nokones
    5
Everything posted by nokones
  1. I will put together some programming worksheets for you to complete and I will email them to you. I doubt that the Motorola or other shops are willing or have the ability to program the codeplugs for these radios for you. You may want to make some calls to see if anyone can and/or willing, I can email the codeplug file(s) to you for to take to the shop. Is there any chance you can provide me with the model numbers of the radio(s) you want to program to see if I have the same model and feature set so I can build the codeplug file(s) without your radios at first?. The MT2000 radio comes in two versions, 48 channels or 160 channels. The 48 channel radio has a top six digit display and is referred as the A4 version and the 160 channel radio has a front face display with a full keypad and has a twelve digit display and is referred to as the A7 version. The display can be configured with either or both the Zone and Channel names with adjustable number of digits not to exceed a total of twelve. I.E., if you elect to have the Zone name with four digits than you can only have the channel name with eight digits. If you elect to have the top rotary knob as the channel selector than you will be limited to 16 channels per Zone. You can have as many zones as you want but, you can't exceed a total of 160 programmed radio positions. You will have the ability to select your zones through the keypad and/or the first three zones with the top A/B/C with if you elect to have that feature switch enabled. Food for thought I'll try to express your programming features options in the worksheets.
  2. When I was looking into buying mobile radios I came across both Part 90 and Part 95 mobile radios that would not accommodate wide band because they were manufactured after the refarming mandate. I believe Kenwood and Midland to name a couple were the ones that would not do wideband. I would need to retrace my steps on what I did several months ago to completely answer your question.
  3. I support narrowband and some of the newer radios that people are using on GMRS will not support or operate on wideband.
  4. Thanks. My mistake on the intervals, I was use to every half-hour on Part 90 station and I am aware of the 15 minute intervals on GMRS..
  5. Does anyone know of a source to obtain an automatic station identifier that I can connect to my radio or transmit on my repeater input frequency to identify my station every half-hour?
  6. I'm using a Laird FG4605 5 dB omni 460-470 MHz antenna.
  7. I fabricated this setup for my 21 Silverado Diesel Dually. I hang it on the lip of the passenger side of the center console, close the lid, and angle the radio towards me. I hang a towel over the lip so the bracket won't scratch the console.
  8. That link is dangerous, at least according to Norton.
  9. I have everything to program the HT1000s, MT2000s, and the MTS2000s. Where do you live, city and state will suffice for now.
  10. Here is my goofy setup. The one radio on top of the power supply is my GMRS base station radio. The other two radios are for the GMRS repeater package. I am using a Laird 5dB Omni antenna with an EMR Duplexer using a LMR400 coax cable with a lightning Arrestor connected to earth ground at the electrical panel. I switched the Antenna between the Base Station Radio and the Repeater Package with an antenna switch. I have other radios for all my vehicles.
  11. I have a Laird 5 dB Omni hanging on the side of my garage connected to a 50 Watt Repeater Station using LMR400 Coax with a lightning Arrestor grounded to earth ground at the electrical panel.
