Here's an interesting video I found.
Will do, Gil. Of course everything multi-band is a compromise. I wouldn’t mind testing it with some single band whips.
SteveShannon reacted to an answer to a question: Best HT Antenna?
WRTC928 reacted to a post in a topic: Got caught in a NET today.
It wasn't a tri-band. It was 2 meters/1.25 meters. I doubt a good tri-band could be made that short. Sometimes I'd like to be able to use 1.25 meters without that 18" antenna flopping around.
WRUU653 reacted to an answer to a question: Best HT Antenna?
Steve let me know if you find one you like or even one you’re thinking of. I’d like to get one as well for my KG-Q10H. I always have room for more antennas, maybe not as many as Josh.
I have a Diamond RH77CA with a BNC connector on my FT5DR. It works when shorter antennas just don’t, but I don’t have access to a large number of antennas like the HRCC video tested. https://www.dxengineering.com/parts/dmn-rh77ca I wouldn’t mind picking up a different Tri-band antenna for my VX-6 and I’d really like to get a decent four band 6 m, 2 m, 1.25 m and 70 cm antenna for my VX-7.
200 watts isn't QRP.
WRXB215 reacted to a post in a topic: Thinking about getting into DMR.
WRXB215 reacted to a post in a topic: Callsign says it's already been claimed by someone else
8" sounds more like a 701. I have an Airband antenna rated for 100MHz-300MHz which should be good for not only Airbands but also 2M, 1.25M and MURS. I'll check out the 320A, thanks.
Yeah that's my go to antenna for tri-band also, I just added a link to my post. I haven't seen any tri-bands at 8 inches, I would be skeptical, though I do like shorter if it works.
That's my go-to for my tri-band radios. As far as I know, there's no tri-band antenna that isn't 15-18 inches long. I think it was on Amazon that I saw a tri-band radio that was sold with a 771-style antenna and a 2m/1.25m antenna that was about 8" long, but I haven't been able to find the antenna by itself. I'd like to have a couple of those on hand.
Each frequency is its own tuning so if you are looking for the best you can do it will depend on what you are doing. I generally use the stock antenna on my HT radios. If you are trying for more, something like a signal stick is going to help and mono band if you want the best out of one band. I just use dual band mostly as for me good is good enough and I prefer to use more bands over more distance. I have a tri band Nagoya NA-320A that works pretty good for 1.25m, 2m, 70cm, in fact it is better on 1.25 than the dual band stock antenna tuned at 1.25 and 2m. In the end you will have more antennas than radios. Josh’s video that @SteveShannon posted is a good one.
I watched 3 or 4 of his videos along with a few from some other folks. Just wonder what folks here were using that they found that worked well for them.
Tidradio H8 does not save DCS I codes as I and switches to N
TrikeRadio replied to WSJM270's question in Technical Discussion
I have an H-8 and have noticed this too... I set to a "N" DCS code for the TX... and it shows on the display as an "I" !! But it seems like it is still working properly. ( it is still activating the repeater and working anyway ) so.. maybe it is just a display bug? -
You haev to first go to the REPEATERS section of the website (for whatever reason the shared user account is kind of - separated between the forums area and the repeaters section) Click the Repeaters menu at the top menu. find the Edit Profile menu on the right under your profile log in (if you are not logged in in the repeaters area .. log in first.) In that Edit Profile edit screen you can change your username and then hit the Save Profile button at the bottom of the screen.
WSJH671 changed their profile photo
How do I change my username on here? I have tried fiddling with all the settings, and I just can't seem to be able to change it from my call sign.
WSJH671 joined the community
It only takes money to QRP. With a Tech License you can TX 200 watts on 10M. With a good antenna you should be able to DX pretty well.
I have a few different antennas from small stubbies(Diamond SRH805s) to a 3.14" longer stubby(Abbree AR-806+,my go to for my work radio) to the mid-length(8")whips and the longer 15.3" Arbbree AR-771. I'd guess that the 771's would give me the best range on par with other 771's like the Nagoya, et al. Question is are there any other antennas that might give me a bit more gain and still be portable enough or is something like a 771 type antenna about as good as it gets? I'll not only be using it on GMRS and MURS but also on 2M, 1.25M and 70cm now that I have my Technician License. Thanks.
WSFN387 joined the community
Oz joined the community
I agree. VOIP is VOIP. QRP to the other side of the earth and impress me.
You don't want to meet my brother. He even makes me pull out the dictionary, but his friends call him "the guy who doesn't talk much"
selectstriker2 replied to a topic in Guest Forum
Got all signed up, thanks! -
selectstriker2 joined the community
Ooops double post
I actually use my ham knowledge working on HVAC controls. Sometimes a sensor with a particular value needs to be simulated or corrected. I carry a signal generator, a decade box and a box of assorted resistors on my service truck. A megger that can read a gig and a Fluke 87 (which can also read nanosiemens if you know how to do the conversion). Guess who gets sent to the freak jobs.
rdunajewski replied to a topic in Guest Forum
I removed the callsign from the other account, so you should be able to register now, Ken. -
No idea who it is
WRJX918 joined the community
Hitting Repeater But No One Can Hear Me
UncleYoda replied to 423radioman's topic in General Discussion
I don't get Waynesville. If you can hit Bearwallow Mtn. 650 near Chimney Rock I should be able to hear that one. (Can't post the tones here.) I'd need to know when to listen though. Forest City 675 is another one that comes in here. I heard Fletcher once but that was probably ducting. Maybe @BoxCar can receive some near you that I can't.
