR part does require a bit of a learning curve though. I had such high hopes for the RT3S but if I can't connect yo the computer then I can't program it.
  19. Oh researched it. It dosnt work for privacy. For some reason I thought it might sorry about that
  20. i'm thinking i would use this on the Ford Aluminium Cab. Even on steel made bodies. My Ram is steel tin and it aint' the asme steel tin cars used in the day, stuff now is Very flimsy
  21. There are adhesive back steel plates that can be bonded to a fiberglass surface to provide a decent ground plane.
  22. Well that does make sense now that I think about it! I just assumed in order for it to bounce off and receive it would need to have a direct mechanical bond to the plane. So I should be good there. Now maybe I need to investigate the combine mounting because I’m not sure that the fiberglass rooftop that the NMO is mounted to there is a good option. I’m sure they have a ground plane under it but I would think a metal surface up top would be better
  23. If you’re really not interested in pursuing DMR, don’t buy a DMR radio. None that I have seen are fantastic analog radios. The interface of DMR radios are not as easy to use for analog configuration as a decent analog radios
  24. Remember that 'ground plane' isn't the same as electrically grounding something. You need a big piece of metal for the signal to bounce off of, you don't need the antenna to be electrically connected to the panel. I don't know that I'd trust double sided tape on the exterior like that, but OEMs hang body panels off with that stuff now so what do I know
  25. Hey everyone. Had a quick question about using one of the dreaded magnetic hockey puck NMO mounts in my 17 F350 which is of course aluminum. Obviously magnet won’t stick to the top of the cab so I’ve put some felt down with double sided tape to stick it there for my ground plane. question is the felt and double sided tape interfering with good grounding of the antenna? I really don’t want to screw anything through the top of my cab to secure the antenna mount to. Right now radios work in excess of 5 miles but if somehow fixing this would get me some more miles that would be great. I don’t have an SWR meter to check any of the specifics. Just bought MXT500 radios for farm use so communicate is kinda important at times. what’s everyone done to remedy the aluminum cab issue? Thanks I’m new here btw so bear with me as I learn these things. We’ve had business band radios for years but they have stopped working and now going another direction since we can’t fix and program our own radios. WSJV395
