106
Everything posted by Lscott
I’ve found a few over the years. Or sure how accurate they are. SCHEMATIC Baofeng UV-5R.pdf TH-9800 Schematics.pdf PCB Layout.pdf
SWR scan on three different antennas
Lscott replied to MarkInTampa's question in Technical Discussion
I’ve heard they are wide banded and popular with scanner users. This is the first I’ve seen an SWR sweep of one. -
I would be interested in seeing them. Sometimes antennas perform better than the manufacture's specifications.
Do you have any reliable SWR measurements you made for the various bands/frequencies used?
Welcome to the club!
Kenwood radios can be setup for wide or narrow band. That is based on which version of the software is used to program a particular radio. The older radios had software that allowed one to select either wide or narrow band. Nothing special was required other than a valid installation key. Newer radios it's more complicated. There are so-called "Engineer's" keys used to install the software that allows, among other things like password removal, to select wide or narrow band. Newer version of the software Kenwood has disabled the use of the Engineer's keys. For those if you search around there are "wide band" keys used during software installation that allows wide and narrow band. You can likely order, buy, the key from a Kenwood dealer along with the software. For some of the radios there are cracked or "Lab" versions that allow even more features than even the Engineer's keys allowed. Anything preceded by an asterisk is a special cracked feature that was enabled. For example in the sample photos I show what one can do. I even used it to recover the trunking system info from a used NX-200 VHF NXDN digital radio I purchased from eBay using the service function. This is something you should NOT be able to do without getting a "System Key File" from the owner of the trunking system! On another site forum a repeater owner said it wasn't possible when somebody asked. I posted the same photo there too.
Just looked. I think this is what you want to use. https://www.winhelponline.com/blog/view-winhelp-hlp-files-windows-10-with-winhlp32-exe/
I forget where but there is a file you can down load from Microsoft that allows you to open and read the old type help files. Just note even with the utility you can’t directly open the help file from within the radio programming application. I ended up just creating a link to the help file itself and setup Windows to use the utility to open it.
I would leave it alone. To trim a dual band antenna for another frequency involves more that just shorting the radials. I would recommend you look for a GMRS specific base antenna. Members here have some very good recommendations they can offer.
I think the concession counter is still open.
Good question. This is one of those areas that can be very subjective. Some people will find the audio response satisfactory for a given test sample while another may dislike it. One sample may sound OK on a given radio's RX while on another it won't. Just another wrinkle to think about. The one thing that is important is the microphone's sensitivity. I have a soft voice so I tend to set the "gain" higher, there is a setting for this in my commercial radios, and I don't know if there is anything like that for some of the inexpensive radios. Some radios have an auto gain control function. There is also an audio equalizer for both TX and RX audio in the analog/digital radios I have. Just IMHO the larger speaker microphones the RX auto does tend to sound better due to the larger speaker. The smaller speakers tend to distort the audio at higher volume levels. This is a consideration when the radio must be operated in a high noise environment. In the end it's all about "communication" and so long as the party on the other end can understand your speech clearly that's what really matters.
Programming Motorola XTL5000 or CDM1250 mobile radios
Lscott replied to VETCOMMS's question in Technical Discussion
That's true with every DMR radio I've ever setup. The 16 channel limit, per zone, on the 6550's was a PIA besides trying to figure out what Motorola called stuff verses the Kenwoods I've done. Besides being time consuming it's tedious. Make one small mistake and it doesn't work. -
Any more theories about the radio? Is there a list of what radios are known to be used by all sides in the conflict there? I've looked at the spec's for the radios used in WWII, Korea and Vietnam. When I watch some old war movies I try to see what kind/model of radio they used. It's shocking how little power output the manpack radios had during those times. Anywhere from a few hundred milliwatts to a watt or so. The radios were really the size of a backpack. Now you get more power and performance out of something that fits in a shirt pocket. https://en.wikipedia.org/wiki/SCR-300 https://en.wikipedia.org/wiki/AN/PRC-77_Portable_Transceiver
"No Ground Plane" antenna on Ground Plane mount
Lscott replied to Extreme's question in Technical Discussion
Note that a 5/8 wave is NOT a "No Ground Plane" antenna. -
Lscott replied to Lscott's topic in Amateur Radio (Ham)
