WRYZ926
    47
Everything posted by WRYZ926
  1. And that is probably the problem with both of my KG-1000G Plus radios. The different y adaptors never worked with either radio.
  2. Good luck with it. I did as Mark said and it worked fine when using only one speaker port on the radio. But sound was horrible when both sides were plugged into both speaker ports on the radio,
  3. It might say that but a 3.5mm stereo y adaptor will NOT work. The sound will be low and muffled if you do. I can tell you this from personal experience because I wasted my time and money trying a y adaptor myself. Again, I was hearing both A and B through the single external speaker but the sound was veery low and muffled. The KG-1000G manual is wrong when it says to use a y adaptor. Even if you did find a mono y adaptor, you will still have an impedance mismatch that will cause the audio to sound bad.
  4. Breaker 1 9, breaker 1 9, rubber duck, do you have your ears on. come back. I use GMRS properly to call family and friends on simplex. And I also will just call out on our repeater to see who is listening. It is usually the same family and friends on the repeater that I talk to on simplex. We do get occasional new people on the repeater that are traveling through the area and I try to answer them back too.
  5. I can give a perfect example of what happens when you use the wrong impedance speakers in car audio systems. Back when Chrysler used the Infinity speakers and cross over amplifiers for their premium sound systems, they used Infinity 4 ohm speakers. Replacing a 4 ohm speaker with an 8 ohm speaker results in horrible sounding and muffled music. Yes I learned that lesson the hard way. I replaced a door speaker on my 2002 Jeep Liberty and didn't pay attention to the speaker impedance. I replaced a 4 ohm speaker with an 8 ohm speaker and was very disappointed with the sound. I realized my mistake once I pulled the new speaker back out and compared it to the old speaker. SO the issue with trying to connect one speaker to two output jacks is twofold. First is the use of a stereo y adaptor in mono jacks and the other is you are getting an impedance mismatch.
  6. @MarkInTampa is 100% correct. Most Y adapters are stereo and not mono. Plus you will have an impedance mismatch whenever you go from to outputs into in one speaker. SO even a mono y adaptor won't work well or sound very good. I'm surprised that you are only getting audio out on the B side though. I tried a y adaptor and I was able to hear both A and B on one single speaker but the audio was very muffled and just down right horrible sounding. Wouxun radios do not have the ability to send audio from sides A and B out to one single channel like other brand radios do. I know my Icom IC-2730 has dual audio jacks but I can still hook up a single speaker to to the first audio port and hear both side A and B just fine. The IC-2730 also uses the second audio jack for programming and computer control functions.
  7. Well all of our club's repeaters use tone squelch so yes I use encode and decode everyday with Wouxun radios. The other local GMRS repeaters in my area also use encode and decode. My sample is small with only three mobile radios and two hand held radios from Wouxun. But I have not had any problems with encode or decode with any of them. For hand held's, I have a 935G Plus and a Q10H. I have two 1000G Plus's and one XS20G Plus. I understand how a lack of customer service can and will turn you away from a brand. I feel the same about Yaesu radios since they have a known issue with the USB ports on their FTDX10 and FTDX101 HF radios and refuse to fix the issue. Instead they want to charge $900 to replace the entire main board because of a few dollars worth of parts. I also see the same when it comes to firearms too. Some will swear off anything made by Taurus or Hi-Point. I own firearms from both companies and they have never let me down. To keep on subject. I have not heard of any issues with the tones on Wouxun radios until you brought it up here on this forum. And I am on many different radio related forums and also active on other types of forums that have a section for two way communications. I'm be no means calling you a lier or that you are not having issues. But if it was a more common or wide spread issue, we would here more about it. In the end, go with what you like and also what works best for you.
  8. I have watched that video too. But most people are not going to even attempt that repair themselves. And Yaesu is ripping people off by charging $900 to swap the entire board out on the FTDX10 and FTDX101D. Again they know there is an issue but won't fix it. The main thing to keep from blowing the USB port on Yaesu radios is to make sure the radio and computer are both turned off before messing with the USB cable.
