  2. As far as the CPS for the MD UV380, I have used both it and the OpenUV380 CPS on a Mac, in Parallels, remotely accessed using RIM without any issues. I have also used RT Systems native Mac CPSes with various radios. All have worked. I don’t think your problem is the CPS software. I think it’s the translation between the hardware USB port in Unix and the port, whether USB or comport, in the Windows virtual machine.
  3. I hear people talking on it but I have not been able to key it up in a few weeks now. Shaw 525 went down also about the same time. (HAM)
  4. I downloaded a copy of Win10 and tried to install it in VirtualBox but VB couldn't read the activation code so it wouldn't install. It has been exhausting, I get excited about DMR only to be let down by CPS's that won't play nice with WINE. I've not had that problem with any of the CPS programs for the analog radios I have.
  5. Thanks…will do. Stopping by Devil’s River and Seminole Canyon on the way. Looking forward to it.
  6. Yep, just look at it wrong and it dents.
  7. Whew: it’s been exhausting! I have no experience with Linux, but it sounds like you are beating your head against a wall for no good reason. You know, Windows 10 and 11 do not require activation and hence are free?!?
  8. Analog really wasn't that hard to program WHEN the radio would connect to the radio. The DMR part does require a bit of a learning curve though. I had such high hopes for the RT3S but if I can't connect yo the computer then I can't program it.
  9. Today
  10. Oh researched it. It dosnt work for privacy. For some reason I thought it might sorry about that
  11. i'm thinking i would use this on the Ford Aluminium Cab. Even on steel made bodies. My Ram is steel tin and it aint' the asme steel tin cars used in the day, stuff now is Very flimsy
  12. There are adhesive back steel plates that can be bonded to a fiberglass surface to provide a decent ground plane.
  13. Well that does make sense now that I think about it! I just assumed in order for it to bounce off and receive it would need to have a direct mechanical bond to the plane. So I should be good there. Now maybe I need to investigate the combine mounting because I’m not sure that the fiberglass rooftop that the NMO is mounted to there is a good option. I’m sure they have a ground plane under it but I would think a metal surface up top would be better
  14. If you’re really not interested in pursuing DMR, don’t buy a DMR radio. None that I have seen are fantastic analog radios. The interface of DMR radios are not as easy to use for analog configuration as a decent analog radios
  15. Remember that 'ground plane' isn't the same as electrically grounding something. You need a big piece of metal for the signal to bounce off of, you don't need the antenna to be electrically connected to the panel. I don't know that I'd trust double sided tape on the exterior like that, but OEMs hang body panels off with that stuff now so what do I know
  16. Hey everyone. Had a quick question about using one of the dreaded magnetic hockey puck NMO mounts in my 17 F350 which is of course aluminum. Obviously magnet won’t stick to the top of the cab so I’ve put some felt down with double sided tape to stick it there for my ground plane. question is the felt and double sided tape interfering with good grounding of the antenna? I really don’t want to screw anything through the top of my cab to secure the antenna mount to. Right now radios work in excess of 5 miles but if somehow fixing this would get me some more miles that would be great. I don’t have an SWR meter to check any of the specifics. Just bought MXT500 radios for farm use so communicate is kinda important at times. what’s everyone done to remedy the aluminum cab issue? Thanks I’m new here btw so bear with me as I learn these things. We’ve had business band radios for years but they have stopped working and now going another direction since we can’t fix and program our own radios. WSJV395
  17. That's it, I give up. I'm not going to worry about DMR as cool as it sounded. It's just too much hassle trying to get my computer to "read" the dang radio. I'll stick with Analog and be happy I have it.
  18. Howdy. Also from Texas. Been wanting to do Big Bend National and Big Bend Ranch State parks myself. Let us know how it goes.
  19. Thank you very much….yes, synchronization. Very helpful work around you suggested.
  20. I'm having the same issue with the RT3S as I did with the DM-1701, no way to select the COM port so it won't "read" the radio. It says usb my be unplugged or in use. I've unplugged everything but my mouse and keyboard so there's only 2 things plugged into usb. I'm going to try downloading a .iso of Win10 and run it in VirtualBox to see if it'll "see" the radio there. If I can't get it working then I'm just going to give up on DMR. It really sucks that the CPS software doesn't work better or isn't set up better so as to let us select a COM port. None of my Analog radios give me this many problems.
  21. Yesterday
  22. You are.. kinda.. Dual-Watch/TDR only disables the active-monitoring of both the A channel and the B channel. On most radios, when you disable Dual-Watch/TDR, the B-channel still shows, it's just silent. What you want is "Channel synchronization", which most/many radios do not have. A work around is to set A to display as "Channel" or "Name", then set B to display as "Frequency" then always keep both A and B on the same channel.
  23. Trying to simplify the configuration/display. Have seen on Youtube that some have configured their specific models to have A set as "main" and B is the same channel as A, but displays the A frequency. I see that with some models such as the Baofeng BF-F8HP......and utilizing the older version of CHIRP, there was a check box in Advanced settings to enable or disable "Dual Watch" I set configured by Baofeng AR-5RM utilizing CHIRP-NEXT and some with the Baofeng UV-17 program........and configured my Radioddity DB20-G with CHIRP-NEXT and a tiny bit with the Radioddity DB20-G program. Despite four days of research and struggle, I just can't figure out how to set up both units with the Main "A" set up as Channel Name and "B" below displaying the frequency of "A" I have the feeling that I may be attempting the impossible with the specific models I have. Please point me in the right direction if possible. Very much appreciated. Thank you.
  24. I have an Epson printer that after it goes to sleep to save power it won't come back out when you call it to print. I put an outlet timer on it that turns it off for 1 minute at 6:20am and that fixes the whole issue. Might be a simple automated way to have the repeater reset itself once a day. Makes me feel a bit better it happens to someone else besides me. I sent a bug report to Btech about it and didn't even get an acknowledgement response, which is unusual. My courtesy tone stopped once, but it's never been a noise burst. Mostly it just reduces in volume.
  25. In mine the Rx and Tx connectors were SMA on the inside. The cables in the repeater are SMA to connect to the receiver/transmitter but N on the other end of the cable. You can't connect without buying new cables or chassis connectors. I chose new chassis connectors.
  26. A planned road trip to Big Bend this fall led me down the GMRS path of enlightenment. I am now the proud owner of a Baofeng AR-5RM (and an AR-771C GMRS antenna) along with a Radioddity DG20-G (along with a Midland MXTA26 with a magnet mount). Already found a few active GMRS channels on the Baofeng when outdoors......need to take the DG20-G with the Midland MXTA26 outside to test it. Thanks to many on this site for the informative posts. Safe travels to all.
