WSGX583 joined the community
Looking for info on eastern Mass .625 repeaters
SteveShannon replied to RadioSith's topic in General Discussion
By “silent RX” do you mean the LED is coming on but you don’t hear any audio or do you mean you hear the carrier but there’s no voice? Keep in mind that not only repeaters transmit on 462.625 MHz but also people using simplex channel 18 for both FRS and GMRS. -
RadioSith started following Looking for info on eastern Mass .625 repeaters
Good morning. I am trying to set up my data bank for repeaters that I use/may use I Am in Quincy/milton mass area and I am getting a silent rx from some .625 repeater (I am using midland mobile mxt 15watt with midland roof antenna. ) I can't find any influence info on any repeaters on the what might be sending this phantom signal...oh...btw... test freq reception at granite links golf... way up high above boston. Thanks for the help.
dosw reacted to a post in a topic: 900mhz range question
SteveShannon reacted to a post in a topic: Is there lost connections thing here...
Some types of radios are nearly impossible to find. I don't blame you for keeping it.
UncleYoda reacted to a post in a topic: Is there lost connections thing here...
Lscott reacted to a post in a topic: Ebay banning certian radio equpment sales
Any idea on actual output power in the 900 MHz band? I always scoff at the handhelds claiming 8 Watts, in a radio that size.....and when tested it is only 3-4 Watts and then drops off quickly to something a lot less than that. I like the displays and the layout of the radios though. Seem a lot like my Anytone 878 variant.
that was just a sarcastic snark remark against Ebay.. No way i'm letting loose of that radio and i'm pretty sure @Lscott knows that.
DMR ID/check I also need the frequency TX/RX of the Repeater I'll be using and I can get the Talkgroup/CC/TS from the Repeater info. Zone will be named "Digital" in my radio. I'm going to watch a couple videos to get more of a handle on things. This one looks pretty good at explaining things.
I have most vers but they are sitting on my server at home.. I'm away camping for couple weeks. What vers are you avter? I would stay below 8's because anything above excludes the motorola stuff due to lawsuit.
yes, you are right. how you write your add is the trick..Avoid speciic model number keywords because thats what they flag. Better to use detailed pictures with heading like Hytera Repeater instead of Hytera RD982 Repeater. According to my friend, Ebay flags specific Model Numbers basted on the information they get. Doing a serardh for Hytera mobile, transciever, repeaters or land base radios brings up the adds. A little more work for some of us looking for specic equipent but it is what it is.
Northcutt114 reacted to a post in a topic: Is there lost connections thing here...
TerriKennedy replied to HamsterDancer's topic in General Discussion
Don't worry, you'll get used to OffRoaderX (or you can set the forum software to ignore his posts). I think he does this stuff for the attention - after all, "making contact" could be something as innocuous as asking for a radio check. -
No, it doesn't. I also looked at the DB-20G. I ultimately went with the 25, not because of the additional power but because of the ability to quickly cycle through four channels instead of only the two available on screen with the 20. We have a dedicated channel for family communication that is always at the top of all of our radios. And then a local repeater under that, a NOAA channel, and then the last one is for simplex channels. If that doesn't matter to you, I'd go with 20, too. But the 25 does look cool and you can have a custom welcome screen.
TerriKennedy reacted to a post in a topic: guest
TerriKennedy reacted to a post in a topic: I'm thinking about getting a Radioddity DB25-G GMRS Mobile Radio 25 watt.
Adding DMR channels is different from entering analogue. You need 5 things for a digital channel, your DMR ID; a talk group; zone; color code; and time slot. Groups such as Parrot should be also set as a PRIVATE call to avoid blasting the zone with your test message.
Welcome John
WSJQ701 started following 🎙️ New Here? Introduce Yourself! 🎙️
Well, I had to dig out my Talkpod A36 Plus cable, the FTDI cables don't work with this radio, but I did get it connected to the CPS and programmed a few analogue channels into it. It hit the 3 repeaters on the White Tanks(about 16 miles as the crow flies)and I made a contact on the Del Web repeater, all be it my TX was weak. This I'd only a 5 watt radio and we have a pretty bad storm moving through so that might be part of it. My 10 watt AR-5RM gets out very clear so the extra power does seem to make a difference. Next step is to add some digital channels to zone 2. I'll need to look them up to see which ones I'm going to want. I've watched some videos that mention adding a Disconnect channel(4000 iirc)and a Parrot (9000?)then the other channels like a World Wide and some local channels. I'll get it figured out. If adding the digital channels is about the same as the analogue ones then it shouldn't be too much trouble. Anyway, just wanted to share.
I'm for it. I live near the Van Buren/ Bledsoe line close to Fall Creek Falls.