  9. I have both and can't tell a difference. Now most baofeng's and even the Icom IC-T10 have wide open front ends that are easily overloaded and pick up more interference.
  10. I will give one word of caution about the Yaesu FTDX10 and FT710. NEVER plug in or unplug the USB cable while the radio and computer are both on. You take a big risk of blowing the USB port by plugging the USB in or unplugging it with everything powered on. And Yaesu will only fix it once under warranty and only for the original purchaser. Otherwise it is a $900 repair since they have to replace the entire main board. Several of us have had the USB ports go out on the FTDX10 and FTDX101. And the Yaesu tech said they will only repair the rail once under warranty for the original purchaser. If the USB pops a second time and/or you are not the original purchaser then the repair will cost you $900. The tech even suggested using an external sound card. SO Yaesu knows about the issue but won't fix it. The USB port is out on my FTDX10 so I ended up getting the Yaesu SCU-17 external sound card for digital modes. I have since gotten myself an Icom IC-7300 which is much easier to use and the controls are more ergonomic. That is a common complaint about quite a few of the different Yaesu radios. This is especially true about the menu system on pretty much all of them.
  11. Normally one would put a second vertical antenna up that is a 1/4 wave length away from the main radiating antenna to get some gain and directional characteristics. A 1/4 wave for GMRS is only 6 inches. So that chances of that happening are definitely less with the antennas spaced at 1 1/2 feet apart. Yes there is still a chance of making the GMRS a bit more directional but not like if the CB antenna was only 6 inches away from the GMRS antenna.
  12. You normally want the antennas to be at least a 1/4 wave length apart which is not going to happen with the CB antenna as you would need 8 1/2 feet. My brother runs a Comet 2x4SR multi band VHF/UHF antenna on the top of his truck cab with a Tarheel HF antenna mounted to the left front corner of the truck bed. Has has at least 3 foot of separation between the antennas and he has no issues. You might find that the CB antenna does act as a reflector for the GMRS antenna being 1 1/2 foot away which can cause the GMRS antenna to be more directional. The only way to know for sure is to try it out. You should not have any interaction when it comes to transmitting since we are talking about 11m vs UHF.
  13. I've never messed with a B-Tech mobile so can't comment. But I have had a Midland MXT500 and still have two Wouxun KG-1000G radios. The Midland would only put out a max of 38 watts on high while both KG-1000G's put out between 48 and 50 watts on high. And yes if you read the fine print in any radio specs, most will say up to a certain watt. Most of the time you will only see the maximum when the radio is connected directly to a SWR meter, you are using good low loss coax and your antenna SWR is 1.0:1 or you are using a dummy load. Higher SWR and lossy coax will cut down on the power output.
  14. I think you will be happy with the TH-7800. I've only had mine since October 2023 but both have worked just fine.
  15. The TH-7800 in my vehicle has done well over the last 15 months being exposed to sub zero temps to 100+ temps inside the vehicle. The only negative I have is the mic is hot and there is no way to adjust the mic gain. I just make sure to hold the mic at an angel which helps. Watch R&L electronics for when they have the TH-7800 on sale. That being said, the Icom IC-2730 is worth the upgrade as far as the radio itself goes. I use mine in the shack so I didn't need the mounting bracket. I do agree with you that Icom is bad about gouging for the mounting hardware and accessories though. I don't even use the mounting brackets for the main units on my radios in the vehicle, They sit under the seat and the remote heads are mounted to a Lido seat bolt mount.
  16. That is the same reason I bought the TYT TH-7800. And the first one worked well enough that I bought a second one for the vehicle. The one in the shack has since been replaced by an Icom IC-2730 but that TH-7800 is now used for Winlink. And the TH-7800 is still going strong.
