I mentioned that their size was similar to a bubble pack radio and I think it may have been misunderstood.
Hello, Im following @OffRoaderX video guide on tone scanning. I'll keep you up on the progress if I can catch people talking on RPT2 or GMRS 16.
WRXB215 reacted to a post in a topic: Baofeng MP31 GMRS
Did I miss something? Where does FRS come into this? The MP31 is a GMRS radio.
ULTRA2 reacted to a post in a topic: GMRS for LA Riots.
JBRPong reacted to a post in a topic: Installation Photos: KG-UV980P in a 2014 F150 Super Crew (Also applies to KG-1000G)
Don't Garman have radios with GPS and will save location of the user in memory?
Thank you very much! I am in.
WRYE567 joined the community
WSGL206 joined the community
WSEP430 joined the community
SteveShannon reacted to an answer to a question: Travel Tones, PL/DPL differences
We have a longer hand time set on our 2m Motorola Quantar 125 for this reason. The Quantar 125 has a pretty high spike in amp draw when it firsts starts transmitting. The spike is fast/short enough that amp meters can't get a good reading. This caused us some issues with our Renogy inverter. The repeater would cause the inverter to throw a ground fault error and shut down. Our fix was to have the Quantar plugged into a line conditioner and the line conditioner is plugged into the inverter.
my uncle, now deceased, had the ammo can version in his collection. It wasn't really an ammo can, it just looked line one. Yes, it was pretty heavy for its size. I remember lifting it and think, what the hell is in this thing.. He also had a Military AM portable radio (i can't remember what they called it) with the radio mounted above its power supply.. The power supply was DC or AC depending how it was configured in the field. That thing was very heavy.
Maybe, but there are a few different ones to try.
I did try one like it but the one I had did not work. It may be a bad one but I had better results with just the wire with the appropriate jacks on either end.
Im ordering it over the weekend. i really thing that's the missing part to the setup.
WSIK532 reacted to an answer to a question: Repeater Box Build: Attempt 1
GrouserPad reacted to a post in a topic: BuyTwoWay came up with a CW solution for KG1000 Radios
From what I remember there were different sizes of battery boxes that could be used with the PRC-77. They were heavy (for the size) even with just a single battery attached. And then you had the weight of any spare batteries you carried on your ruck sack.
My $25 Tidradio H3 does split tones. I have my repeater with a analog receive and a digital transmit. Mostly don't because of the interference issues I have at my house, nothing to do with trying to keep people off. But it's a private repeater so it doesn't matter anywho
LeoG started following Travel Tones, PL/DPL differences
Sure there is. A wait time for someone to answer so it doesn't unkey and then rekey quickly. It's not as bad but no matter what start and stop produce wear and tear even on electronics. And having a 2-3 second hang time gives your party time to respond without the transmitter going off and then back on. It certainly isn't the same wear and tear as a large relay and tube system. But electrical spikes in transistor circuits can be fatal.
didnt they have several variants of that radio? Backpack, ammo can, mobile, etc? The battery back is what made them heavy as in the ammo can and mobile version they were realitivitly small
WRUU653 reacted to a post in a topic: Can not register on the Forum
WRUU653 reacted to an answer to a question: Repeater Box Build: Attempt 1
I have not had any problems with my Q10H yet. But I have had other brands of radios act up. though usually just reloading stuff fixed them. I've had Icom and Yaesu radios have glitches too.
Make sure to fill us in..
I hated when I had to carry the PRC-77. At least I did not have to carry the PRC-77 at the same time carrying the M60 machine gun. The only SINCGARS radios I dealt with were vehicle mounted. They were heavy enough trying to carry from the shop to the vehicles for installation.
Just added that to my cart. I'm gonna test it next week.
I've looked at the spec's for the man-pack radio itself. https://en.wikipedia.org/wiki/AN/PRC-77_Portable_Transceiver At 1.5 to 2 watts for the size at the time seems crazy now days. Just think what a modem commercial, not military, grade P25 HT can do , 5 watts and with AES256 encryption. It would fit in a uniform shirt pocket. I also checked the spec's on the old WWII handie-talkies. I was shocked to see they only did 360 milliwatts! Remember that while watching those old B/W WWII movies. https://en.wikipedia.org/wiki/SCR-536
Okay, I reported your issue also.
I have the same issue & reset password & followed instructions. Still same issue. I am told I have to create an account in forum but it won't let me saying I already have an account.
Yup..
Hello, this is whats missing Amazon.com: ZEZEFUFU Two-Way Relay Walkie Talkie Repeater Box RX/TX for Baofeng UV-5R Accessories 5MHz U-V V-U Cross Band Walkie Talkie Repeater : Electronics
Okay, check your email to see if you received a password change link. Follow it, bla, bla, bla.
I am thinking you need to swap radios on the duplexer ports. Like, I think they are labeled backwards. It would make sense that the case of the HT is letting enough RF leak in to trigger a receive light, but there is not enough of a signal to create usable audio output to trigger the vox operation. If its not labeled wrong and it is wired correctly, you could just be washing out the systems due to being to close to each other and too close with the test handheld. I have seen some HTs so sensitive to RFI from other HTs, that we had to separate them by 75 to 100 yards before the RFI and desense was small enough for the radios to work correctly.
