106
Everything posted by Lscott
That would be great. You really need a COR contact if you want to build a repeater using a radio. Some have sort of done that on a custom basis by using a simple circuit patched into RX LED circuit.
Why really some folks say GMRS repeater linking is illegal
Lscott replied to jwilkers's topic in FCC Rules Discussion
Some other view points on the matter. There are some specific caveats pertaining to data encryption. It's not a blanket permission either. https://www.rrmediagroup.com/News/NewsDetails/NewsID/17804 https://www.qsl.net/k/kb9mwr/projects/wireless/Data Encryption is Legal.pdf -
I think if you go through present and past threads on various topics it will be obvious who those people are. Two are on my block list because I don’t want to waste my time getting posting notifications when they post their garbage. The linking discussion pertains to GMRS not Ham Radio. The question about it’s legality is murky since the rules are a bit ambiguous so it’s a gray area. Until the FCC clears up the language there is the possibility they will unambiguously make it clear one way or the other, maybe flatly prohibiting it by name. Other rules are rather straight forward, however some posters encourage operating practices, equipment modifications (software - hardware -programming), that leave little doubt it violates the rules. Demands for “proof” of enforcement actions, and lack of any, is not permission to ignore them because it’s “really” ok. Essentially the poster(s) are looking for acknowledgment from others their actions are OK to excuse what they know is wrong. I’m not playing that stupid game.
Getting the antenna up higher will make a big difference. Try to get the antenna to at least clear the roof top of your house, and any near by if possible.
That's true. I occasionally catch some DMR traffic on one of the GMRS simplex channels where I work. I verified that by using the digital monitor function on my D878UV I took into work one day just to see if I could identify the source. Nothing was said that I could use to figure out who was responsible. It doesn't happen often enough to bother checking frequently. About the rules you have a point. There are several people on this forum who have the attitude if the FCC hasn't busted anybody for an obvious rule violation then they mustn't care so it's OK to continue doing so. The worst part is when they encourage other users to do the same. -
ISS Satellite Contact a Few Minutes Ago. Advice?
Lscott replied to marcspaz's topic in Amateur Radio (Ham)
Here is some more info on eggbeater antennas. Antenne Eggbeater-Engl-Part2-Full.pdf Antenne Eggbeater-Engl-Part1-Full.pdf -
There are "gain" and radiation pattern differences between the various antennas. Also at UHF it's LOS, line of sight, so just moving even a few feet can make a huge difference when there are obstacles between the radio and the repeater location. One other item you may notice while driving at times is a flutter or rapid momentary dropout of the signal. That's commonly refereed as "picket fencing". That's due to the signal being blocked by buildings etc. so the signal path between radios, or radio to repeater, changes rapidly as you move.
Code plug hacking can be a lot of fun, getting a radio to do things the manufacturer doesn’t allow. I did about the same thing with would otherwise be 3 useless UHF 2 channel Kenwood ProTalk radios I got from a buddy for free. Programmed one channel for the typical GMRS road frequency and the other the local GMRS repeater. None of those are in the selection list of preconfigured frequencies for those radios.
What does piss off people are those that treat the rules as “suggestions” with no concern for possible enforcement actions, or where they prove inconvenient when they want to do something that’s prohibited. There are several on these forums who think that way. Unfortunately they set a bad example for the newbies.
Not very reassuring without firm legal ground to support the practice. At least people should be aware that it could be ruled as prohibited at some point so one shouldn’t get their panties in a twist “if” it ever happens. -
I tried looking that up to see if there is any definitive definition by the FCC. Nothing immediately popped up that wasn't confusing. I guess that's why we have lawyers and courts to argue the issue. Maybe some court will reach an opinion, then later elsewhere another court will reach a different opinion. Oh well, use your own best judgement. -
What was your LEAST favorite radio for GMRS you wasted money buying?
Lscott replied to Lscott's topic in General Discussion
I have one of the tri-band HT's. I dropped it on the cement floor once at a Twin Peaks while out with the guys. The audio got buggered up. I opened the radio to see if the speaker wires broke, nope. I did get it replaced under warranty but wasn't impressed with the durability. I use it now in a office setting as a cheap scanner. I won't buy another one, seems way too fragile. -
Here is another analysis. Just another point of view. http://www.nsea.com/Linking.pdf -
See attached files. 14641445_GroundingTipsfortheShack.pdf 203345484_LightningProtectionGroundingSolutionsforCommunicationSites.pdf
This is my Anytone D878UV model 1 in digital monitor mode. I had my Kenwood TK-D340U programmed for this repeater and talk groups. However one evening the Kenwood wouldn't decode any audio. So, I grabbed the D878UV and used the digital monitor to see what was going on. Turns out this was an undocumented talk group on the repeater. While these radios don't have the best receivers, some remark in analog mode it's not great, they do make nice radios to experiment with DMR if you can get one cheap. I recently got a D878UV model 1 at a local Ham swap with antenna, battery pack and charger base in like new condition for $35. Ordered a cheap soft nylon case, $12, for it on line. While this radio won't out perform any of the commercial grade DMR radios it has one feature none of them have, the digital monitor mode. If you can get one of these cheap enough this feature is worth it if you use DMR and need to identify undocumented user ID's, time slots, color codes and talk groups that are in use. You can carry the radio in your pocket whereas that's not possible with an SDR dongle plugged into a laptop. -
By any chance did you forget to enter the "secret" password code to set the mode? It's in the second of the two photos. Also if you look at the text file for the at_options app you'll see the same code just before the lines for the various modes listed for the different D878 models. There is a different code for the D578 series.