  17. That has to do with the tint that is built into factory windows. Some tint has enough metal in them to mess with reception. I have even seen people have problems with the glass mount antennas like what nokones posted. Granted not everyone has had reception issues with these type of antennas but some have. It depends on the tint used and how much metal is in it.
  18. That is one of the issues I have read about the TH-9800. I'm thinking it has something to do with it being quad band since you don't hear about the TH-7800 having that issue. Wouxun makes their KG-UV980P quad band. I can't comment on its quality since I have never used one. That being said, the Wouxun KG-1000G is based off of the 980P with a different firmware and it is a good radio. Now if you don't mind using a dual band radio then the TYT TH-7800 works pretty well. The only complaint I have about it is that there is no mic gain settings and the mic is hot. But that goes with most CCR mobile radios, none of them have adjustable mic gain. You have to remember to hold the mic at a certain distance and at an angle.
  19. Yes you can program extra channels on the MXT500. I forget if the MXT labels the repeater channels as Ch 23- Ch 30 or RPT 15 - RPT 22. Say you have two repeaters in your area that use the repeater channel 19 which is 467.650 (RX on 462.650). You can set the tones for the first repeater on the pre programmed RPT 19 ( channel 27) with the correct tones. Then add a custom channel in any memory slot above RPT 22/Ch 30 using the same TX/RX frequencies (467.650/462.650) and then put the tones for the second repeater in. Doing that will keep you from having one channel where you have to constantly try to change the tomes to use the different repeaters. I have two repeaters in my area that use the RPT15/Ch 23. I programmed the first repeater in the channel memory slot 31 and the second in channel memory slot 32. I also set my radios to display names instead of channel numbers which helps keep different repeater on the same channels separated and easy to find.
  20. I'm another one that wished I would have taken the general test on the same day after passing the technician test. I started studying for the Extra but got distracted by too many squirrels to chase - digital modes, Winlink, AllStar, CW, etc.......
  21. Myself and others have quite a few of the Wouxun UV and KG series radios. And none of us have had any issues with tones not working as they should. And NO I am not sponsored by Wouxun, Buy Two Way Radios or anyone else. I am going to give you honest answers when asked to the best of my ability. Again I have not heard anyone having issues with the CTSS Tones on any of their UV or KG series Wouxun radios.
  22. The clicking is not normal. I'm curious to see what is causing it.
  23. The TH-7800 and TH-9800 use the same password unlock to open them up. Though you must use the official TYT programming software to do so. I went with the TH-7800 dual band since there is no 6m or 10m FM repeaters near me and the fact that a 6m and/or 10m antenna would be way to big to drive around with all of the time. I have one TH-7800 in the vehicle and the other is setup in a go box for Winlink. I have not noticed any clicking noises like @Wayfarer has with my TH-7800's so maybe it is something with the TH-9800's.
  24. The Comet 2x4SR is an excellent multi band mobile antenna. Since you said that you can get into that repeater with an HT then yes going to 20/25 watt radio will improve things. Stepping up to a 40/50 watt radio will definitely improve things. I have a repeater that is about 50-55 miles away that I can get into with a 20 watt radio but the other people hear a lot of static on my transmission. Everyone can hear me clearly when I use a 50 watt radio. Basically you have to quadruple the power output to notice any big difference. I am still going to suggest going with the Comet CA-GMRS for a few reasons. One is that it is light enough at only 2 pounds. Second, it has a wind load of 135 mph. And you can also get rid of the pizza pan that will definitely act as a sail in high winds. The CA-GMRS is lists at 5.5 dBi which is 3.4 dBd. The 2x4SR is listed at 6.2 dBi ( 4.1 dBd). Plus you would still have to use a metal pan for your ground plane which is a wind sail. I can't tell in your photo if your roof is fairly flat or has a ridge. Getting your antenna up some more and going with a mobile radio will improve performance for you.
  25. You now have so many more squirrels to chase, especially once you get your General.
