gortex2 replied to NWHov's topic in FCC Rules Discussion
Line A is still a thing. What has changed is GMRS frequencies are no longer part of the restrictions. I still have multiple FCC frequencies for public safety being held up in Canda. - Today
gortex2 reacted to a post in a topic: Ham Radio 2.0 Coverage of Low-band Channels for GMRS
WRQI663 reacted to a post in a topic: Dear Mr President Trump...
Synister joined the community
Over2U reacted to a post in a topic: Interesting comments being filed with the fcc on unused 46Mhz/49Mhz pairs
bihlein started following Ailunce HA1G PTT ID not working?
Hello all, I recently got a Ailunce HA1G radio and have been trying to get it working with a PTT ID required repeater in my area. Everything I have tried so far has not been working. I sent up the repeater channel, added my assigned ID to own ID under signal settings (or call ID if your programming via CPS), set to BOT at 300ms and set the channels signaling setting to one of the dtmf signaling lists I have. Anything I maybe missing? Any help on things I may be missing or tests I can do is much appreciated.
207 reacted to a post in a topic: New GMRS repeater.
207 reacted to a post in a topic: Repeater network navigation
UncleYoda reacted to a post in a topic: DB20-G radio oddities
My At-779UV does the red blinking light thing too. I just jiggle the mic cord and it resolves. Haven't had the audio issue described.
Might be a dodgy connection from the mic cable? those RJ-45 connectors aren't the strongest things in the world. If you jiggle the connector at the radio does it happen? I've noticed it do weird things if I disconnect or connect the mic or programming cable while the radio's on.
I'll have to let the repeater owners explain how it works on repeaters. My ham mobile can block incoming signals based on the tone, but that's different from an ID code. I don't think any radio I have can decode IDs even though they can transmit them. [A newer radio I have has an encryption function but it isn't legal to use so I can't even test that.] All my radios are analog.
[The cutesy title is a play on the brand name.] Just had an unnerving occurrence where no sound was coming out of either earphones or the radio speaker (receive LED and signal meter did indicate it was receiving). I tried all the relevant settings I could think of to no avail. After giving it up for broken, I tried turning SUB back on and switched to B -- boom!, sound blaring out. Switched back to A and sound there too. And it worked with earphones too. Doesn't make sense but I'm glad it started working again (no signals to test with right now). The other odd thing I've noticed is the red TX LEDs will come on briefly at random times when I'm not touching the radio. No pattern to it that I can discern so far. And the mic is hanging up where the PTT button is not touching anything.
WRQC299 started following Can the Anytone AT-878-UVii still be unlocked for GMRS?
I mean, "obvious" is a strong word, but yeah, it's certainly logical. I was just making sure. I assume that's not something that analog radios are able to do? You'd need a digital radio, yeah?
While you're waiting for 702's reply, I'll say that if specific IDs are required, then would it not be obvious that revoked IDs would be blocked? But for the official procedure to ban someone, the owner is supposed to send a letter to them (probably after telling them).
WSGE773 changed their profile photo
So let me ask a follow up question to this. If a radio can identify itself to a repeater and then the repeater can allow it access, can the opposite be true, as well? Can a radio be "banned" from a repeater by not allowing it's ID?
WRPQ808 joined the community
WSJL659 replied to WSJL659's question in Technical Discussion
Update: It worked. I entered test mode and changed the unit to Mode 2. It now has the same range as the older units. Thanks for the speedy answers. I just didn't want to open the box and power the unit up if someone had already tried and did not have success. The new frequency range must just be listed that way for US sales... -Adam -
Where I live is entirely different. I'm within range of 4 GMRS repeaters and I can go all day and hear nothing. One of them is mine and it's kind of a "stealth" repeater, but the other 3 are public.