- 34 replies
- gmrs
- gmrs radio
(and 3 more)
Tagged with:
WSBX980 reacted to a post in a topic: EAST TN Hub
WSIY893 joined the community
WSJF268 joined the community
Gladesrunner joined the community
Change My Mind - I Don't Need Permission to Use Your Repeater
SteveShannon replied to marcspaz's topic in General Discussion
I don’t think I provided any kind of interpretation. All I think I did is provide citations from official government websites. -
DocV joined the community
WSBX980 replied to WSBX980's topic in Guest Forum
Does the 5 watt less really make a difference between the 20G Vs the 25G? -
MichaelHahn56 joined the community
WRUU653 replied to WSBX980's topic in Guest Forum
I think it’s probably a decent radio but the DB-20G also has 500 memories while the DB-25 has 200 if that’s important to you. -
Thanks to @TheMeatTrapper (WRN250), @WSDV406 (me), @WSIY431, @SteveGibbs (WSBM443), @WRXS569, and @WSGE773 For checking in on this rainy Wednesday evening. Tonight's net question was: "What is one thing on your bucket list you look forward to checking off?" Answers were things like "a fly-in trip to a remote Alaskan fishing village", "a month on the gold coast of Australia where the beer is cold and shrimp are warm", "break 200mph on two wheels" and many more very interesting answers. Join us Wednesdays at 8pm on 462.600. You're welcome to simply monitor if you wish, but consider keying up and saying hi if it feels right to do so. Thanks to everyone that takes time out of their busy week to spend a few minutes connecting and getting to know each other a little better. *Point your browser to (or share with a friend) SCTNGMRS.com or SouthCentralTNGMRS.com for easy access to the club page.....and make sure to click "follow" so you can stay up to date with new posts in our club forum.*
WRKC935 replied to marcspaz's topic in General Discussion
So then we get into the 'redneck rectification' part of it where the owner shows up at the GMRS users home. I was having this discussion about HOA board members and 'enforcement agents' that don't understand the law. Feel that THEY are the law. Or in some cases are a narcissist. You take a state like Florida that is fully in support of stand your ground and Castle Doctrine, and show up to a users house there. So you are one 'get the F out of here' from being trespassed. If you refuse to leave, you are already breaking the law. Criminal trespass is when the police write you a notice. But as soon as the property owner tells you to leave and you refuse, it's trespassing. It's not at a criminal level, but it's still illegal. But you are pissed and they are talking on YOUR repeater. As mentioned above, FCC has jurisdiction, NO ONE ELSE, including police. It's no more trespassing on your repeater than a pilot flying over a road is speeding. So you are really pissed and refuse to leave. Then decide to make threats, or your REALLY dumb and have made threats over the air or some other method of communication that is loggable, record-able and presentable in a court of law. So we now have threats, are on their property and are refusing to leave. GMRS operator is also a gun owner. But your pissed, he's used YOUR repeater. So you approach him in a way that HE believes is threatening... and it all goes to hell quick. You are going to the hospital or worse. You figure you will sue, if you survive. Tapes are played of you threatening him. Other's that were on the repeater are called to the stand to say they heard the threats. You weren't at a neutral location, you were at HIS property / home/ whatever. Key word is HIS. And you after all that approached in a threatening manner. So how mad are you about him being on your 'private repeater' again? HOA people sometimes do similar dumb stuff. It's not gone down this road that I am aware of, but it certainly can and probably will. Point is don't be that guy. Oh yeah, and don't think this means you need to go carrying a gun into this situation. Then you have committed multiple crimes while armed. Most states make all those mid-level crimes felonies. So even if you get your head straight and don't end up shot. You're going to prison, for some time. You convinced it's that important they aren't on your repeater? -
WRYS709 replied to WSBX980's topic in Guest Forum
I recommend you look instead at the DB-20G, which is now supported by Chirp; as well as by RT Software With a separate cup-holder mount, a mag-mount antenna and its cigarette lighter plug; I can easily install and remove it as needed. Alternatively, it easily permanently mounts as well. I use another one in my shack with a power supply and external rooftop Comet CX-333 tri-band antenna and it outperforms my Yaesu FT-857d on 2 meter and 70cm FM. -
