  2. That is correct. There are several other threads that started with someone pontificating about how others use GMRS incorrectly. None of them settled anything. This is one place where GMRS is similar to ham radio; someone thinks their way is “the only right way” even though the regulations don’t support that.
  3. Well, we have a procedure here in the good old US of A. You follow the rules until you change the rules. Our problem is too many folks are too lazy to do the work to change the rules. Scofflaws always have excuses for their illegal behavior, in the same way illegal aliens do.
  4. Make more. It's not going to end soon.
  5. The MA09 antenna isn't all that bad. I found that mine wasn't really omni directional. We had a wind event and it bent the flimsy bracket I was using. When I used it while it was at a 15º tilt it was working better than it had in a while. I replaced the bracket and all of a sudden my signal went to crap again now that my antenna was vertical again. I had oriented it in the exact same direction because I have a cell phone booster antenna and I keep it pointed at the cell tower on the mast. I got this crazy idea and I rotated the antenna about 10º and reoriented the cell phone antenna and my GMRS signal got substantially better (from my house). Found that really odd that it made that much of a difference. Must have moved one of the lobes and now it's pointed at my house.
  6. I'm sure glad I made popcorn for this.
  7. We can break your bank guessing at what the problem might be. My feeling is that your antenna probably isn’t higher than the surrounding terrain and trees. Getting it higher can help but UHF does poorly in vegetation. Poor cable contributes by attenuating the signals in both directions, but antenna gain and visibility is by far the most important factor.
  8. Today
  9. Ya, I didn't even use the cable after I saw what it was. I have the RT97S which is only 6.7 watt out of the socket and I think I had right around 2 watts at the end of the cable. Pretty pathetic.
  10. Correct I got it as a package deal with the antenna, mic & cable. I can get about 1 1/2 miles west of me though the old oak woods & about 3 miles east though the pastures. So you guys think I need a better cable.? My antenna is a MA09 High Gain 462~467MHz GMRS Omni-Directional Base Antenna 4.5/7.2 dBi High Gain Fiberglass Antenna 5.75’ Thanks Sig
  11. That’s correct. But RG-59 has been replaced by RG6. Sell it to someone for use on HF or lower. It’s just not suitable for VHF or UHF.
  12. I’m just providing real life results in my situation and it was the same time of day. But, yes, two different radios. I’m trying to get a better picture of what and where different variables come into play in my area. I was able to use the MP-31 from this same street in the winter with less dense foliage.
  13. I found a spot like that 17.5 miles from my repeater. Pretty much a foot either way and nothing. Amazing I even found the spot. And there's no way I should have even been able to touch my repeater with a mountain in the way. I know it's mine from the courtesy tone I use.
  14. Yup, was too lazy to go look last time and couldn't remember. ends in 9 is 75 ohm ends in 8 is 50 ohm, right? Here's the roll of 50' I never used that I got with my kit. If I knew it was going to be this I wouldn't have ordered the kit.
  15. No flames... but there are so many other things that could have contributed to your results. That fact that you didn't use the exact same radio for both tests, during the same time of day from the same location (I think), are the big items that come to mind. Slight movement can make a huge difference, too. I can stand in one spot in my driveway with my HT using 0.5w and hit a repeater 30 miles away... but if I move a few inches out of that same spot, I can't hit the same repeater with my 115w mobile and high gain antenna.
  16. 50 feet of RG-58 would attenuate a buttload of UHF RF.
  17. A guy on one of the FB Groups for GMRS/FRS/MURS/CB posted: "I'm thinking off throwing out a call on my MURS Radio to see if anyone is around to talk, what do y'all think?" Besides the obvious reply about it being pretty much used for businesses for short distance comms. etc., my question back was, "what will you do for a callsign, given there are none for MURS; 'This is Cleanup on Aisle 9 monitoring, anyone around?' "
  18. So although the output frequency is 462.550, the frequency you must transmit to the repeater is 467.550 MHz. That’s usually taken care of automatically if you select a repeater channel.
  19. That's OK, I cheated and used the internet to do the calculation. Put in a wattage and it spits out a dBm and you subtract the dBm's and there it is.
  20. At the risk of being flamed…I tried using a Baeofeng MP-31 (output of about ~2W) to reach a low watt repeater about 3/4 mi away in a heavily tree lined suburban area. Unfortunately, I was not able to successfully hit it. I swapped to a Tidradio H3 with the stock antenna and was able to hit and communicate through the repeater. This radio transmits at about 5W. Attached is a photo of the area I was walking.
  21. That is the plan if/when I get the roof drilled for a NMO mount. I do plan on adding a backing plate to the underside of the cab roof. I would not want the roof to tear if I hit something with the antenna.
  22. Yup,, Center of the cab and don't waste your money on those third brake light mounts. I got one on a deal on Ebay and after about a year it cracked at the antenna mount. Worthless hunk of $hit...
  23. WRUE951
    Michigan GMRS
    I wonder why GMRS users in Los Angeles are complete opposite. It's like the gates to the jungle their
  24. If the roof top metal is that thin then consider some kind of backing plate on the bottom side to distribute the bending moment created by wind resistance on the antenna at highway speeds. No use in seeing the roof buckle around the mount if you can avoid it. I have a sun roof on my CX-5 so even if I wanted to drill a hole, which I don't anyway, there is precious little room. That's why I had the optional roof rack rails installed when I purchased it. The mount attaches to that. Even at highway speeds the 60 inch tall antenna isn't going to bend that wide rail. https://forums.mygmrs.com/gallery/image/473-close-up-of-mobile-mount/?context=new
  25. After trying all weekend, I have to accept, that at 66, I can't do it by myself anymore Licensed GMRS person and I have a TID H3, and yes, it is in GMRS mode. I used it this past weekend, listening to a really cool discussion forum in NW Indiana and decided to try to dip my toes into GMRS repeater, so I asked for permssion to a local (to me, anyway) repeater and have been nicely granted access to PULASKI-550. Frequency is 462.550 Output tone is 141.3 hz Input tone is 110.9 hz I don't care how many times I tried putting this into the menu options that I "thought" required: 11, 13, 21, 23, et al, no combo would ever make this thing remotely sound like it was gaining repeater access. Can anyone help me with a simple guide to programming this repeater into my H3? I've tried various YouTubes and, of course, not a single one had anywhere near the setup I need for this repeater. Thanks in advance!
  26. Well if he bought the kit like I did it came with 50' of RG59u (58?) which was horrible for UHF and the cable being that long.