Yes, I know I'm thawing out an old topic, but I thought it could use a refreshment. I have 4 repeaters on the air. I do keep a record of each repeater's users. Just not the email addresses. The "Run Reports" software as configured shows columns labeled Repeater Name, User Name and Callsign, Phone number etc. I am wondering if the columns labeled Number of Users, Requested Date, Approved, and Updated Date could be removed and put their email in place of them. Even if you couldn't download a .CSV file, it certainly would be easier than clicking on each approved member to glean the email address. What do you think? Doug Mitchell WROW 434
No, using Mobile Digital Communicator (MDC) signaling for voice on GMRS is not legal. The FCC prohibits all digital voice modes, such as DMR, on GMRS channels. MDC, though a form of digital signaling, is part of a digital voice system that does not conform to GMRS regulations.
How to Update DMR-1701 to Open GD77 on Windows 10 pro
WRYS709 replied to WSCN925's question in Technical Discussion
Yes in Los Angeles If you want to send it to me at my address here on myGMRS with a prepaid return label, I woukd be happy to do it for you. Let me know your digital ID, too Is there no Ham Radio club nearby you in GA? Another option is to just purchase a preloaded OpenGD77 on a TYT-390 from Lets Get Ready Radios for $119 free shipping from Los Angeles (I do not get any commission): https://letsgetreadyinc.com/opengd390plus -
WSCN925 replied to WSCN925's question in Technical Discussion
I think the Open GD 77 cps is not set up correctly or is not a Valid one to use. Does anyone have one that does work and have everything needed to upgrade my dmr 1701? -
STE is a separate function on Baofengs (and also RP-STE). This squawk I'm referring to is under Roger Beep. Anyway, around here, for ham, the advice is always to not use any of the stuff like that (STE, RP-STE, ANI-ID, access tone eg 1750). For GMRS, all I've seen is "don't use any DTMF codes on my repeater" (and of course, turn off the roger beep). My ham mobile can transmit my call sign (in CW?) but I don't use it in normal use.
WRUE951 replied to WSCN925's question in Technical Discussion
PLEX wrote back and said the problem is caused when PLEX server does Library Scans on the QNAP which takes up unnecessary resources to communicate with QNAP. They have a recent update that solves the issue along with some other security isssues.. Installed the new PLEX server update it it looks like all problems with my COM Ports are now solved with Windows 11. No issues so far connecting my DMR radios to CPM. -
WQAI363 replied to marcspaz's topic in General Discussion
I remember my first commercial handheld, it was the YAESU FTH7008. i purchased the radio since I was a Volunteer on Philadelphia's Operation Town Watch. Our group was one the first Town Watches to switch from Citizen Band Radio to GMRS. The one thing that I should have was obtain permission before purchasing the radio. I also wish that I had obtain my GMRS license, but I wasn't really active as I am now. I do remember our frequency was (462.725 / 467.725), I never really paid attention on the PL tone or Channel as GE used to use. -
Nope. Nothing Illegal About It For Private Use. Businesses Use It Per Part 90 & It Is Also Legal For GMRS Under Part 95.
Mobile Digital Communicator. its en encrypted communications which is pretty much illeagle for public use. You can legally play with it on MURS or a business radio license.
DPL (DCS) Coded Squelch Repeaters Are Different On How The System Recognizes The End Of A Received Transmission. No Squelch Burst.
WSIL946 joined the community
Reverse burst is usually generated on commercial 2-way transmitters to eliminate the squelch tail noise burst in systems using PL, or Private Line. "Reverse burst" is a Motorola term, and GE calls the same thing "STE" for Squelch Tail Elimination. Reverse burst or Squelch Tail Elimination ("STE") is a process that uses a change of the phase of the PL tone encoder for a short period of time after the user unkeys the PTT button. The term "reverse burst" is used to describe the deliberate phase change for a specific abount of time while the transmitter carrier stays on - about 150 to 200ms - with the phase of the PL encoder offset by from 120 to 180 degrees (180, naturally is a complete reversal). During the reverse burst time period the reverse phase stops the PL decode reed dead in its tracks - which slams the receiver squelch closed right now. By the time the transmitter actually drops off the air the RX squelch is already closed - which results in no burst of squelch noise being heard.
