Thanks! That is a special case, indeed. To your point and more generalized, BUSYLOCK is useful with simplex comms in noisy environments?
I know it's weird, but I kinda want one... LOL
No don’t use it. I just listen. But what you’re experiencing on a repeater is squelch tail. No one should be talking before the tail drops. If you start talking before the tail drops your lumped in with the previous station on the talk out timer. Usually 2-3 min. If everyone just waits for the tail to drop it shouldnt be an issue. I also leave it off because if I need to break in for an emergency or priority I can.
HHD1 reacted to a post in a topic: New TidRadio H3 PLUS
WRNU354 reacted to an answer to a question: Argument against Busy Channel Lock
amaff started following Argument against Busy Channel Lock
Not usually, but I do when I'm in the race car and, even with molded earbuds, can't always hear whether or not my spotter's done transmitting. Other than that, no, no busy lock.
WRUU653 reacted to a post in a topic: POTA Question
WRUU653 reacted to a post in a topic: TIDradio TD-H3 limitations
My enabling Busy Channel Lock (BUSYLOCK) on my radios seemed like a simple courtesy to reduce the chance of accidentally stepping on others. Before enabling it I did receive good advice that BUSYLOCK can disable a radio's ability to transmit in noisy or congested environments. I thought this risk acceptable risk since BUSYLOCK is easily disabled. What I didn't anticipate was the effect of BUSYLOCK had on my participation in repeater based events. The owner of my favorite repeater hosts a weekly event were participants start by checking-in. With a list of participates complete, he calls upon each to respond to the week's topic. It provides lighthearted discussion and opportunity to check out equipment. After enabling BUSYLOCK I found my attempts to check-in resulted in the BUSYLOCK error tone, even when I was sure the previous participant was done and no one else was attempting to talk in that moment. In my ignorance I did not consider the repeater's use of carrier delay (hang-in timer) on BUSYLOCK. With the repeater's carrier delay longer than it takes for participants, including the host, to realize the current speaker is done and there is an opportunity to talk I was effectively blocked. Now slightly less ignorant, I have disabled BUSYLOCK on my radios unless I find some future special case use. Does anyone have use for BUSYLOCK?
It sounds like you are getting an out of frequency tone. As @SteveShannon mentioned we’re going to need more information to help sort it out.
SteveShannon reacted to an answer to a question: Spurious RF emissions?
WRUU653 reacted to an answer to a question: Error Beeps
Or if the name has "Peoples Republic" I know the reason for Baofeng releasing the GT-5R was to clean up the SE on the earlier UV-5R radios. The UV-5R radios prior to the release of the GT-5R were pretty dirty. Though the front end was not improved on the GT-5R, it is still susceptible to front end overload. I have both radios and the GT-5R does a better job overall and is clean.
I LOVE!!! post like this. No info at all just a problem and a plead to fix it. But how? We know nothing about the situation? It’s like saying my car doesn’t run right what’s the problem? I’d bet it’s something very simple that has been over looked. Or it’s one of the many radios that have unexplained issues right out of the box. please give more info like already asked. Even a screen shot of the programming if possible.
Sounds like they took a nice radio and really screwed it up. I have none of those issues with the original. Worst issue is you get a dead transmit radio every once in a while, and they replace that. Ya, if you get in with them through email they will treat you right. I deal with Luxi and she hasn't lead me wrong yet. Gave me a UV26 to test and review. I like the H3 better.
