106
Everything posted by Lscott
A few people have used a wood utility pole as a cheap antenna tower. Of course the issue is lighting protection and how do you get the antenna up there and service it later. You can use either certified climbing gear, or better rent a bucket truck for a few hours. Oh yes, you will sooner or later have to check/repair/replace the antenna and cable, maybe more than once, at some point. This goes for any place you put your antenna. That might change your mind on the mounting location.
What’s in a Faux Nagoya (not a question)
Lscott replied to SteveShannon's question in Technical Discussion
Some people feel the switch to SMA, from BNC, on HT's was a mistake by the major manufactures. The opinion is BNC connectors are physically stronger. -
This a Kenwood NX-1300AUK5 upgraded with the DMR license, and the enhanced 40 bit ARC4 encryption option license (DMR only and compatible with Motorola's Enhanced Privacy setting), effectively a NX-1300DUK5, so it will do both analog FM, wide and narrow band, and DMR conventional operation. This radio can also be loaded with the NXDN digital mode, which requires another feature license being added to the radio. The radio will do analog FM and either one of the digital modes depending on which firmware is currently loaded on the radio. It will only do one digital mode at a time. I have a collection of NX-200's/300's series radios for NXDN so I don't need that mode in this radio, I'm just interested in DMR. https://comms.kenwood.com/common/pdf/download/NX1K_Specsheet_K.pdf The radios I purchased have the 400-470 MHz band split so it's a perfect fit for Ham 70cm and GMRS. You only need one radio to cover both services on UHF. Currently digital voice is not authorized on GMRS so the DMR feature is only usable on the Ham band. Although it's not Part 95E certified, Just Part 90, it can be used on GMRS if it's programed carefully. So far the FCC hasn't been clamping down on Part 90 radios used on GMRS but it's not a guarantee they won't later. One nice feature is the radio can do front panel programming as a standard feature, you only need the display with the limited keypad model, when enabled in the programming software and the code plug loaded into the radio! I believe you also need the software to enter the alpha tag, otherwise it's set as CH-xxx where xxx is the current channel number. Not perfect but many commercial radios you can't program from the front panel at all, or if you can it's an extra cost item and you're still limited to narrow band FM. I now own a bunch of these radios currently. I paid $400 for the new one BTW in the photo. The rest are used but in like new condition. A couple were analog only but upgraded, license key written to the radio, to DMR. Effectively NX-1300DUK5 models. All the radios are now enabled, license key, for ARC4 40 bit encryption as well, about another $30 for it per radio. One has the NXDN firmware loaded, but doesn't have the ARC4 encryption option available. I just recently purchased a used NX-1200DVK2 radio in very good condition. It included the base radio, antenna, battery pack and charger base. The price was about half of a new radio. If the radio doesn’t have ARC4 enabled I have a quote to get the feature license to add it in. It’s pretty cheap. There is a cracked version of the programming software available so you can avoid the cost and hassle of buying a license key and the PIA license manager garbage with Kenwood's servers. You'll have to register (NO COST) and join the group to gain access to the file section. The below link has the cracked software and mostly current firmware files. https://groups.io/g/kenwood/files/NX Series/NX1xxx-3xxx-5xxx/KPG-D6 Documentation for the radio, service manuals, user manuals, programming manual are located at this link. https://groups.io/g/kenwood/files/NX Series/NX1xxx-3xxx-5xxx/Docu/NX-1200_1300_1700_1800 Series/NX-1200_1300 HT's The cracked software also allows wide band over the full frequency range too. Otherwise that's another extra cost license option for the programming software you can avoid. -
After being disappointed by one, or more, you learn why people spend a lot more money on better radios soon after. I have a buddy at work that purchased several Baofengs for GMRS. I got him to spend money on a good clean Kenwood TK-3170 commercial radio. https://forums.mygmrs.com/gallery/image/263-tk-3170jpg/ Since he started using the Kenwood he doesn't bother with the Baofengs, and comments how the Kenwood works better. With these cheap Chinese radios, CCR's, you get what you pay for, and maybe not even that is some cases. ?
Isn't that what the radio is used for? ?
Lscott replied to WRAX891's topic in FCC Rules Discussion
I see there are some repeaters on P25. You going to do any for NXDN? -
I was reading the post as activating a new repeater. I was wondering if another one besides the Detroit and Mt. Clemens machines was going in some place. I was talking about the above repeaters at our Thursday night coffee group meeting. One of the Hams mentioned your name I believe. He has the cross-band repeater in Melvindale. Another Ham in our group just put up a repeater on UHF a short while ago. I was suggesting he could get his GMRS license and put it on the band. That would provide coverage out on the west-north-west side of the Detroit area. I believe he has access to emergency power at the site. -
One of the new GMRS repeaters by me does so using a female voice. It even announces it’s an open repeater and the access tone required. -
Where do you plan to locate the repeaters in the area? -
Oh, if you're worried about getting the channel selector set to the wrong position on any of the radios. Just program all the channels exactly the same. Then it doesn't matter where the channel selector is set.
