  2. I got phone calls from both my sons and a sweet text from my granddaughter. That's better than anything radio-related.
  3. True, but if they had used the radio as little as they probably really did, the movie would have been much less exciting. I believe you're referring to Bat 21 which was supposedly based upon an actual incident. I give Hollywood a little slack on some of these things. Nobody wants to see a movie about a bunch of soldiers who spend 20 days standing around scratching their b@lls and then have a 3.6 minute firefight.
  4. Thank you all for the quick reply. It worked today. Love this community already, everyone is so willing to help. Cheers!
  5. Just the gift of Time to work 6 meters for the VHF Contest.
  6. Today
  7. No, directly from Btech. I ordered the repeater from them. They decided the duplexer was troublesome and sent me a new one already tuned to the GMRS spectrum. I removed the old and installed the new. I still have the old one, they didn't want it back.
  8. From BuyTwoWayRadio?
  9. The repeater I ordered was new and apparently they got a bunch of defective duplexers and needed to replace them. OffroaderX can tell you all about that. So the company just sent me a new one already tuned to receive the GMRS frequencies.
  10. I would actually like to get one tuned to the frequency I use to see if it changes anything. Not planning on moving the frequency anytime soon so a hard tuned duplexer would be just fine. I would just remove the broad tuned one out of the machine and replace it with the single band tuned. Pretty simple operation. Probably less than 1/2 hour. That's about what it took me to do when I didn't know what I was doing, although not knowing what I was doing was just based on never had done it before. It's just removing some screws, swapping out the coax one for one and returning the screw back in place.
  11. Had a friend ask me to make his Retrevis rt22frs radios compatible to talk to other brands of radios. I have a TIDradio Bluetooth programmer I use for my own radios and I removed all Tones from all channels. Then decided to test and found that the radio could talk to my uv5r but couldn't hear it back (simplex channel no tones- I'm a licensed user). And then couldn't talk to anyone else's radio till I restored it back to original. Wondering if anyone knows what is up?
  12. @LeoG Where did you order the SGQ-450D from and did they do the tuning before sending it?
  13. There is an issue with the data we receive from the FCC, which affects newer licenses. We worked around it and have processed all the available GMRS licenses that we can see through the FCC data export. If your license was issued in the last 48 hours, you should be good to go now!
  14. I would say that is much better than a radio anyway!
  15. For those new to radio, and aren't a complete radio dork.... yet.... 12dB SINAD is a standard measure to describe receiver sensitivity. SINAD stands for 'Signal to Noise and Distortion'. This type of measurement is particularly useful for testing analog FM receivers. It represents the point where the desired signal is 12dB stronger than the combined noise and distortion. A lower input voltage at 12dB SINAD indicates a more sensitive receiver. Receiver sensitivity is the ability of a receiver to detect weak signals. A lower input voltage (measured in microvolts or dBm) at 12dB SINAD means the receiver can detect weaker signals and still produce a usable audio output. A 12dB SINAD measurement of 0.25µV (about -118dBm, -119dBm) is pretty good. Most expensive radios are about 0.200µV (about -121dBm). I looked at that SGQ-450D duplexer specs a few minutes ago. If someone is interested in buying one, while it's only rated for 50w, it actually looks pretty good on paper. 1dB insertion loss is great and both the suppression and isolation are on par with other mobile duplexers that are 3 times the price. Again, zero personal experience with this particular device, but it looks good on paper and @LeoG hasn't thrown it in the trash yet... so those are both good signs. LOL
  16. SOP hasn't changed, one still has to keep transmissions short to keep the enemy from triangulating your location. The Russians and Ukrainians are finding that out the hard way. Difference is you now have to worry about drones along with missiles and artillery. Signals are scrambled and most military radios use frequency hopping but the can still be located if they transmit too long.
  17. My military radio usage was over 50 years ago, so things likely have changed a bit.
  18. The Kraken system is like a child's toy when compared to what federal agencies and the military have. Even the equipment we had in the 90's was still better than the Kraken. We had no problems triangulating exact Iraqi positions back in 1991. And don't think for a minute that the feds are not using that kind of equipment right now. Transmitting briefly is standard SOP when using any military radio and has been for a long time. Transmit too long in a combat zone and you will get a missile or artillery rounds down your throat.
  19. I have the Btech RT50 and it has a full spectrum GMRS duplexer. It says it's rated at .25µV at 12dB SINAD. Can't say I can prove it but it seems to receive well for the antenna and it's height. This is the replacement duplexer they sent me. The originals sensitivity was much worse than the replacement. Tuned full band.
  20. that was the idea when using the AN/PRC-90. I just missed the AN/PRC-103 that was a pretty good improvement. There was a movie about a downed flyer. There radio discipline was pretty terrible and had they used the radio as much as they did in the movie it would have died or the flyer would have. The north Vietnamese knew what frequency to monitor.
  21. All I got was a card and love from my family.
  22. find a big huge round ground water tank and splatter your signal everywhere as you drive in circles around it .
  23. It might be difficult even for a few krakens to locate FRS/GMRS radios especially if there are many signals on the same frequency. Lots of "ghost" signals that keep moving around. Maybe 3 airborn detectors triangulating with high power optical recorders might be able to do the job quickly. And I don't doubt they have such a system. But with lots of radios out in a relatively small area it might be difficult to lock on a single tranceiver and even harder to hear a single transmission in a sea of similar signals. Don't use a roger beep or any identifying transmission.
  24. Transmit briefly and move frequently.
  25. This! Absolutely nothing unusual about the results.
  26. You need to look out for those krakens...
  27. Unless your UV-5G is different from mine, it can't be changed from the radio. It requires editing in Chirp. The Shift-D set to "Off" is the same as blank in Chirp, which is the setting for simplex transmit.