Personally, if you are a GMRS user and tie up a repeater pair with a wide area coverage repeater, effectively soiling the channel for all other users to use. And then close the repeater to other's or require fee's to access it, well. I REFUSE to do that. I will take my equipment off the air first. And of course if I am pulling it down because someone decided to misbehave and pissed me off to that point. I will tell ANYONE who ask why and WHO is responsible for the dead air. Wide area, meaning some number of COUNTIES... Not a garage repeater with a 20 foot antenna. Now, my read of the regulations. And this comes from a number of different pieces of 47 and 95. Type accepted radios have ALL repeater channels programmed into them. They do NOT require special programming by a radio shop to access any allocated frequency or PL/DPL. Part 90 DOES require professional programming. And those professionals CAN get into problems with the FCC if they start sticking stuff in a radio that is NOT suppose to be there. That can be other LMR frequencies, Public Safety frequencies or anything else that the user has no right to. The FCC allows under part 95 for radios to go out to the consumer with all 15 repeater channels in place and the ability to program them at will. So point 1 There is NOT a requirement in the rules, as stated here that makes a GMRS license holder get special permission to access any repeater or use any repeater pair with any PL/DPL they see fit to. The only regulation is you can't use SIMPLEX on the repeater input frequencies. Point 2 Per the regulations, all GMRS license holders have equal access to all allocated frequencies within the scope of their license. Back in the day you got 2 frequencies. One was the 'traveler channel' at 462.675 the other repeater pair was assigned to minimize interference. So nothing that says you can't talk on the outputs. Point 3 What the FCC does state is that you can NOT generate HARMFUL interference on any frequency in the allocation. Use of a repeater is not harmful interference. Keying up and playing music, making noises, transmitting dead carriers, or a list of other things is 'harmful interference' And the method that the transmissions are happening, like someone keying over someone else of course is harmful with out question. Keying on on a GMRS repeater and giving you call sign and speaking o someone else if you are responded to is NOT harmful interference. The FCC isn't going to see it that way, and you should know this via reading the regulations and attempting to follow them. It you are that obtuse that you don't know what's inferred by the government, it's not the goverment's problem or concern how you think it reads, it says what it says. And then they are going to make a judgement call on what is and is NOT interference, harmful or otherwise. Point 4 So My opinion, Marc's right. At least at a federal regulation level, there is NOTHING that says you can't When you get into is it illegal trespassing? A cop can no more write a speeding ticket to a commercial jet pilot when they fly over their jurisdiction, that they can enforce use of the airways. That all falls on the FCC and their discretion. Now, an uninformed cop might try to do something with it until the guilty party tells them they are out of their jurisdiction and have no ability to enforce federal regulation. That may or may not work in the moment, but once people with actual knowledge of this stuff become involved like judges and prosecutors, the only thing that happens is the overzealous cop gets his jurisdiction sued for false arrest, imprisonment and a bunch of other crap. Some cities have laws that forbid the possession of equipment that is programmed specifically for their owned radio system. But then it's the police being interfered with and NOT GMRS. And the police can be brought into court over their misuse of frequencies. I know of a dept that was using 151.625 which is a 2 watt itinerant frequency as a dispatch frequency at 100 watts. Their all knowing radio guy did it, and never really bothered to explain what he had done. They were complaining about others being on their frequency, which wasn't 'theirs'. When we figured out what had been done, there was a call placed to the high ups at the dept about it and it got quickly dealt with. But they DID get a letter from the FCC soon after since someone had turned them in. But here again. GMRS user on GMRS frequencies is NOT any of these situations. If they have the license, they are good. If they are on FRS radios with no license, again. They are good. Nothing enforceable. The BS that Kentucky has on the books about radios in vehicles is so poorly written that a cordless phone could be in violation of their laws if they have a single low band licensed frequency anywhere in the state. Their law doesn't say programmed, it says capable of being used on. Yes, a real radio person could modify a cordless phone to hear and talk on low band. If it ever gets fought to a federal level, the state would loose. And if you want to REALLY make a cop mad, take an old X band radar detector and modify it to TX and RX FM audio. Of course no one uses X band any more, but when they did, talking (ham call IDing) and it coming out their radar unit WILL get you pulled over,,, but hams DO have an allocation on that frequency as a secondary user and if you are operating as a ham operator, it's ultimately legal. And made a pretty good jammer to boot. -
Northcutt114 replied to marcspaz's topic in General Discussion
Ooooooooooooo! I learned something tonight. It's in the settings tab, eh? I was looking for it as a field in the Memories tab. Thanks for clearing that up, and yes, all of mine have it. Interesting. -
UncleYoda replied to marcspaz's topic in General Discussion
I can't tell you where the settings are on every model. On my K5+ (a 5RM type), menu 20 is for selecting S Code, but the actual code has to be entered in software. Menu 22 chooses the timing of PTT ID, which also has to be entered in software. Here's one page in Chirp(next) for a UV5R from 2012 (covers many but not all such settings): -
I do know how to use the menu. I still don't see anything in the onboard menus that say anything about "ANI" or "DP-ID."