A similar radio to the VX-231 from Kenwood are the TK-3160 and TK-3360 16 channel radios. Neither one is Part 95 certified however. The TK-3360 is a somewhat newer version of the TK-3160. Both are basically idiot proof. There are only a channel selector, volume control, transmit button and two optional programmable side buttons. You could give one of these to a 5 year old and not worry much if they will much something up. TK-2360-3360 Brochure.pdf TK-2160_3160 Brochure.pdf
Good question. I never got into the details of what the technical qualification are pertaining to frequency range to get certification under the various FCC rule parts. It could just be Kenwood felt the 450-520 band split was a better fit to cover the commercial market. Before the rule changes businesses could get a GMRS license. The 400-470 band split doesn't cover the upper end of the commercial market. It's likely a better fit for markets outside of North America.
You're going to find a lot of Hams on this forum too. There is nowhere for you to hide.?
I have identical radio models where the only difference is the band split. For example my NX-300's come in two band splits, 450-520 and 400-470. The 450-520 has Part 95A while the other doesn't. Both FCC grants are dated for 2013 prior to the rule changes. NX-300 FCC Grant - 2.pdf NX-300 FCC Grant - 1.pdf
Another suggestion is the TK-3170. I carry that one around myself. There is also a TK-3173 which is about the same except it will do trunking. For GMRS you don’t need that otherwise the radio is the same as the TK-3170. The TK-3140 is a good radio as mentioned above. The difference that might make a you pick one over the other is the side port used for programming and options like speaker microphones. The TK-3170 uses the same type of plug that many of the cheaper Chinese radios copied. Also many times you can use the same programming cable too. The TK-3140 uses what Kenwood calls a universal connector. It has 14 spring loaded pins on the plug that makes contact with the pads on the side connector port. The nice thing with this is it keeps dirt and water from getting inside of the radio. That’s the problem with the other radios I mentioned if the port isn’t covered or an accessory plugged in it. There are other commercial grade radios that fit you requirements others here have used and will recommend. TK2140_3140.pdf TK-3173(K) Brochure.pdf TK-2170_3170(K) Brochure.pdf
I'm waiting for delivery on a new NX-1300DUK5 radio with display and standard keypad. This particular model has the ability to be front panel programmed without any hardware modifications or license key loads. One of the option license keys for it enables the 40 bit ARC4 encryption feature. It's a "cheap" license, around $30 more or less. I know it's weak encryption, and has been broken. If a number of radios use it them I might spend the money and upgrade it just to experiment with it. The one nice feature is no key-loader is required, for example AES and DES. My question here what radios currently use this encryption standard? NX-1300DUK5.pdf
- 1 reply
- encryption
- arc4
(and 1 more)
Tagged with:
Well, there aren't that many non ground plane antennas to choose from. Another point is a non ground plane antenna needs an internal load matching section. That adds bulk and cost to the antenna over a simple 1/4 wave design which needs a ground plane and no load matching section. It's possible that more non ground plane antennas will be marketed as more vehicles employ plastic in the roofs and other body panels to save weight and cost. For those you don't have much in the way of options.
I think some other members here have clarified that for you. Don't be one of those that fail to ID. There are a surprising number of Hams on GMRS. The DF equipment that works on 70cm works just fine on GMRS too. ? -
What makes cheap coax cheap, and expensive coax expensive?
Lscott replied to Blaise's question in Technical Discussion
It's split mainly between dielectric losses in the isolating material between the center conductor and skin effect losses in the conductors. The geometry has an indirect effect on both. https://www.resonac.com/solution/tech/transmission-loss.html -
For your application I think it would work just fine on transmit. The radio does have a GPS receiver. I don't know if it will pass the GPS satellite signal from the antenna to the radio. There is a filter network internal to the amplifier that would likely block this. In that case your GPS would be non-functional. This would not prevent you from getting APRS packets from another radio however. If the radio has it's own internal GPS antenna then the amplifier won't be an issue. You should be able to get good position data for sending APRS packet info.
That depends on the transmitting radio and the mode in use. The main difference between the two models is the AMP-U25D will work with digital transmitting modes like DMR, P25 Phase 2, TETRA, etc. All of those use a form of TDMA, time division multiple access, which means the radio's transmitter is switching between transmit and receive many times per second and the amplifier has to keep up. The other digital modes don't do this thus the AMP-U25 will work fine. For the small difference in cost I would get the AMP-D25U. At some time in the future you get your Ham license, if not already, and want to try out some of the digital voice modes the amplifier will work. In Ham radio most of the digital voice mode activity seems to be on the UHF 70cm band anyway. One big caveat, the amplifier IS NOT FCC Part 95 certified. AMP-U25D Users-Manual.pdf Internal-Photos AMP-U25D.pdf Review BTech AMP-U25D.pdf Test-Report AMP-U25D.pdf
Nothing like getting a high-resolution photo of the porch pirate giving your camera the thumbs-up as they run off with your Amazon delivery.
Question, if the application is for a nation wide Itinerant frequency does it still have to go through a coordinator? I thought I read it doesn't.
In all fairness I think he wanted to cover all the bases and tried to avoid most of the objections. He does have a sort of dry sense of humor, entertaining to watch. There are some points he makes in the videos that I think are wrong or disagree with, but nobody is perfect.
Who ever came up with that had a major brain F--t. In all fairness it was likely done due to the band getting crowded with all sorts of modes and specific uses. With only 4MHz of bandwidth that can get allocated quick. On UHF the usual 430-450 gives one 20 MHz of bandwidth to use. South of Line-A it's 420-450. For example the vast majority of digital voice operations you'll find on UHF. Most likely due to more room to accommodate it.