On the NX-200/300 series radios the programing cable should work for the data communications too. The programming software uses the serial port. The wrinkle is when the port is used for data exchange. The port works a bit different. Since it's used to program the radio it's obvious it can't be a "full time" serial data exchange port when you setup the port in the radio programming software. Apparently what Kenwood's firmware does is looks for commands from the programming software running on the computer to start a radio write operation for code plug loading. That has to happen within the first 10 seconds after the radio is powered up. After that the port reverts to the serial data exchange mode. You have to be quick and ready to click that write button when you turn on the radio if you want to load a code plug, or read one out. -
I've seen stuff like the item in the link below at swaps from time to time. Has anyone played with one? https://www.ritron.com/dtxm-nx-series-radiomodem-transceiver-nxdn-data-only-protocol -
Technically the base of the mount and the metal under the paint form a capacitor. The RF current, for the mirror imaged half of the dipole, flows through that capacitance. The capacitance you get is a function of, the area of the base, space separating the base of the mount and vehicle body metal and the dialectic constant of the material between the two. You would ideally like the that value, capacitance, to be as high as possible resulting in a low capacitive reactance. The lower the effective capacitance, higher reactance, the more it will affect the SWR. You can try shimming up the mount using anything that’s none conductive then check the SWR. Once you get enough space between the vehicle’s body and the antenna’s base the SWR will rapidly go to crap. Some people have experienced poor SWR using cheap magnet mounts with a tiny base on a vehicle that has a thick coating of paint on the metal body. Oh, the increased space between the magnet mount and the metal body will reduce the holding force too. Having the mount break loose at highway speeds usually doesn’t end well.
It's a hobby. People will comment about the money I've spent on my radio collection and electronic test gear. I ask them how much did those new snowmobiles motorcycles and boat, they use just a few months out of the year, cost them. The silence from them is pure gold. -
I don't think I've notice that. Next time I get around to playing with the XPR's I'll look for it. Anyway that's cool you can do cross band and cross mode repeat. Do you know if the audio is sent in digital format between the two radio decks or is it analog? I'm assuming it is. Another question can those radios be setup for an auto ID using CW? Just about every radio with builtin cross band repeat I know about has the same problem. No way to do an auto ID. The NX HT's I have include a CW ID function, but it's not automatic. You have to assign it to a function key then press it to send. The screen shot is from a NX-200/300 HT setup. I looked at the P25 radios I have, TK-5220/5320, and they don't have this feature. Sort of odd since at one time you could get Kenwood convert your radio, NX-200/300 <-> TK-5220/5320, from one to the other. I'm told that's no longer offered. I though about how cross band would work using a couple of hand held radios. The coupling would have to be done using analog audio. A lot of processing is done on the analog signal in the course of conversion to digital, then couple that with another from digital to analog, then the reverse on the second radio would result, I would assume, in some serious degradation in audio signal quality. On a different topic how much has this setup cost you so far? -
I've played a tiny bit with Motorola's RM just to see what it does. It was automatically installed along with CPS 16. I only have a few radios so the extra work isn't worth it for me. I just have to save the code plugs by radio serial number. I've though about using the Depot software to change the SN on the radios to be the same. Then I don't need to track the code plugs by SN. I'm not using anything that's specific to a radio that's enabled using an entitlement key, I believe, so that might work for me saving the tracking by SN hassle. I did bugger up one of the XPR6580's I have. Somebody had used V2 on it. I saved the tune data for the radio to a file. Then used the Depot tool to force a downgrade in firmware which also eliminated the trunking crap. At this point I had nothing to lose. Apparently you have to get rid of the trunking stuff to use the in-memory edit software hack with CPS 16 to get the radio on the 33cm band. I tried to reload the tune data and found out there is a difference in the number of parameters so it refused to load. WTF!! Boo-hiss. Now Motorola in their infinite wisdom uses the auto tune feature, in their test gear, to setup some of the parameters in the radios. The tune utility won't let you manually adjust those specific ones. Anyway I used the Depot tool to change the serial number to match the good XPR6580 I have. I saved the tune data from the good radio and wrote it to the buggered up one. Yeah some stuff very likely is not optimally set but at lest I have a radio that sort of works I can beat around and try stuff out on. This is why I sort of stick with the older Kenwood stuff. -
Even one cable likely isn't enough. I just purchased another cable for some of my radios. I keep a set at home, at work and some to take along on road trips. Then I a have a few spare cables put away. Yes I've had programming cables fail. Oh well,you spend a bunch of money buying radios a few extra for a cable or two, or three...
