I see many repeaters listed stating they require a paid subscription. I have questions about this. All licensed GMRS users may transmit on any authorized GMRS frequency using any available tone, providing they are not breaking any FCC regulations. I understand that setting up a repeater requires time and resources (i.e., $$$$), but anyone setting up a GMRS repeater is essentially putting it out in the public domain. Tones are not some super-secret thing. How is charging people money to use public frequencies not illegal?
I hear you. My adult sons take great pleasure in telling me if I forget to be a "normie" and get a little to military. I usually start with, "well at your age I was blah blah blah," as if they care. LOL
Haroldo reacted to a post in a topic: Propper radio etiquette
EarlG940 joined the community
LOL - Too Funny........ "30 Super Carry" Was As Successful As The "Sig357" Round - Both Didn't Do Well........ Everyone Has Their Opinion, & As Long As The Gun Goes "Bang" For Your Specific Purpose - All Good For The Intended Purpose.......
tcp2525 reacted to a post in a topic: NOTICE OF UNLICENSED OPERATION
Hell YES!!
SteveShannon reacted to an answer to a question: TD-H3 GMRS and Repeaters
WRUU653 reacted to a post in a topic: NOTICE OF UNLICENSED OPERATION
WRUU653 reacted to an answer to a question: Retevis Repeater Software Help.
WSHW579 joined the community
WRUU653 reacted to a post in a topic: RT Systems for Mac and Wouxun radios.
WRUU653 reacted to a post in a topic: Fixed Station vs Base Station?
If you have a type accepted GMRS radio the offset should be baked in for you. A number of diy repeater channels should be also.
Might want to consult the manual. It has info you need to know. Then you may want to consult the interweb. It also has info you need to know. If your programming in a computer this will alll be 10000000xs easier and make more sense to you. You will always need a plus5 off set for gmrs repeaters and usually tones.
Just steer 'em to the 30 Super Carry group...
You're not alone. I've read similar comments over time.
Try right clicking on the install file and left click "Run as Administrator".
Lscott reacted to a post in a topic: NOTICE OF UNLICENSED OPERATION
That's OK. I tried. If you can't work the inner workings of the system they you are reliant on everything working right the first time around. I just spent an hour with my wifi router that I use to connect my laptop to my printer. No internet connection. It's been working for over a decade and then it went plop. Had to reset my router completely and now I only have the default name which I hate. Took me an hour to get things back to operation because I refused to give up my original specs. But eventually I had to reset it.
I am going to guess, based on his previous responses, that he is going to have zero clue what any of those words mean. ..just a guess though..
Should work. I had trouble with Win7 Uninstall the previous programming software if you haven't already. See if there's a line in the program area of the control panel to remove the driver. If not go to the device manager and locate it and remove it. Reboot the computer and install the driver. Hopefully it'll work. Or you might be able to "update" the driver in the device manager with the same file. Likely this with throw an error as "current version installed"
rodz6331 joined the community
You mean we aren't suppose to inhale any nitrous oxide???? I figured a little for me and a little for the race engine was a good thing.
Or a bit too much nitrous oxide.
New guy here and learning what I can. In my readings it sounded like making a new channel for repeaters is best; ie. Channel 31. Do I need to input the offset/direction or is it auto/hardcoded in the H3GMRS radio? thanks.
Another update. RT Systems has released the Mac versions for the following Wouxun models: KG-XS20G/KG-XS20G Plus KG-935G/KG-935G Plus KG-Q10G KG-Q10H KG-1000G/KG-1000G Plus Note: for versions that have a regular and Plus models, there will be two different installers inside the Zip or DMG files. Make sure to select the correct one.
WROF765 joined the community
Everyone sounds drunk.
10
Anyone have any info about this Michigan repeater "Frida 700"
Scott1966 replied to Scott1966's topic in General Discussion
Yes, I am familiar with those towers and use them occasionally. You have already granted me access. Thank you for that and thanks for giving me the scoop on Frida 700. -
It's definitely fascinating tech. I can see why digital is so appealing, but I just can't get used to the sound.
WSBC594 joined the community
you won't be happy with a simplex repeater but if money is your controlling factor, try it out.. it's cheapo enough..
WSHH887 started following Fixed Station vs Base Station?
Relax. Every "hobby" has subjects that come up from time to time and elicit opinions guaranteed to create chaos. Heck, after over a century of coexistence, asking which is better .45acp or 9mm will result in weeks of debate on firearms forums.
LeoG started following Retevis Repeater Software Help. and Propper radio etiquette
The eff sea seas says every 15 minutes if you are conversing that long. Otherwise when you plan on not talking anymore call out your ID.
What version of Windows are you running?
WRXL702 replied to Scott1966's topic in General Discussion
The Frida 700 Station Has Never Been Built Out Or Put Into Service. Some Folks Like To Post A Station To Mark A Geographic Area They Are Considering For A Repeater Someday. The Problem Is That "Someday" Doesn't Seem To Happen. You're Welcome To Put In A Request For My Niles 725, It's In Service & Has A Good Footprint For South Western Lower Michigan & Northern IN. You Will Also Receive The Indiana Osceola 600 Which Covers A Portion Of Southern Michigan As Well........
