The definition of an open repeater is one that has been deemed so by the owner. GMRS repeaters are privately owned. You don’t have the right to list them, only the owner does. Furthermore a repeater having a matching output does not make it open, in fact programming the output (receive) isn’t even need to operate a repeater or hear it.
WRUU653 reacted to a post in a topic: Unlisted GMRS repeaters
Have you tried VHT + TX? Doesn’t it only turn on the fan while you are transmitting AND the temperature is too hot?
tweiss3 replied to WRPL700's topic in Amateur Radio (Ham)
I need to get back to studying for AE. Same as last years study course, life got busy and I'm behind again. -
hxpx joined the community
SteveShannon replied to WRPL700's topic in Amateur Radio (Ham)
I did. -
I'm hoping that you're not really serious??
WRVH403 joined the community
WSEZ864 replied to WRPL700's topic in Amateur Radio (Ham)
I don't know, I will look further into this. Your situation seems unique, with no prior call sign shown before your upgrade. Did you go from unlicensed to AE in one session? - Today
SteveGibbs reacted to a post in a topic: New Member Check-In
Good morning, same thing happened to me. Granted I literally just upgraded, so I'll give it a bit to trickle through the wickets.
WRCR724 replied to WRPL700's topic in Amateur Radio (Ham)
Or unless you request a new sequentially assigned callsign. -
My outdoor antenna for the repeater station and a third antenna in the shop window. The attic antenna depicted above post and the window antenna are just used to access repeaters in my area. I have two base station setups and one repeater station.
WRCR724 reacted to a post in a topic: My cheapskate attic antenna
WRYZ926 replied to WRPL700's topic in Amateur Radio (Ham)
My brother didn't request a new call sign either. The FCC will not change it unless you request a vanity call sign. -
WRCR724 reacted to a post in a topic: Unlisted GMRS repeaters
So did mine. Because I didn't request a new callsign. -
DeoVindice reacted to an answer to a question: btech gmrs-50v2 when i key up im my truck i get feed back
gortex2 reacted to a post in a topic: Off Roading
I have multiple repeaters. None are listed. I dont need or want them listed. Why should others list my repeater ?
You for sure married the right woman. My wife is kinda intrigued by my funny radio "fad", although she does not really "get it" and probably would never pick a radio up and talk into it... but she laughs at some of the funny conversations on our local repeaters. And she still loves me anyway.
xilix joined the community
WRVQ892 joined the community
It can be set to TX, VHT+TX or ALWAYS. There doesn't seem to be an option to keep it off unless it's hot (VHT)
That can be changed in menu 51.
ehawsey joined the community
Thanks for the feedback. I'm not sure if it's a Del Webb home. It's about 40 years old. For the most part it's a well built home. Nothing fancy. The attic over the garage is a good 7ft tall at the peak so I had plenty of room. Mostly I wanted to test the concept and these were the materials I had on hand. I got it all put together right before a local net started. I had to dodge my mother in law who wanted to chatter about what I was doing. Anyway, it seems to work pretty well. I am hearing the drive through girl at the Chik Fil A a few miles away, local highschool football coaches, road construction flaggers etc. More importantly, I can now hit a few repeaters that were out of reach with my HT. I am in a bad spot in this valley for reception otherwise. I am at the low end of the valley, right up against a curtain of mountains that block me to the East and South. You have the altitude advantage with that third floor. What kind of cable are you using?
Here's my little setup. Of course the KG1000G+ radio, then a Jesverty 30A switching power supply with a Surecom 102 SWR meter and my wife's trusty TD H3. The power supply is new. The old one was a Pyramid but lacked the amps to drive the radio. It was able to run my KC XS20G+ to 29 watts out but won't drive the KG1000G+ to 20 watts for whatever reason. The extra power pushed my SWR up from 1.01 to 1.03 on my Comet CA 712EFC antenna. Power seems spot on. On the repeater 467MHz channels it's pushing 49.x watts and on the lower 15-22 channels looks like it outputting a bit over 51 watts. Haven't tried into a dummy load yet. Looks like I'm stuck with my DMR noise, no real change unfortunately. The speaker output is much louder than the XS20G+. The fan coming on every time you transmit is annoying. Guess the silence of the XS20G+ has me spoiled. 3 power settings is really 4. The medium setting has a menu choice of 10 or 20 watts, I keep it at 20. Low outputs 4.8 watts, medium 20.5 watts and of course high 49 watts. We'll have to see about the sensitivity of the superheterodyne receiver as time moves on.
Welcome to the club. It’s a great radio, and performs well. I never knew that about the priority channel. I’ll keep that in mind if I turn weather alerts on as part of the scan as I also have the IC2730. Good info, thanks WRYZ926
My brother's call sign stayed the same when he went from technician to general to amateur extra. He was first licensed in 2022. -
Has that recently changed? Because three years ago I was automatically assigned AI7KS after I passed the AE exam. -
Didn't think about that but I see no vents anywhere on the unit. I've got the same impedance speaker just 5 watt instead of 2. Maybe I'll rig up a computer cooling fan blowing on the heat sink and see what happens.
GMRS seems pretty quiet in N Dallas. There are zero repeaters with hoards of users wanting in … sad, but true. Ham way mo betta
Well I see that I have the priority scan off. I normally don't use the scan function anyway. But I have 3 repeaters that are in my area as well as my own. Maybe I'll set one side up to scan the 3 channels since in different areas I use different repeaters and need to let the little lady know when I'm moving out of one area and into another.
Sometimes the existing vents are designed to direct airflow over certain components. Seems like the fan has to be pulling air from somewhere.... If you pull the speaker, you may provide additional ventilation throughout, but you may lose an important airstream over components like the processor or amplifier. IMO, if the existing vents are clean and clear, not blocked by anything externally, that's likely the best you can do for it.
Since this is the technical forum, what you are really interested in is the impedance of the speaker, expressed in ohms (unit of measure for resistance and impedance). An impedance match (amplifier:speaker) is important to both power transfer efficiency, audio fidelity and component longevity. "What is the pound of that pack of hot dogs?" vs "What is the weight of that pack of hot dogs?" (expressed in pounds). I would agree with @WRUE951that it is usually more important to match impedance than max power, since most applications never need max power. Answer to OP: Yes, using a 5 watt speaker in place of a 2 watt speaker is fine, although, depending on the speaker, you may require slightly more power to achieve the same sound level.
