46
Everything posted by WRYZ926
I very well could be wrong on that. I will have to look that information up again. I thought that FRS was limited to 2 watts and GMRS hand held were limited to 5 watts. Okay straight from the FCC: https://www.ecfr.gov/current/title-47/chapter-I/subchapter-D/part-95/subpart-E/section-95.1767# It only states that the 5 watt limit is for the interstitial channels AKA channels shared with FRS.
You are correct that the regulations state 5 watts maximum for a hand held and 50 watts for a mobile on GMRS. Unfortunately that won't stop some from running amplifiers. CB is another prime example, it is limited to 4 watts yet people run up to 1000 watt amps on CB.
How and where do you have the antenna mounted? And you say you are transmitting on 462.575 and 462.725. You should be transmitting on 467.575 and 467.725 in order to talk to the repeater.
@WSAE637 is repeater mode turned on in your MXT275? Another question- are the repeater channels set to wide band? The reason I ask is that I had to turn that on in my MXT500 before it would transmit on repeater channels.
Glad I could help.
Are there minimum requirements for a repeater to be added?
WRYZ926 replied to WRZM759's topic in myGMRS.com
When we first set our repeater up, several of us just drove around in different areas within a 25-30 mile radius of the tower. I know that is not the best way to test but that is how our amateur radio club members did it. We are getting up to 30 miles range with 50 watt mobiles depending on the terrain. The nice thing is between all of us, we found out exactly where the dead zones are. We are using a Bridgecom repeater and the antennas are 400 feet up on the tower. No matter what type of repeater setup you have, you want to use a good antenna(s) and get it as high as you can. -
It's been a long time since I heard the term puddle pirate. We were usually too busy giving the Air Force, Navy, and Marines trouble that we would forget to pick on the Coasties. And yes you can give me trouble about being a round ponder, glorified grunt with a shovel (combat engineer) and jumping out of perfectly good airplanes since you served also. And I will give you a little bit more trouble. You have to remember the 10% rule - you have to be 10% smarter than what you are trying to operate. On subject. Yes make sure you are on the repeater channels. They will be labeled as RPT15 through RPT22 on most radios or might be labeled as Channels 23-30 on some radios. Those channels will automatically set the proper offset so that you can talk to and hear the repeaters. And make sure to set the tones correctly if needed. Don't be afraid to ask for help as there are plenty of people willing to assist new people.
I do believe the KG1000G is the same radio as the KG-UV980P. What I do not know is if the UV980 firmware will work on the KG1000G. I would hate to see anyone brick their radio though. Even the Wouxun amateur band radios seem to be more difficult to unlock and I too have not found a way to unlock the KG1000G. The TYT TH-7800 and TH9800 are simple to unlock using the TYT programming software. Not that I would tell or suggest anyone do that.
Like I said in my first reply, this can be an argumentative topic at times. It can be as bad as asking what type of oil to use in your vehicle or what type of lube to use on your firearms. Read the NEC concerning antenna towers/masts, etc along with the link provided above, watch some videos and then decide what YOU want to do.
It might only be 4 foot on your setup but it is not on my setup with my antennas up above the roof. But hey, you setup things how you want and I'll setup things up how I want while sticking to NEC codes. Have a nice day.
Actually the lightning arrestor goes on the coax right before it enters the structure. in that hand drawn picture you have it up at the antenna end which is wrong.
Midland MicroMobile Replacement/Substitute Microphone Needed
WRYZ926 replied to Over2U's question in Technical Discussion
Well you do you. I have had Midland and still have Baofeng radios and they do not compare with Wouxun radios when it comes to quality, performance, etc. The Midlands are all gone and while I will keep the Baofeng hand held radios around, I will not buy another Baofeng again. Sometimes it does good to head the old saying "buy once, cry once" -
I never received any messages.
I was only recommending a very good and reliable radio. And I would take that over any Midland Baofeng, or other cheaper brands. But that is me. If the OP is on that tight of a budget then getting a replacement mic is his best option. -
This is all covered by the NEC (national electric code). It is worth looking the regulations up and reading them. As mentioned your coax shield is grounded to your radio which in turn is grounded to the home ground at the outlet. That is why one should use lightning arrestors on the coax before it enters the structure and also to have everything grounded and also bonded to the service ground. That gives the electric a shorter path to ground. And the lightning arrestor should also keep the electricity overload from entering the structure. Grounding can be a touchy subject and people will always argue about it. I prefer to be safe than sorry and have ground rods at each antenna mast/tower along with a ground rod right at the wall passthrough where my coax cables enter my house. They are bonded together and to my service ground..
If you plan on replacing your radio then look at the Wouxun KG-XS20G Plus 20 watt mobile. It is a lot better than a Midland radio. I have one mounted in my SxS connected to a Comet 2x4SR antenna and get great signal reports from everyone using the repeater that is 21 miles away. -
As mentioned, you transmit and receive with your radio set to a repeater channel. Make sure you are on a repeater channel and also that you have any tones set correctly.
You need to be transmitting on the repeater channel on 467.575. GMRS repeaters receive on 467 and they transmit on 462. And yes you will hear the repeater on a simplex channel, that is normal.
Getting the offset wrong will drive one batty. You can't always go by what repeater book says either.
- 13 replies
- Wouxun KG-UV920P-A
- KG-UV920P-A
(and 1 more)
Tagged with:
Good for you for getting your amateur license too. To answer your question about the Comet CA-712. It comes tuned for GMRS and is an excellent base antenna. I have one mounted to a satellite dish type j mount at the peak of my roof and am using LMR400 cable from it to my radio.
The area is a mixture of river/creek valleys, gentle rolling hills and flat farm ground. But I can get into the GMRS repeater at 400 feet with a HT better than I can get into the 70cm repeater at 900 feet. Getting into the GMRS and 70cm repeaters in my vehicle with 50 watts radios is about the same, it depends on the terrain and trees. The thick rows of red cedar that grows along the roads here really messes with UHF signals.
The need to use plain language without attempts to decieve also goes for amateur radio too. And no new digital mode for amateur radio can be used without first making it public per the FCC. Business bands and public service band fall under different rules than amateur and GMRS bands.
I found that video pretty informative. I also own an Icom IC-T10 along with the KG935G. Both are very good radios even being SOC. I know there is a difference when it comes to VHF compared to UHF. But I can use the IC-T10 inside my house and still be understandable by others when talking on the repeater 21.5 miles away. It is sometimes hit or miss with the KG935G inside the house. I can forget about getting into the 70cm repeater with an HT though. All three repeaters use the same tower. The 2m and 70cm antennas are 900 feet above the ground and the GMRS antennas are 400 feet above the ground - all of them are on the same tower.
Smiley Antenna Slim Duck GMRS 465MHz 5/8 Wave.??
WRYZ926 replied to TNFrank's topic in Equipment Reviews
I have a few Abbree 771 and Nagoya 771 antennas for 2m/70cm and GMRS. The 771 antennas do make an improvement on my Baofeng and Explorer QRZ-1 (TYT UV-88). But I did not see any improvement with those antennas on my Wouxun KG935G or Icom IC-T10. -
I haven't had any issues with my CCR radios either. In fact I got rid of all my Midland radios and replaced them with Wouxun radios. The Wouxun radios are built better and work better. And even the top Japanese radios either built with Chinese parts or built in China. And I guess everyone's Apple or Android phones must be junk since they are made in China too.