I don't believe I have ever used the "AT" option exe to change the mode. I just programmed the radio with it set through the CPS. I just updated the firmware, V1.27, and rebuilt the code plug. Nothing unusual when I programmed the radio and the code plug was built for the expanded RX and TX range. Maybe somebody else can share their experience.
I've used it a number of times. There was a DMR signal source on the same frequency used by another local mall I monitor while at work. Without the digital monitor I had zero idea what it was. It turned out to be a hospital security detail. While monitoring the communications I was able to gather enough info to figure out which one. Then just the other day on a Ham DMR repeater I was getting traffic but no audio on any of the talk groups I had programmed in. After monitoring a few minutes it was an undocumented talk group on that machine. Dah.
I've spent too much the last few weeks. I located a vendor in the Netherlands that still had, or access to, the discontinued Kenwood TK-D300E radio. Just got an email from them with tracking number so it should ship today or tomorrow. With just the belt clip and radio core, both new, cost me 271 Euro's with tax and shipping. That now gives me two, one used and a new radio. https://www.kenwood.eu/files/file/comms/uk/brochures/nx/TK-D200_D300_V4.1.pdf Then just a day ago a seller on eBay has a complete kit, radio, battery pack, charger base, antenna etc., all NEW for a TK-5320 FM/P25 radio with the 400MHz to 470MHz band split. https://www.ebay.com/itm/275450179209?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=sUiBWWytRDK&sssrc=2047675&ssuid=j_t98fioS_6&widget_ver=artemis&media=COPY https://comms.kenwood.com/common/pdf/download/TK-5220_5320_Specsheet.pdf The price was $250 total with free shipping. Knowing what stupid high prices used P25 radios run I purchased one, the price was way too good. That gives me three of these in my collection now. Still looking for a second VHF version, TK-5220, that the seller isn't trying to rape you on price. The VHF stuff sells for significantly more than the UHF gear.
I'm not so sure of the reception ability of the D878UV design. I had my first generation D878 sitting on a desk next to my Kenwood TK-D340U. https://comms.kenwood.com/common/pdf/download/DMR_TK-D240V_D340U_K_letter_1124.pdf Both were monitoring the output of a local DMR repeater. On multiple occasions the Kenwood would decode audio while the D878 just light up the green RX LED and nothing was decoded. I'm doubting the ability of the D878 to reliability decode DMR traffic now. The best feature of the D878 however is the digital monitor mode. You have no idea what slot, color code, talk group and user ID is being used, well the digital monitor mode shows it all. Unfortunately the higher end commercial DMR radios can't do it. I have a MARS/CAP modded TK-D74A. The radio is a beast. It's the fastest scanning radio I have, something like over 20 plus channels per second. I've only used mine maybe a few times. Other than the D578 it's the only other radio I have than can run digital voice on the 1.25 meter band. With the prices these are selling for used it's like own a brick of gold. One odd thing is nobody in North American sold a soft case for it. I even contacted the US based Kenwood tech support and they confirmed it. Nobody could explain why. I had to order one from a Ham radio dealer in the UK and shipped it by airmail here.
You can use directional antennas, or a bit more power with an “eggbeater” type for TX and RX. The way they are designed is the radiation pattern is circularly polarized and directed up and out to the horizon, thus no tracking required. http://146970.com/PDFs/Antenna Eggbeater-Revisited-English.pdf -
I don’t like the one I have. It was a freebie. Had nothing but problems trying to program it. Half the time or more the communications between the PC and radio fails so you can’t reprogram the radio. After a few tries I tossed it in a storage bin. Haven’t touched in a couple of years. -
I wouldn't mind having one myself. I've been on the look out for a good deal on one. For $150 and no slugs I can get one that's beat to crap, or for $250 to $300 and still no slugs I can get a nice one in very good condition. Don't forget you an buy them with different connectors. They can be swapped but you're better off getting it with the ones you want. Also the slugs aren't cheap either.
Well you are the best judge of which connector type will suite your needs the best. Don't forget you may at some point want to use the antenna with another radio, such as a mobile, so you'll likely will need some adapters sooner or later anyway.
