17
Everything posted by LeoG
I set my KG20+ up as a base station using a Pyramid Power supply. The description fooled me into thinking this was a 7 amp power supply when it is really a 4.5 amp. 7 amp is the surge rating. Either way, it works fine and I have full output from the transmitter. I get between 20 and 25 watts out depending on the frequency. I don't transmit that much on the base station as it's more for the wife to listen. But so far the power supply has performed to spec and the radio works just like it should.
Originally the same amount of channels in CB as GMRS. 23 for CB and 22 for GMRS. The they went to 40 and added SSB which just annoyed people. Just like putting digital on GMRS
Probably done by truckers to help their brethren.
The Future of Linked Repeaters??? Must Watch!
LeoG replied to marcspaz's topic in FCC Rules Discussion
Says no linked repeaters. Clearly means you aren't allowed to use a linked repeater. That is how the citation will go. But I agree with you. Needs to be specifically stated. Any ambiguity in the law should benefit the accused, not the govt. -
Now that's getting into the nitty gritty. There is no regulation saying you can't use a linked repeater. There is (seems to be) a regulation saying you can't link repeaters. Again the FED will assume that one means the other. But as you said, it isn't written anywhere. -
I don't think CH9 being an emergency channel was ever an official decree. It was made that way early on. I could be wrong.
The members of the club used it knowing it was a linked repeater. When I used it, it was my first time and I was clueless to it being linked although I figured it out after 2 days from hearing conversations way out of range of the repeater I connected to. Ignorance of the law is no excuse.... Which is something I never bought. Because law enforcement and the judicial have so many laws and antiquated laws on the books no one can keep track of them. -
Repeater question - TD-H3 GMRS, Tennessee Valley / North Alabama
LeoG replied to WSDA306's question in Technical Discussion
I'm just assuming it takes a pretty big hill to stop the signal, or a bunch of smaller ones in succession. The signal makes it over the hill still above your radio but because of propagation of waves it starts creeping down again. In the shadow of the hill and as you get farther from it you can get more signal bleeding down. One of the main reasons not to have a super high gain antenna in a hilly area. If you laser beam your signal in one small plane it will get absorbed more by an blocking object. -
If you have vertical "walls" of rock it will. But in my case it's hills and I wouldn't expect a bounce to put the signal where I want it. -
We be doin' some bouncin then -
Oh darn. It's showing information that isn't corresponding to my results for me. Or my signals are punching through hills. This is my repeater (gr) and my sisters location (bl) and I was happily talking to a friend across the river through the RT97S repeater. Just seeing a red line doesn't equal no signal. And I had a very nice signal talking between two 4.5 watt HTs and the repeater. -
Great reference ! -
Here is your area in the topographical map. Have fun https://en-gb.topographic-map.com/map-gn9tp/Connecticut/?center=44.45529%2C-87.92378&zoom=14&popup=44.44725%2C-87.92001
The maps I use work off of ASL so that's what I'm using. You can do the extra math if you'd like. Both are relative if I stick with ASL or AGL and don't mix them
Which is why I want to set the repeater up at my shop which is 48 meters above sea level plus I need to put the mast at least at 60' to get above the tree line which would put me at 56 meters.
Well I looked on google maps and found an ideal path for the signal and had to see if I could get it to work in real life. It had a bunch of signal travel over the river and not a lot of dense forest. Using a interactive topographical map the end point is 19 meters at ground level, it says I'm 21 meters. It did pretty good, about 50% signal strength on the Wouxun signal meter in the truck. Dropped off pretty quick after that. I made a big circle to come back and I traveled over the river and I was surprised that I got almost nothing for a response. Just random low power jitters. Came back up the interstate and really didn't get a reliable signal until I was about 3.7 miles away. And now I see why. It's the hills... My antenna is at 33 meters (21m+42') Can't get through that 40 meter hill. My shop is at 48 meters and then 60' of mast would put the antenna at 66 meters and I would be able to get past those hills. Which is why I want to put the repeater at the shop.
You really don't get that I don't live in a desert with no obstacles. Everything around here is hills and trees. The antenna is at 42' off the ground so 105' altitude above sea level. I'm in the upper middle of a hill at 62' ASL and the top of the hill is at 85' ASL, so effectively I'm at about 20' above ground level. The trees around here are 70' tall. I'm obviously running the RT97S and that is outputting 7.8 watts into the coax. I have a 1.92dB loss so it's 5 watts at the antenna and it's a 7.2 dBi (5.05 dBd) gain antenna so effective radiated output is around 15 watts. I'm sure if I lived where you did I would be getting 30+ miles out of the repeater. But around here you get 5-7 miles best case. 2-3 miles is the usual. I want to get my shop antenna above the trees so I'll need it to be 70-80' above ground level which would put it at 170' ASL, still pretty low.
So since I put up the antenna at my house I decided to try the repeater here. So I could get out to about 4.6 miles and hit the repeater but the signal was weak. I came in about 1/2 mile and the signal was much stronger. Rode around town and checked out different distances. Most of them were about 2-2.8 miles out and had a good connection just driving around with my mobile radio. Anything within 1.5 miles was full quieting or close. I went to the shop where the repeater usually is and was able to hit it and talk. It was scratch because of all the trees. But if I went out to the road it cleared right up because the trees are out of my way. So I suspect if I can get my shop antenna up above the trees it should do quite well. The shop is on ground 100' higher than the house.
Digital is a newer tech. It isn't compatible with analog to share the same frequencies.
Seems to be an epidemic up near another repeater I frequent. The seem to think it is a pair of cranes lifting large beams that are communicating with each other. They don't know if it's automatic adjustment between the two cranes or the guys running them communicating with each other or others. But they know since the 2nd crane got there the interference has been brutal for them on the 575 I'm not sure if I get any of that, but I do get bleed over from my problem onto the 575 along with the worse interference on the 625
As long as you get to play with the radios first....
Club memberships required to use (aka Pay to play)
LeoG replied to UncleYoda's topic in FCC Rules Discussion
Usually only a couple of the mods do 90% of the work. The rest like the glory. I take care of politics and religion in one of them..... That can be fun. -
I'm a admin on one and a moderator on another forum. I get paid $50 a year for one, get a gift card and the other isn't paid. It's not a requirement to moderate. Come as you please and if you see something you clean it up. You get a dozen volunteers across the nation and you have the time slots all covered. -
Cry, they are coming this way out of school, both grade and college. -
You have to transmit the codes from the TD-H3. Put them into function 13, Tx CTCSS. Put the H3 on the frequency and then press the blue button, press 1 then 3 and press the blue button again and then the up button until you reach the proper tone and press the blue button again. Should transmit and receive after that.
