  2. 2% diphenhydramine HCI pump spray is my go-to. I get generic at my local dollar store.
  3. Thanks to @OffRoaderX for the suggestion! Here are the steps necessary to add a user to your “ignored users” list. First, click your screen name in the upper right hand corner. A drop down dialogue appears. Right next to the bottom it says “Ignored Users”. Click on “Ignored Users”. You’ll see a dialogue asking you to enter a member’s name to your ignore list. Start typing the screen name they use. You’ll see a listing of usernames that match what you’ve typed. Select the name from the list for the user you wish to ignore. Select the check boxes that define what you wish to ignore. If you never want to see their posts, check “posts”. If you want to block messages from them check “messages”. If you don’t want to be notified when they mention you, check “mentions”. And finally, if you just don’t want to see their signature at the bottom of every one of their posts, check signature. For example it makes sense to check signature but not posts if their signature bugs you for some reason. It really doesn’t make sense to select signature when you’re going to be blocking their posts, but that’s the default. Then click the blue button that says “Add User”: You’ll get a quick confirmation message saying you added the user to your ignore list: It’s that easy.
  4. You should make a step-by-step How-To for blocking/ignoring someone.. with screenshots and arrows and everything.. That way we can all link to it whenever necessary. In the screenshots be sure to use an appropriate user as the example.
  5. Today
  6. that was it.. he is now history in my book. Thanks
  7. Look at the selections you made for ignoring him. It’s possible not all are checked.
  8. Congratulations! Definitely go for General next. If you're using hamstudy.org then you're on the right path. Consider Amateur Extra as well. Yes, it's a bigger lift, but you can do it. Just study like you studied for Technician and General.
  9. Congratulations.
  10. TLDR. The simple answer to the question is: "It depends".
  11. if its the Repeater with Auto Voice ID announcing the wrong time and date, I believe it sits on a hillside north of Pasadena. It seems to be a unattended repeater, i often wondered if the guy died or something
  12. That looks very clean. Nice job.
  13. Listening with no RX tones will allow you to hear traffic. The call sign will tell you the licensee and their mailing address so you can send a snail mail request. What’s the call sign?
  14. Well a double post doesn’t get more answers. As for La echo 1, nope. It’s a massive huge foot print. I can hear it all over LA and the IE, up into in Santa Clarita, Ventura, antelope Valley, parts of San Diego, victor valley and in Barstow. It’s probably on mt Wilson and must be atleast 200w with a huge antenna. I have never heard anyone on it in years. Just the stupid auto ID every 5 minutes. It’s so big that if people had the tones it would be useless with 100s or 1000s of people jibber jabbing on it all day.
  15. Good rule for Poison Oak & Ivy, but not sumac. Poison Sumac is not three-leaved and is entirely different looking. Sumac leaves are "pinnate" (resembles walnut leaves), with 7-13 paired leaves on a stalk. Sumac is also usually found as a small tree with a woody trunk. [url]https://www.healthline.com/health/outdoor-health/poison-sumac#identify[/url]
  16. To be on the safe side, it would be best to check the VSWRs on your transmit freqs you favor most offen in both bands. Dual band antennae are a compromise and can be problematic for your radio over time if not properly tuned for your operating freqs.
  17. That's what I was saying. He'll charge you big and then only give you decimal points.
  18. Nice clean install. Looks good!
  19. Congratulations!!! Now get that General License!!! It greatly expands what frequency bands you are allowed on, which is important (from what I gather) since we will be losing 10M and 12M because of the 10 year solar sunspot cycle winding down. Though they have not been that great here in the last month or so already.... I am a newer ham and am really enjoying 20M. It is surprising how far you can comm with 20 watts when the ionosphere cooperates.
  20. Decimal points are cheaper than periods, ask any woman.
  21. Anyone know anything about the location, owner or PL tone on the LA ECHO1 W40 repeater in California on GMRS 22 462.725?
  22. Anyone know anything about the location, owner or PL tone on the LA ECHO1 W40 repeater in California on GMRS 22 462.725?
  23. Sounds like you might just be to far away. Especially on a handheld even if your in the estimated distance of the repeater you might need to walk around and see if you can find a spot. Best way you will know this is if you cannot hear people talking on the repeater then you won't be able to open it either. Find a place where the traffic is coming in perfectly clear then try again. If still no then program it on the radio and not chirp, and ensure you have the correct offset as well. Good Luck Have fun its always a learning process.
  24. Assuming your creating a node only network and talking over DVswitch or Zello only, I would think the network admin would be able to help more then someone on here since most here is just RF related. With that said with my limited knowledge of nodes I would say it sounds like you have a config issue, that your node number is not registered or approved for the network. In which case again you would need to contact your network admin.
  25. I remember during COVID lockdowns I was out walking late at night for exercise with my HT to combat the boredom. Two Hams on a local repeater talked for an hour about their model railroad hobby. That was a refreshing break from the usual stuff you hear.
  26. Hang in there, man. The steroids will help, and hopefully not have too many side effects.
  27. Out of curiosity, I took a general practice test with zero prep the other day and got maybe five questions right so I didn't think I should waste the test team's time today. I'll study for it and try in a few weeks once I've got that work cert knocked out. Ouch, you're not kidding. I've bought motorcycles for less than some of the base transceivers I saw over at DX Engineering. Though to be fair, one of the bikes was like $600 and was older than me. We bought a bag of split pea soup mix to make with leftover ham from Christmas, and then we forgot to make it.