1) it is still beta and buggy. That is to be expected being a beta product and I'll give them credit (big credit) for fast turnaround on updates, though each update breaks something else. 35 years in IT, I also expect that. Sometimes menu button works, other times it thinks it is the UP button. 2) Receive audio is weak. 3) Tx power is on par with other CCRs for GMRS, not quite what they state in the real world, but none of them do. This is a ham radio as well, 220 Tx is 0.1w. One tenth of a watt. 4) Options that could easily go on one of the PTTs are not available to map to it, you have to go into the menus. 5) Bluetooth ok with their app, but nothing else. Big miss, though apparently they are working on a BT speaker\mic for it. BT disconnects randomly. 6) Belt clip attached to the battery, not the case and there's no other external screws so no easy option for a counterpoise. 7) Ejecting the battery feels like it will break something every time, inserting again is like inserting a USB cable. Try. Fail. Try. Fail. Try again a third time the same exact way and it will click in. It is affordable and that carries a lot of weight, especially for the casual user or someone that just wants a small radio to talk to their buddies on the trail. As a RADIO radio, it isn't awesome. It isn't bad like a blister pack from Walmart with Spiderman on it, but up against similarly priced radios, it is at best, average once they get the bugs worked out. The H3 I've heard good things about (I don't own one), the Plus is not the same radio.
What's not awesome about it? I think the TDH3 is pretty awesome for the money.
What brand and model of radio? What’s the frequency? What channel is it assigned to? How did you program it?
Fix was released today. It works. Still not an awesome radio but at least it isn't a paperweight.
ag4so started following Error Beeps
I have one channel Out of four not working, when I key up I get three beeps. I figgure something is not programmed right but cant find it compared to the other channels. It is a GMRS frequency. Can any one tell me the meaning to the error code? not in the manual Thanks SteveWQPL257
WSHU230 joined the community
WRKI638 joined the community
Got the tracking # for the hardline, not arriving for a week. Looks like by that time the weather might be a bit more pleasant to be out in. Below freezing tonight.
LeoG started following Finally finished
Sounds like a good setup.
Like my grammar school history teacher taught us, any country that has the words "Democratic" in its official name, isn't.
Question about iCom ID-5100A and Repeater Tones
WRUU653 replied to cmranch's question in Technical Discussion
I can’t speak specifically to the 5100 but I have the Icom IC-2730a and can do spit tones using chirp. It may be worth a shot with the ID-5100 or as mentioned by @SteveShannon and @MarkInTampa leave the receive tone off. Good luck. -
Most of the hams I know are also GMRS users. It’s about fifty fifty on which license they got first. Some like me got their GMRS, got the bug and decided to expand. Others had their ham and I think saw value being inclusive for people in their own family, friends and community that aren’t interested in getting an amateur radio license. It isn’t two teams, it’s two tools.
WSEP997 joined the community
muddysamurai started following TidRadio TD-H8 - A true 10 watt handheld
muddysamurai replied to SvenMarbles's topic in Equipment Reviews
I just picked up an H8 HAM bundle off Amazon. I've unlocked it for all frequencies. When I tested the power output on High Power I got 11w on MURS 1, about 9w on 146.200, 8w on 446.00, 6.5w on GMRS 1 and 5.5w on 467.725. The power definitly drops as the frequencies go up. -
jjfireboy joined the community
WRWK581 joined the community
WSDX877 changed their profile photo
WRYZ926 replied to cmranch's question in Technical Discussion
Yeah Negative Nancy is being real helpful again isn't he. -
Jaay replied to cmranch's question in Technical Discussion
Good comment ... -
GMRS is another tool in the toolbox. Where some people might not have a ham license, the Gmrs license is good alternative. Even MURS is a good choice for people without Any license.
I have to agree with what @BoxCar, @SteveShannon, and @AdmiralCochrane said. My local club is quite friendly to GMRS users. We have our GMRS repeater setup at the same site as our 2m repeater and main 70cm repeater. We also encourage GMRS users that are not club members to use the repeater. We had a few naysayers when we started discussing GMRS. We sold the idea to them by letting them know that GMRS is another tool in the toolbox for emergency communications if/when needed. The other main reason we used is that GMRS is an easy way to get into two communications and some GMRS users might use it as a stepping stone to get their amateur license. And we don't have any problem if people that have their GMRS license never get their amateur license. A lot of the naysayers ended up getting their GMRS licenses after we put the GMRS repeater on the air. And they enjoy and use the GMRS repeater on a regular basis.
